    Can I use su to produce this , plugin ?
    13 Posts 6 Posters 804 Views 6 Watching
    • B
      bejoo
      @numbthumb said:
      What was done with 3ds Max?
        could it be done with SU .. is there plugins ?
        Yes
        • numbthumbN
          numbthumb
          No plugins needed. Except maybe for that tapered curved part: http://www.drawmetal.com/
          Comfortably numb...
          • GaieusG
            But the profile is twisting just as if it had bee made with the tool πŸ˜„
            • GaieusG
              Not exactly the same spiral but would it be something like this?
              There were three plugins involved here:
              1. Made a helix (there are lots of helix or spiral plugins)
              2. Used SketchyFFD (Free Form Deformation) plugin to make the middle "fatter" a bit - this was only to "prove" the concept that the spiral/path can be nicely deformed
              3. Finally used taper maker plugin to do the tapered "follow me". This could also be done in more steps (in the original image, the extrusion seems to be equally fat for a while and only the end tapers visibly)
              taper.skp
              • irwanwrI
                irwanwr
                i don't get it.
                • T
                  tspco
                  Must be a secret, I can't see it.
                  SU make 2017, /Twilight Render Hobby
                  Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                  • GaieusG
                    @irwanwr said:
                    i don't get it.
                    What don't you get? The steps?
                    What can't you see? The file? The resulted taper?
                    • numbthumbN
                      numbthumb
                      Probably the file that was attached in the first post. Because I donΒ΄t see it anymore, either πŸ˜•
                      Comfortably numb...
                      • GaieusG
                        Ah, you are right. It was edited later by the poster I see.
                        • irwanwrI
                          irwanwr
                          well, he probably work for CIA, old KGB and Mossad at the same time πŸ˜›
