    [Plugin] Super Drape
    192 Posts 54 Posters 391.4k Views 54 Watching
    • utilerU
      utiler
      @tig said:
      Here's v3.0 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
      It's little changed... except that it is now an Extension.
      [The update is part of my Extension-izing of my toolsets...]
      You can now download it as either a ZIP or an RBZ archive.
      If you have the recent SUpv8M2 you can now simply install the tool's file/subfolder+files from the RBZ format archive using Preferences > Extensions > Install Extension button...
      Otherwise use the ZIP version as before, extracting and installing the files/subfolder_files manually into the Plugins folder...
      Note that as an Extension it must now be activated initially with the Preferences > Extensions > Super Drape checkbox.
      And as an Extension it can now be activate/deactivated as desired using that checkbox to optimize Sketchup's tool-loading and memory-usage...
      Cool TIG, So no need to delete the previous one?
      Just Curious...
      • BoxB
        That is odd Tig, I removed it and tried again.
        Same thing, not in the extensions until I restart, the toolbar was there straight away.
        It's not an issue, just odd, and I was looking in the right place.
          This script does a 'tidy up', so no need to remove old files etc...
          Strange about it appearing/not in Extensions...
          The other issue I am trying to fix is that the toolbar appears initially ticked but it's not showing, then you un-tick it and it's still not showing, then you re-tick it and it finally shows ! 😒
            Here's v3.1 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
            No dramatic changes... but the toolbar now appears correctly after an rbz install...
            As I said before...
            Otherwise use the ZIP version as before, extracting and installing the files/subfolder_files manually into the Plugins folder, and restarting...
            You may also need to activate the toolbar, depending on whether it's a new install or not etc...
            • G
              Gillman
              TIG, thanks for a great tool. And all your others as well. They're fast becoming the first tools I look to for my projects.
              • B
                bhbarchitects
                Thanks TIG
                Had so much trouble with drape crashing I had to stop using it, long live super drape..
                • K
                  Kesian
                  It's ker-splatting me too. Maybe I'm trying to drape too large an area?
                  • charly2008C
                    charly2008
                    Hello to All,
                    I would like to project a transparent logo on a cylindrical surface.
                    I thought I could do it with Superdrape. I've edited the "PNG Image" with "Imagetrimmer". But ImageTrimmer creates a component. SuperDrape only works with a group. If I transform, the component in a group than the texture gets mixed up .
                    Does anyone know another solution?
                    Charly
                    Untitled.skp
                      Just a thought but could you draw a circle below (or above) the circle you just cut out and then apply the material as Projected to that circle before using it to drape onto the cylinder?
                        • charly2008C
                          charly2008
                          Hi TIG,
                          I would like to again thank you very much for your help.
                          Charly
                            rachmatrf
                            Hi TIG,
                            Thank you again... 😍 😍
                            You Rock!!!
                              dansphere
                              This is awesome! Used it loads already.
                              Is it possible to have the resultant lines and faces go to default layer 0 or a specified layer instead of matching the layer of the surface it's being draped onto? That was I could hide the surface and picked out the draped lines and faces all curvy n such 😄
                              D
                                dbalex
                                just wanted to say thanks for this one, it works incredibly well!
                                http://www.bocostudio.com
                                • opalO
                                  opal
                                  I love this tool! It worked great this morning - several times.
                                  This afternoon - 4 bugsplats in a row, right as I click the second group.
                                  I even reinstalled it.. splat.
                                  I haven't changed anything in the program.. no updates on anything since using SU this morning. I don't know what I'm doing to cause the splat.
                                    Have you used Model Info > Statistics > Fix Problems... ?
                                    Have you tried moving the draped object a tiny amount ? Sometimes small facets cause issues.
                                    Alternatively Scale everything up x10 or x100 and retry. Scale down afterwards...
                                    Report back... 😕
                                    • opalO
                                      opal
                                      Report back... 😕
                                      Back after testing.
                                      I had not used the statistics fix, but do use TT's cleanup frequently.
                                      moved objects.. centered on origin.. nudged.
                                      scaled up by 10 and 100
                                      all splats 😞
                                        MartinK
                                        Thanks TIG, another useful plugin. This will be quite helpful in draping 2D site plans with materials onto a 3D terrain.
                                          Totally missed this one! 😲 😎 👍
                                          • B
                                            bravoddb
                                            Can I drape solids? can I do it with a mesh made in sandbox? I need to make a road that follow the terrain, I bought Instant road and I couldn't make it work, I tryed super drape but it crashes, what can I do? or how can I do it?
                                            • 7 / 10
