    [Plugin] Super Drape
    192 Posts 54 Posters 375.0k Views 54 Watching
      This script does a 'tidy up', so no need to remove old files etc...
      Strange about it appearing/not in Extensions...
      The other issue I am trying to fix is that the toolbar appears initially ticked but it's not showing, then you un-tick it and it's still not showing, then you re-tick it and it finally shows ! 😒
        Here's v3.1 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
        No dramatic changes... but the toolbar now appears correctly after an rbz install...
        As I said before...
        The update is part of my Extension-izing of my toolsets...
        You can now download it as either a ZIP or an RBZ archive.
        If you have the recent SUpv8M2 you can now simply install the tool's file/subfolder+files from the RBZ format archive using Preferences > Extensions > Install Extension button...
        Otherwise use the ZIP version as before, extracting and installing the files/subfolder_files manually into the Plugins folder, and restarting...
        Note that as an Extension it must now be activated initially with the Preferences > Extensions > Super Drape checkbox.
        And as an Extension it can now be activate/deactivated as desired using that checkbox to optimize Sketchup's tool-loading and memory-usage...
        You may also need to activate the toolbar, depending on whether it's a new install or not etc...
          Gillman
          TIG, thanks for a great tool. And all your others as well. They're fast becoming the first tools I look to for my projects.
            bhbarchitects
            Thanks TIG
            Had so much trouble with drape crashing I had to stop using it, long live super drape..
              Kesian
              It's ker-splatting me too. Maybe I'm trying to drape too large an area?
              • charly2008C Offline
                charly2008
                Hello to All,
                I would like to project a transparent logo on a cylindrical surface.
                I thought I could do it with Superdrape. I've edited the "PNG Image" with "Imagetrimmer". But ImageTrimmer creates a component. SuperDrape only works with a group. If I transform, the component in a group than the texture gets mixed up .
                Does anyone know another solution?
                Charly
                Untitled.skp
                  Just a thought but could you draw a circle below (or above) the circle you just cut out and then apply the material as Projected to that circle before using it to drape onto the cylinder?
                      charly2008
                      Hi TIG,
                      I would like to again thank you very much for your help.
                      Charly
                        rachmatrf
                        Hi TIG,
                        Thank you again... 😍 😍
                        You Rock!!!
                          dansphere
                          This is awesome! Used it loads already.
                          Is it possible to have the resultant lines and faces go to default layer 0 or a specified layer instead of matching the layer of the surface it's being draped onto? That was I could hide the surface and picked out the draped lines and faces all curvy n such 😄
                          D
                            dbalex
                            just wanted to say thanks for this one, it works incredibly well!
                            http://www.bocostudio.com
                            • opalO Offline
                              opal
                              I love this tool! It worked great this morning - several times.
                              This afternoon - 4 bugsplats in a row, right as I click the second group.
                              I even reinstalled it.. splat.
                              I haven't changed anything in the program.. no updates on anything since using SU this morning. I don't know what I'm doing to cause the splat.
                                Have you used Model Info > Statistics > Fix Problems... ?
                                Have you tried moving the draped object a tiny amount ? Sometimes small facets cause issues.
                                Alternatively Scale everything up x10 or x100 and retry. Scale down afterwards...
                                Report back... 😕
                                • opalO Offline
                                  opal
                                  Report back... 😕
                                  Back after testing.
                                  I had not used the statistics fix, but do use TT's cleanup frequently.
                                  moved objects.. centered on origin.. nudged.
                                  scaled up by 10 and 100
                                  all splats 😞
                                    MartinK
                                    Thanks TIG, another useful plugin. This will be quite helpful in draping 2D site plans with materials onto a 3D terrain.
                                      Totally missed this one! 😲 😎 👍
                                        bravoddb
                                        Can I drape solids? can I do it with a mesh made in sandbox? I need to make a road that follow the terrain, I bought Instant road and I couldn't make it work, I tryed super drape but it crashes, what can I do? or how can I do it?
                                          This doesn't drape 'solids' - only 'faces' - it you explode the solid and get the faces to drape?...
                                          It you want to 'imprint' solids onto a terrain that's a 'whole new kettle of fish'... 😕
                                          • bsintzelB Offline
                                            bsintzel
                                            TIG,
                                            First I'd like to thank you for your amazing plug-ins. They are all incredibly useful.
                                            I had two questions:
                                            1 - Your Super Drape plugin (above) is is labeled version 3.1, but your download 'appears' to be v3.0. Is this simply a typo?
                                            2 - I experimented with this plugin using various constructs, all of which were grouped (see attachment). All worked well until I attempted to drape grouped text onto the surface of a circle. It appears that the material doesn't transfer. It's probably something I'm doing wrong so if you can...please let me know.
                                            warm regards
                                            Bob
                                            SuperDrape Material anomolie.skp
                                            I've taken obfuscating to a whole new level!
                                            • 7 / 10
