    Help With Slide Using Follow Me Tool
    12 Posts 7 Posters 1.0k Views 7 Watching
      cmartin
      @tig said:
      Try FAK [FollowMeAndKeep] available from through the Plugins Index button above...[attachment=0:159wwqpm]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:159wwqpm]
      thank you!
      • dukejazzD Offline
        dukejazz
        Move face to wire
        Then used follow me
          FollowMe can 'twist' as it extrudes...
          FAK does not 'twist'...
          Which is often what is required ๐Ÿ˜‰
          • BoxB Offline
            Then laugh maniacally as the children fly off to their death on the first curve.
            Oops Tig slipped in there to explain what I was referring to before I said it.
            • jeff hammondJ Offline
              @dukejazz said:
              hee! hee! ha! ha!
              That the point why the drawhelix13 tool to create a spiral is not a good ideal in general. The top and bottom of his spiral is inverted. What he need is a coil not a spring to use sketchup push-pull tool.
              So the tool (FAK [FollowMeAndKeep]) you refer too. works well with helix spring for a slide. good ideal.
              huh? the draw helix tool has nothing to do with it..
              normal sketchup follow me doesn't have a 'road-like top' option.. (or in other sketchup lingo, it will not auto-fold edges)
              in the case of this slide, the vertical faces need to break (triangulate) in order to keep a level top but follow-me won't do that.. it keeps all the sidewall faces coplanar which leads to the twist..
              hence the need for a plugin.
                my spider sense is tingling
                  i can think of about 11 different things you mean by that.. none of them related to one another.
                  mystery is good though.. matches you're avatar ๐Ÿ‘
                  ๐Ÿ˜„
                  • mitcorbM Offline
                    mitcorb
                    The tingle may be FollowMe Helix. Look it up in the Candy Sto-- uh I mean the Plugins Index. Also, I believe DrawHelix is up to 1.4. And here comes somebody else.
                    • dukejazzD Offline
                      dukejazz
                      Hee hee! ha ha!
                      That the point why the drawhelix14 tool to create a spiral slide with SU follow me tool is not a good ideal in general. The wire spiral is always twisted. What he need is a flat coil slinkey not a twisted wire spring to use for the slide.
                      So the tool (FAK [FollowMeAndKeep]) you refer too. works well with helix spring for a slide. Good ideal.
                      • dukejazzD Offline
                        dukejazz
                        I tried out FAK today on Vista SU 8 M2
                        The tool (FAK [FollowMeAndKeep]) you refer too. works well with helix spring for a slide. Good ideal. I also agree with you all now about the curve problem.
