    RBZ as allowed extension
    72 Posts 11 Posters 9.5k Views 11 Watching
    • jeff hammondJ
      actually, i just backwards tested it and i think your code will be a-ok on mac.
      i renamed my plugins folder and created a new empty one then zipped up a bunch of random crap laying around the desktop..
      changed it to .rbz then installed it via su extensions.. the empty plugin folder was then populated with all that stuff without the standard osx additional folder..
      • jeff hammondJ
        @jim said:
        By the way, Alex Schreyer mentioned on twitter that in Windows you can past a URL to a .zip or .rbz in the file browser opened by the Install Extensions button, and have the plugin install over the Internet.
        neat.. i'm posting this file here so i can test it on mac..
        url_install_test.rbz
          Jim
          I don't believe SketchUp does any sort of validation check of the .zip/.rbz file - if the author messes up the file layout in the archive, the files will be messed up when extracted and the plugin won't work, and may cause load errors.
            Jim
            Won't work because you need to be logged in to download files... already tried. πŸ˜„
              driven
              works here, using your code Jim
              • jeff hammondJ
                [attachment=0:2jb6paan]<!-- ia0 -->of_course.png<!-- ia0 -->[/attachment:2jb6paan]
                πŸ˜† πŸ˜† πŸ˜†
                • jeff hammondJ
                  [attachment=0:1sd00pi3]<!-- ia0 -->url_install_test.rbz<!-- ia0 -->[/attachment:1sd00pi3]
                  nah.. not happening
                  [oh.. i see this from you now: "Won't work because you need to be logged in to download files... already tried. "]
                  πŸ˜†
                  well, it's not like the author was doing anything wrong.. for instance, say i want to download didier's projections plugin..
                  on windows, it will be:
                  projection_v2.zip
                  β€” Projection
                  β€” projection_extensions.rb
                  β€” Projection.pdf
                  β€” read_me.txt
                  whereas, on mac, you'll have
                  projection_v2.zip
                  β€” projection_v2
                  β€” β€” Projection
                  β€” β€” projection_extensions.rb
                  β€” β€” Projection.pdf
                  β€” β€” read_me.txt
                  you see.. there's an extra folder in there.. and i can't just "unzip projection_v2.zip in the plugins folder"(as is often stated in ruby instal instructions) and expect it to work.. it won't work.
                  and sometimes, to make matters more confusing, the .zip and the folder that supposed to go in the plugins folder share the same name so we end up with 2 folders of identical names and are being told to put it in the plugins folder (but there is no 'it'.. there are two of them) πŸ˜„
                  you see the confusion? and it's not as if the writer's have done anything wrong with their packaging/delivery.
                    Jim
                    You should probably remove the _MACOSX folder and any .DS_Store files. They must be hidden files on a Mac by default?
                    • jeff hammondJ
                      yeah, they're in all our folders.. they tell the computer how to arrange the icons or what sort order to put the files in etc.. we (mac users) don't see them unless we turn them on but i always hear windows people complaining when they get zips from macs.. πŸ˜„
                      (but i can send driven a folder which will open with all the files arranged in a certain way.. this can come in real handy when working on projects and whatnot between different people/computers.. so they do have a benefit of being included with our folders)
                      there are some 3rd party compression apps and terminal and/or automator commands that people use prior to sending to windows but fwiw, those files are harmless to you.
                        driven
                        I'm not seeing the _MACOSX folder and the .Ds_Store can't be easily avoided, unless you remove them from all, system wide.
                        are you seeing _MACOSX folder if you change it to zip and open.
                        Google generated a _MACOSX folder in Plugins on a test I did last night...
                          driven
                          it has the .ds store but not the other, I believe thats SU...
                          I changed .rbz to .zip to look inside the download from here.
                          this is what I downloaded from here
                          • jeff hammondJ
                            here's a little freebie that will keep them out of your zips..
                            http://www.sopht.jp/cleanarchiver/
                            there are some more robust ones as well but i just use archiveutility.app that ships with osx.. i rarely send zips to windows users anyway..
                              driven
                              cheers Jeff,
                              I've actually got YemuZip which does the PC friendly bit, but right clicking is easier.
                              Jim, can you check if that _Mac folder is still generated?
                              no mac only files in this zip...
                                driven
                                proper test complements of Jim... thanks in advance Jim
                                re-name or disable 'homer' if already in your Plugins, and try the loader.
                                REMOVED ATTACHMENT... there's another below
                                the Extension Button works here and so does Jim's first script.
                                the difference is SU opens the toolbar button and Jim's you need to enable it...
                                  Jim
                                  I checked - no extraneous files/folders.
                                    Until .rbz is associated with SketchUp I see no point in using the .rbz format over .zip. The Install Extension button and the API methods accepts either format, so why not keep distributing in .zip?
                                      The API does allow ZIP or RBZ files... but the Preferences > Install Extension button filters the list of available files to choose from in the dialog that opens to RBZ files only [can't be changed!] - so if you want to use the installer button then your stuff must be packaged as RBZ rather than ZIP, but annoyingly you'll still need a ZIP version for all of the other users with versions that don't include the installer button!
                                      πŸ˜’
                                        What? They didn't add .zip to the list? πŸ˜’
                                        One can just type * in the file name text field, but then you've already defeated the purpose of making things easy and non-technical. x_X
                                          driven
                                          And if it's Zipped on a Mac, Google creates a new folder to hold the .DS_Store
                                          If it's only the one I guess it means we don't need to 'PC' Zip files from mac's...
                                            Jim
                                            I understand the Mac command-line zip utility does not create the extraneous files or folders.
                                            $ zip -r homer.zip homer.rb homer/
                                            You can also create the .rbz directly:
                                            zip -r homer.rbz homer.rb homer/
                                            And view/extract the contents of .rbz without renaming.
                                            $ unzip -l homer.rbz $ unzip homer.rbz
                                            • 2 / 4
