    RBZ as allowed extension
    72 Posts 11 Posters 8.7k Views 11 Watching
    • jeff hammondJ Offline
      @jim said:
      careful with that.. macs are different than pc when it comes to zip.. an example i used recently..
      There is no difference between a .rbz and a .zip. The .rbz is simply a renamed .zip. The .rbz just adds to the confusion, IMO.
      However, it is SketchUp that is handling the unzipping, not the operating system. It is still up to the plugin author to create the .zip/.rbz the right way so it unzips correctly. Most of the .zip plugins are all ready to go.
      Error 404 (Not Found)!!1
      (sketchupapi.blogspot.com)
      oh.. as long as sketchup is doing the unzipping then it should be ok.. i'm sure on SUosx, sketchup is ignoring the top level folder -or- i suppose that top level folder is actually being added by osx during the unzipping process..
      but i can't test your code 😳 πŸ˜† you got something i can copy/paste into the console to try ?
        Jim
        Try this one-liner:
        Sketchup.install_from_archive(UI.openpanel("Install","","*.zip"))
        By the way, Alex Schreyer mentioned on twitter that in Windows you can past a URL to a .zip or .rbz in the file browser opened by the Install Extensions button, and have the plugin install over the Internet.
          actually, i just backwards tested it and i think your code will be a-ok on mac.
          i renamed my plugins folder and created a new empty one then zipped up a bunch of random crap laying around the desktop..
          changed it to .rbz then installed it via su extensions.. the empty plugin folder was then populated with all that stuff without the standard osx additional folder..
            neat.. i'm posting this file here so i can test it on mac..
            url_install_test.rbz
              Jim
              I don't believe SketchUp does any sort of validation check of the .zip/.rbz file - if the author messes up the file layout in the archive, the files will be messed up when extracted and the plugin won't work, and may cause load errors.
                Jim
                Won't work because you need to be logged in to download files... already tried. πŸ˜„
                  driven
                  works here, using your code Jim
                    [attachment=0:2jb6paan]<!-- ia0 -->of_course.png<!-- ia0 -->[/attachment:2jb6paan]
                    πŸ˜† πŸ˜† πŸ˜†
                      [attachment=0:1sd00pi3]<!-- ia0 -->url_install_test.rbz<!-- ia0 -->[/attachment:1sd00pi3]
                      nah.. not happening
                      [oh.. i see this from you now: "Won't work because you need to be logged in to download files... already tried. "]
                      πŸ˜†
                      well, it's not like the author was doing anything wrong.. for instance, say i want to download didier's projections plugin..
                      on windows, it will be:
                      projection_v2.zip
                      β€” Projection
                      β€” projection_extensions.rb
                      β€” Projection.pdf
                      β€” read_me.txt
                      whereas, on mac, you'll have
                      projection_v2.zip
                      β€” projection_v2
                      β€” β€” Projection
                      β€” β€” projection_extensions.rb
                      β€” β€” Projection.pdf
                      β€” β€” read_me.txt
                      you see.. there's an extra folder in there.. and i can't just "unzip projection_v2.zip in the plugins folder"(as is often stated in ruby instal instructions) and expect it to work.. it won't work.
                      and sometimes, to make matters more confusing, the .zip and the folder that supposed to go in the plugins folder share the same name so we end up with 2 folders of identical names and are being told to put it in the plugins folder (but there is no 'it'.. there are two of them) πŸ˜„
                      you see the confusion? and it's not as if the writer's have done anything wrong with their packaging/delivery.
                        Jim
                        You should probably remove the _MACOSX folder and any .DS_Store files. They must be hidden files on a Mac by default?
                          yeah, they're in all our folders.. they tell the computer how to arrange the icons or what sort order to put the files in etc.. we (mac users) don't see them unless we turn them on but i always hear windows people complaining when they get zips from macs.. πŸ˜„
                          (but i can send driven a folder which will open with all the files arranged in a certain way.. this can come in real handy when working on projects and whatnot between different people/computers.. so they do have a benefit of being included with our folders)
                          there are some 3rd party compression apps and terminal and/or automator commands that people use prior to sending to windows but fwiw, those files are harmless to you.
                            driven
                            I'm not seeing the _MACOSX folder and the .Ds_Store can't be easily avoided, unless you remove them from all, system wide.
                            are you seeing _MACOSX folder if you change it to zip and open.
                            Google generated a _MACOSX folder in Plugins on a test I did last night...
                              driven
                              it has the .ds store but not the other, I believe thats SU...
                              I changed .rbz to .zip to look inside the download from here.
                              this is what I downloaded from here
                                here's a little freebie that will keep them out of your zips..
                                http://www.sopht.jp/cleanarchiver/
                                there are some more robust ones as well but i just use archiveutility.app that ships with osx.. i rarely send zips to windows users anyway..
                                  driven
                                  cheers Jeff,
                                  I've actually got YemuZip which does the PC friendly bit, but right clicking is easier.
                                  Jim, can you check if that _Mac folder is still generated?
                                  no mac only files in this zip...
                                    driven
                                    proper test complements of Jim... thanks in advance Jim
                                    re-name or disable 'homer' if already in your Plugins, and try the loader.
                                    REMOVED ATTACHMENT... there's another below
                                    the Extension Button works here and so does Jim's first script.
                                    the difference is SU opens the toolbar button and Jim's you need to enable it...
                                      Jim
                                      I checked - no extraneous files/folders.
                                        Until .rbz is associated with SketchUp I see no point in using the .rbz format over .zip. The Install Extension button and the API methods accepts either format, so why not keep distributing in .zip?
                                          The API does allow ZIP or RBZ files... but the Preferences > Install Extension button filters the list of available files to choose from in the dialog that opens to RBZ files only [can't be changed!] - so if you want to use the installer button then your stuff must be packaged as RBZ rather than ZIP, but annoyingly you'll still need a ZIP version for all of the other users with versions that don't include the installer button!
                                          πŸ˜’
                                            What? They didn't add .zip to the list? πŸ˜’
                                            One can just type * in the file name text field, but then you've already defeated the purpose of making things easy and non-technical. x_X
                                            • 1 / 4
