    Best free Plug-in's
    30 Posts 10 Posters 3.5k Views 10 Watching
    • massimoM Offline
      massimo Moderator
      Press the big red button called "Plugins index" on top of the page then go to TIG-->image trimmer.
        JMdesigns
        Thank you. OK, i downloaded the plugin, installed, and imported my logo as a PNG with transp. But nothing seems to happen??
        it shows on the bottom that something is happening but nothing? I even tried it on the " remy martin" PNG file from the thread and nothing?
        please advise, thanks
          Read the thread to see if your Java is enabled.
            more easy and fun than Inkscape : the Free Expression 3 πŸ˜‰
            (description is in French but prog is in English! πŸ˜’
              JMdesigns
              Hi Rich, how do i do this?..I read the thread, and dont have a compression program ? can i do this in SU ?
                This has f*all [or at least very little] to do with 'compression-progs' !
                IF you were to read the thread carefully you should see that you need to have Java properly enabled on your PC [through Windows and the Java Control Panel], and also set to allow local execution of any .jar files etc...
                You should also check that the .jar file suffix remains assigned to be executed with Java; because a few compression progs will try to hijack it and try to open it themselves unless you read what you are doing when you accept their default settings... so it then fails when the .jar doesn't execute properly as it must... πŸ˜’
                  f*all?
                  frall...
                  feall...
                  fiall...
                  WTF?
                    feck!
                      JMdesigns
                      TIG,
                      Forgive me for my ignorance, i installed java and cant seem to find the file settings?
                      I have attached a screen shot, thank you for your help
                      computer screen
                        JMdesigns
                        Nevermind TIG, unclebim helped me πŸ˜„ ...he said just run SU as administrator, and it works πŸ˜‰
                          There's usually a 'Java' Control Panel with the rest of them...
                          • 2 / 2
