    Materials I have not applied to the model
    9 Posts 6 Posters 506 Views 6 Watching
    • charly2008C Offline
      charly2008
      Hi All,
      I've seen it before, that there are materials in a new model that I have not applied. Is this a SketchUp bug?
      Charly
        Charly, open a new session in SketchUp. Then look at the materials browser. Are those materials in the browser? If so, they are saved as part of your template.
          The triangle of the material thumbnail indicate that the two green materials are in use in the model.
          Make sure your template is cleaned of any hidden geometry and that no edges has any material applied, purge and re-save your template.
            driven
            Ivy maker, preloads it's materials [and so does lightup], whether you want them or not.
            the only way I found to stop it happening is to disable the plugin and turn on it only when you want it/them...
              charly2008
              Hi Dave,
              If I start a new session, the materials are gone. Even if I start with a different template the materials are again available. While it is nothing bad, I only ask why this is so.
              Charly
                charly2008
                Hi John,
                thanks for the explanation. The materials disappeared after the deactivation of the plugin.
                • TIGT Online
                  At the end of the LiveIvy_tool.rb there's this:
                  if (not file_loaded?(File.basename(__FILE__)))
                    menuitem = "SketchupIvy #{LiveIvy;;VERSION}"
                    mm       = UI.menu("Plugins")
                    mm.add_item(menuitem) {
                      Sketchup.active_model.select_tool LiveIvy;;IvyTool.new
                    LiveIvy;;IvyTool.load_definitions
                    LiveIvy;;Materials.ivy_materials
                  file_loaded(File.basename(__FILE__))
                  if you edit it to read thus, then the Components and Materials will only load IF you use the tool...
                  because the action is moved into the menu block rather than running when the script loads at startup!
                    charly2008
                    Thank You TIG,
                    you are great
                    Charly
                      gr8fzy1
                      Post removed, I solved the problem myself
