    Any Cinema 4D users here?
    extensions
    27 Posts 9 Posters 3.0k Views 9 Watching
      And fully compatible with Moment of Inspiration! πŸ˜‰
      (Moi --> C4D not the inverse!
      (Moi is used in general as Pre-modeler for C4D )
      Export from Moi in OBJ with Ngons enable! πŸ€“
      (if you don't know Moi, it has the same spirit of facility than SU! 😎
      PS Hypernurbs has nothing to see with real Nurbs πŸ˜‰
      • soloS Offline
        Pilou, you have punted MOI hundreds of times, are you an employee?
          MOI is good but not a mapping solution.
          • StinkieS Offline
            Stinkie
            @solo said:
            Pete,
            Would you ever try Blender? It's quite powerful and when you start to get to grips with it you reap the benefits. Plus the tutorials are abundant and free.
            Blender is very powerful, but so intimidating, the problem is getting to grips with it, I have tried a few times but just fizzled out.
            You know, the 'recent' UI overhaul really worked wonders. And Rich is right about those tuts.
            http://cgcookie.com/blender/get-started-with-blender/
            Not free, but looks good:
            http://www.cgmasters.net/training-dvds/environment-modeling-and-texturing/
              @Solo
              Not really, but i am with it from the begining for all the French parts! πŸ˜„
              UI, Manual, Forum, Wiki, my own site and own tutorial videos etc... a cool mode to fill my old days and nights! β˜€
              About the mapping, there is no problem: make it in C4D
              All is yet well oriented for a renderer πŸ˜„
              And better than Blender for example, this last one don't know use all informations of orientation's vertices/faces !
              Modeling Moi3D and Autodesk 123d
              Texturen and Fx Cinema 4D and Turbulence 4D
              Animation Cinema4D
              Rendering Vray for C4
              By Zarkow
              [flash=560,315:2j34k90m]http://www.youtube.com/v/XfJM2z_tw0I[/flash:2j34k90m]
                Another great famous classic modeler guy just begin with C4D πŸ˜‰
                Glen Southern 😎
                This guy is very approachable don't hesitate to contact him πŸ˜„
                Maybe you can convert him to SU πŸ˜‰
                Some example of his new tutorials πŸ˜‰ no sound!
                (click the links if you want to have the full screen)
                http://vimeo.com/30935186
                [flash=400,225:ulph6fw4]http://vimeo.com/moogaloop.swf?clip_id=30935186&server=vimeo.com&show_title=0&show_byline=0&show_portrait=0&color=00adef&fullscreen=1&autoplay=0&loop=0" type="application/x-shockwave-flash[/flash:ulph6fw4]
                http://vimeo.com/31037569
                [flash=400,225:ulph6fw4]http://vimeo.com/moogaloop.swf?clip_id=31037569&server=vimeo.com&show_title=0&show_byline=0&show_portrait=0&color=&fullscreen=1&autoplay=0&loop=0" type="application/x-shockwave-flash[/flash:ulph6fw4]
                You can of course also see the other works more technic like this crazzy watch 😲 100% C4D
                http://vimeo.com/31463883
                [flash=400,240:ulph6fw4]http://vimeo.com/moogaloop.swf?clip_id=31463883&server=vimeo.com&show_title=0&show_byline=0&show_portrait=0&color=&fullscreen=1&autoplay=0&loop=0" type="application/x-shockwave-flash[/flash:ulph6fw4]
                By Glen Southern
                http://southerngfx.co.uk/wp-content/uploads/2011/10/steam-punk-watch-006-860x1024.jpg
                • daleD Offline
                  dale
                  Pete
                  Just wondered if you were tempted by the fact that Thea will soon operate fully functionally inside C4D? This would be absolutely amazing.
                  • soloS Offline
                    @dale said:
                    Pete
                    πŸ˜„ Yup.
                    • N Offline
                      notareal
                      @solo said:
                      @dale said:
                      Pete
                      πŸ˜„ Yup.
                      In The Oven - Thea Render for Cinema4D http://www.youtube.com/v/I-Vq2BGzdbU πŸŽ‰
                      As all plugin authors can use the same SDK, it's more a matter of time when further integration will happen... naturally C4D does benefit greatly as it can handle high polygon models. SU may still need a external renderer, because of it's memory limitations. But certainly a deeper integration is now possible.
                      • daleD Offline
                        dale
                        Which of the C4D versions are you looking at (or working with)?
                        • soloS Offline
                          R 13
                          • daleD Offline
                            dale
                            Final questions.
                            Are you able to export to C4D from SketchUp?
                            Does it work well, and in which format?
                            • soloS Offline
                              @dale said:
                              Final questions.
                              I have not tried yet, I am still on the absolute basics. Will need to stop learning this week as I have an urgent project (the hot potato job given to the foriegner over Thanksgiving) πŸ’š
                                πŸ˜‰
                                Thearender inside C4D (in the Oven)
                                [flash=560,315:1t0b68bl]http://www.youtube.com/v/I-Vq2BGzdbU[/flash:1t0b68bl]
                                • soloS Offline
                                  I know...DROOL!!! 😲
                                  • jeff hammondJ Offline
                                    hey wait.. that's the best time to learn a new app..
                                    refuse to open the app(s) you already know then be prepared to not sleep for 4 days.. on day 5, you'll be decently familiar with the new one
                                    β˜€ πŸ˜„
                                    • I Offline
                                      ilay7k
                                      c4d-user is here πŸ˜‰
                                      1. http://www.cineversity.com
                                      2. same guys and several from maxon.net(USA) made maxon's tip&tricks at youtube
                                      Pilou, i like lwo export from moi to c4d
                                        @ilay7k
                                        It's more also for Modo, or Blender but why not! β˜€
