    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 57.1k Views 16 Watching
      Jim
      @thomthom said:
      Dunno. I'd think it'd be possible. But I really have no clue when it comes to compiling. It'd be nice to have tutorials for different compilers. So please feel free to jump on the bandwagon )
      I could not get MinGW working using Ruby 1.8.6. I could get the examples to compile using Ruby 1.9.3, but they just crashed SketchUp.
      But both example seem to compile and work just fine in SketchUp using VC++ Express and Ruby 1.8.6 per your instructions in the Readme file.
      • Dan RathbunD
        Dan Rathbun
        Ruby v1.8.6-p287 was the last 'distro' to be compiled with MSVC. (.. which is likely why the GSUDT released SU8 with this patch level, even though their were newer v1.8.6 patch levels available.)
        All patch levels above p287 were distro'd (via Windows One-Click Installer,) compiled with MinGW.
        That is not to say, however that someone (including Google,) could build the newer patch levels with MSVC, or do a manual install by downloading precompiled binaries from:
        ftp;//ftp.ruby-lang.org/pub/ruby/binaries/mswin32/
        (.. However not all patch levels are available.)
        I'm not here much anymore.
        • T
          tomasz
          Shouldn't the C extension be protected by a sort of a "namespace"? I mean shouldn't Point3d {}; be SX_Ext_Point3D {};? If we have two diffetent DLL's, do their functions exist in a same 'space' πŸ˜„ ?
            No - only the Ruby modules, classes and methods you define - like in a normal Ruby Script. Everything else is isolated.
            As you see in the init function:
            <span class="syntaxdefault"><br />void&nbsp;Init_SX_Basics</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">void&nbsp;</span><span class="syntaxkeyword">)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Modules<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mSUExtTest&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">rb_define_module</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">"SUExtTest"&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Constants<br />&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;>&nbsp;SUExtTest;;SX_BASIC_VERSION<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_const</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SX_BASIC_VERSION"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">rb_str_new2</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">"0.1.0"&nbsp;</span><span class="syntaxkeyword">)&nbsp;);<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Methods<br />&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;>&nbsp;SUExtTest.foo<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"foo"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_foobar</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.multiply(&nbsp;number1,&nbsp;number2&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"multiply"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_multiply</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.pi_array(&nbsp;array&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"pi_array"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_pi_array</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.random_points(&nbsp;size&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"random_points"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_random_points</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.closest_distance(&nbsp;point_set1,&nbsp;point_set2&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"closest_distance"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_closest_distance</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2&nbsp;</span><span class="syntaxkeyword">);<br />}<br />&nbsp;</span><span class="syntaxdefault"></span>
            It's the rb_define_* that will make the extension share anything with the Ruby environment - everything else is isolated.
            • C
              chyn2000
              Hi Guys.
              First, I want to say that this project you have started is awesome. I had just decided I needed a ruby extension to get a speed boost for a plug-in project. I found a lot of tutorials on making extensions, but most were for either linux or for MS Visual Studio 6 on Windows. I'm not using either environment. I am on Windows 7 (64bit).
              Sooooo, I have followed TBD's example program the best I can.
              • I have downloaded the SUExt files.
              • I have downloaded the Ruby Installer and Source per the SUExt readme file and installed Ruby.
              • I have installed Pelles C.
              I tried to open suext.ppj file and Pelles C kept throwing an error about "suext.obj is wrongly located in -path_to_project-". So I tried suext6.ppj and it seemed to be fine. It even seemed to build once I pointed Pelles C to where my Ruby installation was at.
              From here I'm a little lost. Am I done? I brought up the irb and typed in: require 'path_to_project/suext.so'
              The results were as follows:
              LoadError: 127: The specified procedure could not be found. - Init_path_to_project\suext
              path_to_project\suext.so
              from path_to_project\suext.so
              from path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
              from (irb):1
              What am I missing?
              -Chyn
                When you require a C Extension, do not include the file extension.
                So instead of:
                do:
                require 'path_to_project/suext'
                • C
                  chyn2000
                  Ok. That certainly changed things a little.
                  I type:
                  irb(main):002:0> require 'path_to_project\suext'
                  and get back:
                  from (irb):2
                    or
                    • C
                      chyn2000
                      Both. The '/'s and ''s that are in the post were copied and pasted. I didn't change any of them. Let me know if you want the original output. I just shortened the paths for readability.
                      -Chyn
                        Jim
                        TIG means try using this --> / <-- instead of that --> ** <-- in your require statement.
                        • C
                          chyn2000
                          Ah. Gotchya now.
                          Nirg. Same result...
                          Anything else? Maybe is one of you guys have successfully built the example you could post it for download. That would make sure I've got my environment set up correctly.
                          -Chyn
                            How did you build it? Seems something has gotten confused and the path has gotten mixed into the name of the initializing procedure for the C Extension.
                            It tries to call a function named Init_path_to_project\suext - where, given the name suext it should be trying to call Init_suext.
                            • C
                              chyn2000
                              I built in Pelles C.
                              So, the path isn't hard coded in the program. I can place a copy of the suext.so on my d:\ and it changes the error out put to match:
                              irb(main):002:0> require 'D:\suext'
                              LoadError: 127: The specified procedure could not be found. - Init_D:\suext
                              D:\suext.so
                              from D:\suext.so
                              from d:/Ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
                              from (irb):2
                              Is there a specific directory I should have the file at?
                              • Dan RathbunD
                                Dan Rathbun
                                %(#BF8000)[path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/**custom_require.rb**]
                                Why are you customizing the require() method ?
                                Try it WITHOUT loading this custom script...
                                  Jim
                                  He isn't - this is something done by RubyGems.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    OK.. my bad.. N/M
                                      Jim
                                      You did it again.
                                      Use:
                                      require "D:/suext"
                                      irb(main);001;0> require 'C;\SX_Basics'
                                      LoadError; 127; The specified procedure could not be found.   - Init_C;\SX_Basics
                                      C;\SX_Basics.so
                                              from C;\SX_Basics.so
                                              from (irb);1
                                      irb(main);002;0> require 'C;/SX_Basics'
                                      => true
                                      irb(main);003;0>
                                        Jim
                                        Ok, I just built TBD's suext example using Visual Studio Express 2010.
                                        In order to get the extension to require properly, I had to use:
                                        require "SUExt" <-- note case
                                        require "suext" failed.
                                        • C
                                          chyn2000
                                          Yep Jim. That was exactly it!
                                          Thanks everyone. Let me know if there is anything I can do to help.
                                          Actually, it occurs to me that we may want to start making a small library of math and geometry ruby extensions very targeted towards SU. Thoughts?
                                          -Chyn
                                            Not a bad idea. I had plans of doing some bezier functions.
                                            • 3 / 9
