    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 46.3k Views 16 Watching
      I am writing the extensions in C. But under windows I installed Visual C++ Express 2010 because it has the required Windows headers and nmake to compile it. I have some crude notes in the README.txt in the repo. Under OSX you need X Tools from the OSX DVD.
        Note that I never use the Visual C++ IDE editor.
          Jim
          Just wondering if there's any reason that MinGW instead of MSVC++ could not be used to compile c extensions. I assume the c extension is a libaray and doesn't require any Windows-specific GUI stuff - it's just a library of functions, right?
          • Dan RathbunD Offline
            Dan Rathbun
            @thomthom said:
            Btw, does anyone know how one can make extconf.rb and make/nmake output their files to a given folder? I'd like to make it so that each platform outputs its generated files to separate directories.
            Did you check the methods defined in "mkmf.rb" ?
            (You can also see "Appendix C. Functions Available in extconf.rb" in the "README.EXT" file.)
            .. also check our the "extmk.rb" file in the ext dir.
            I'm not here much anymore.
              Dunno. I'd think it'd be possible. But I really have no clue when it comes to compiling. It'd be nice to have tutorials for different compilers. So please feel free to jump on the bandwagon πŸ˜‰ )
                Yea, got a wee bit lost... πŸ˜•
                  Dan Rathbun
                  I know (insert head-spinning emoticon here).
                  Lets try these:
                  A Simple Makefile Tutorial
                  Makefile Tutorial
                  I think the constant you want is DESTDIR or $(DESTDIR)
                    πŸ‘
                    Will have a look. Currently when I use nmake I get some warning about some of the compiler flags. Maybe I can eliminate them. I'd prefer that so there's less noise coming from the compiler. Easier to spot other warnings.
                    ( That first link is sightly messed up though, as they didn't escape angle brackets inside the code examples: #include <hellomake.h> eaten by the browser - at least under Firefox.
                    I've come across a partial documentation of mkmf: http://www.ensta-paristech.fr/~diam/ruby/online/ruby-doc-stdlib/libdoc/mkmf/rdoc/index.html
                      Jim
                      @thomthom said:
                      Dunno. I'd think it'd be possible. But I really have no clue when it comes to compiling. It'd be nice to have tutorials for different compilers. So please feel free to jump on the bandwagon )
                      I could not get MinGW working using Ruby 1.8.6. I could get the examples to compile using Ruby 1.9.3, but they just crashed SketchUp.
                      But both example seem to compile and work just fine in SketchUp using VC++ Express and Ruby 1.8.6 per your instructions in the Readme file.
                        Dan Rathbun
                        Ruby v1.8.6-p287 was the last 'distro' to be compiled with MSVC. (.. which is likely why the GSUDT released SU8 with this patch level, even though their were newer v1.8.6 patch levels available.)
                        All patch levels above p287 were distro'd (via Windows One-Click Installer,) compiled with MinGW.
                        That is not to say, however that someone (including Google,) could build the newer patch levels with MSVC, or do a manual install by downloading precompiled binaries from:
                        ftp;//ftp.ruby-lang.org/pub/ruby/binaries/mswin32/
                        (.. However not all patch levels are available.)
                          tomasz
                          Shouldn't the C extension be protected by a sort of a "namespace"? I mean shouldn't Point3d {}; be SX_Ext_Point3D {};? If we have two diffetent DLL's, do their functions exist in a same 'space' πŸ˜„ ?
                            No - only the Ruby modules, classes and methods you define - like in a normal Ruby Script. Everything else is isolated.
                            As you see in the init function:
                            <span class="syntaxdefault"><br />void&nbsp;Init_SX_Basics</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">void&nbsp;</span><span class="syntaxkeyword">)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Modules<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mSUExtTest&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">rb_define_module</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">"SUExtTest"&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Constants<br />&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;>&nbsp;SUExtTest;;SX_BASIC_VERSION<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_const</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SX_BASIC_VERSION"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">rb_str_new2</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">"0.1.0"&nbsp;</span><span class="syntaxkeyword">)&nbsp;);<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Methods<br />&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;>&nbsp;SUExtTest.foo<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"foo"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_foobar</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.multiply(&nbsp;number1,&nbsp;number2&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"multiply"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_multiply</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.pi_array(&nbsp;array&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"pi_array"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_pi_array</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.random_points(&nbsp;size&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"random_points"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_random_points</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.closest_distance(&nbsp;point_set1,&nbsp;point_set2&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"closest_distance"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_closest_distance</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2&nbsp;</span><span class="syntaxkeyword">);<br />}<br />&nbsp;</span><span class="syntaxdefault"></span>
                            It's the rb_define_* that will make the extension share anything with the Ruby environment - everything else is isolated.
                              chyn2000
                              Hi Guys.
                              First, I want to say that this project you have started is awesome. I had just decided I needed a ruby extension to get a speed boost for a plug-in project. I found a lot of tutorials on making extensions, but most were for either linux or for MS Visual Studio 6 on Windows. I'm not using either environment. I am on Windows 7 (64bit).
                              Sooooo, I have followed TBD's example program the best I can.
                              • I have downloaded the SUExt files.
                              • I have downloaded the Ruby Installer and Source per the SUExt readme file and installed Ruby.
                              • I have installed Pelles C.
                              I tried to open suext.ppj file and Pelles C kept throwing an error about "suext.obj is wrongly located in -path_to_project-". So I tried suext6.ppj and it seemed to be fine. It even seemed to build once I pointed Pelles C to where my Ruby installation was at.
                              From here I'm a little lost. Am I done? I brought up the irb and typed in: require 'path_to_project/suext.so'
                              The results were as follows:
                              LoadError: 127: The specified procedure could not be found. - Init_path_to_project\suext
                              path_to_project\suext.so
                              from path_to_project\suext.so
                              from path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
                              from (irb):1
                              What am I missing?
                              -Chyn
                                When you require a C Extension, do not include the file extension.
                                So instead of:
                                do:
                                require 'path_to_project/suext'
                                  chyn2000
                                  Ok. That certainly changed things a little.
                                  I type:
                                  irb(main):002:0> require 'path_to_project\suext'
                                  and get back:
                                  from (irb):2
                                    or
                                      chyn2000
                                      Both. The '/'s and ''s that are in the post were copied and pasted. I didn't change any of them. Let me know if you want the original output. I just shortened the paths for readability.
                                      -Chyn
                                        Jim
                                        TIG means try using this --> / <-- instead of that --> ** <-- in your require statement.
                                          chyn2000
                                          Ah. Gotchya now.
                                          Nirg. Same result...
                                          Anything else? Maybe is one of you guys have successfully built the example you could post it for download. That would make sure I've got my environment set up correctly.
                                          -Chyn
                                            How did you build it? Seems something has gotten confused and the path has gotten mixed into the name of the initializing procedure for the C Extension.
                                            It tries to call a function named Init_path_to_project\suext - where, given the name suext it should be trying to call Init_suext.
                                            • 3 / 9
