[Tutorial] SketchUp Ruby C Extension
Ah. Gotchya now.
Nirg. Same result...
Anything else? Maybe is one of you guys have successfully built the example you could post it for download. That would make sure I've got my environment set up correctly.
-Chyn
How did you build it? Seems something has gotten confused and the path has gotten mixed into the name of the initializing procedure for the C Extension.
@chyn2000 said:
LoadError: 127: The specified procedure could not be found. - Init_path_to_project\suext
It tries to call a function named
Init_path_to_project\suext- where, given the namesuextit should be trying to callInit_suext. -
I built in Pelles C.
So, the path isn't hard coded in the program. I can place a copy of the suext.so on my d:\ and it changes the error out put to match:
irb(main):002:0> require 'D:\suext'
LoadError: 127: The specified procedure could not be found. - Init_D:\suext
D:\suext.so
from D:\suext.so
from d:/Ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
from (irb):2
from :0Is there a specific directory I should have the file at?
%(#BF8000)[path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/**custom_require.rb**]Why are you customizing the
require()method ?Try it WITHOUT loading this custom script...
@dan rathbun said:
Why are you customizing the require() method ?
He isn't - this is something done by RubyGems.
OK.. my bad.. N/M
You did it again.
Use:
require "D:/suext"irb(main);001;0> require 'C;\SX_Basics' LoadError; 127; The specified procedure could not be found. - Init_C;\SX_Basics C;\SX_Basics.so from C;\SX_Basics.so from (irb);1 irb(main);002;0> require 'C;/SX_Basics' => true irb(main);003;0> -
Ok, I just built TBD's suext example using Visual Studio Express 2010.
In order to get the extension to require properly, I had to use:
require "SUExt"<-- note caserequire "suext"failed. -
require "SUExt"<-- note caserequire "suext"failed.Yep Jim. That was exactly it!
Thanks everyone. Let me know if there is anything I can do to help.
Actually, it occurs to me that we may want to start making a small library of math and geometry ruby extensions very targeted towards SU. Thoughts?
-Chyn
Not a bad idea. I had plans of doing some bezier functions.
Maybe wrapping up an existing library for SketchUp/Ruby would be a way to go? Here's some interesting ones:
[1] http://vcg.sourceforge.net/index.php/Main_Page
[2] http://www.cgal.org/
[3] http://ptex.us/
[4] http://code.google.com/p/ruby-sketchup-sdk/
[5] http://www.visilibity.org/ -
I was so excited to discover that someone was building Sketchup extensions with Visual Studio 2010 - that's exactly what I need to do - unfortunately, after going through the whole process, I can't seem to successfully load the SX_HelloWorld module:
require 'SX_HelloWorld' Error; #<LoadError; C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so; 126; The specified module could not be found. - C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so> (eval) (eval);0Notice this is not a situation where the file is missing - that produces a similar but different error message.
After some Googling it seemed like missing .so's are sometimes the culprit, so I tried copying over some from my Ruby build directory (win32ole.so and Win32API.so), but it didn't help. Finally I tried running Sketchup from the VS2010 command line shell - this resulted in the infamous "bugsplat".
I'm at my wit's end here... any ideas?
Thanks,
Jeff
PS: My Ruby install gives RUBY_PLATFORM=i386-mswin32_100, RUBY_VERSION=1.8.6; Sketchup gives RUBY_PLATFORM=i386-mswin32 and the same version -
FYI: When
requireloads a shared object library file (and not a ruby script,)
therequire(filepath)method looks for a C function named:
"Init_" + File.basename( filepath, File.extname(filepath) )
and runs it after loading the shared library.This means that named C function must exist (even if it does nothing,) and must be named exactly as the file is named (CASE SENSITIVE.) If an enduser renames the so (or dll, dylib, etc.,) file later (including changing the case of any characters,) then loading the library file with
require()will fail. (usually resulting in a "entry point not found" error.) -
Thanks for the quick response! Unfortunately, I don't think that's the issue, for three reasons:
- The error message is "The specified module could not be found", rather than "entry point not found"
- I'm using the example file from bitbucket unchanged... the name of the relevant function there is "Init_SX_HelloWorld", vs filename "SX_HelloWorld.so"
- I can use this module OK in Ruby standalone (whichever one I built with)
I do think it's got to be something simple... I just can't see what it might be. The error message isn't terribly helpful
BTW your on Windows 7 ??
Is the path:
%(#BF0080)["C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so"]and what is the result of (at the console):
puts $LOAD_PATH -
That's right, Windows 7 Professional SP1
Is the path:
%(#BF0080)["C:/Program Files(x86)/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so"]No, it's "C:/Program Files/Google/Google Sketchup 8/Plugins/SX_HelloWorld.so" (no "(x86)")
puts $LOAD_PATHputs $LOAD_PATH C;/Program Files/Google/Google SketchUp 8/Plugins C;/Program Files/Google/Google SketchUp 8/Tools nilThanks!
Hm... it works in IRB, but not SketchUp?
Exactly what version of Ruby did you use to build the extension?
Also - did you remember to modify theconfig.hfile as described in the README? -
The error you report is mentioned in this article: http://apocryph.org/2007/06/16/totally_bullshit_ruby_extension_experience_windows/
However, I did not experience such error... not really sure what the difference is here...
Is the path:
So (just to be clear:
1) You installed the 32bit version of Windows 7 ??
2) Are you running Sketchup with the Google supplied "msvcrt-ruby18.DLL" (which is v1.8.6-p287,) or did you replace the "msvcrt-ruby18.DLL" library file in the Sketchup program dir, with the one that you built ??
.. and did you try:
require('SX_HelloWorld.so')
(ie, specifying the extension, which should skip the search for a "SX_HelloWorld.rb" file.)
