    Round edges
    14 Posts 6 Posters 988 Views 6 Watching
      Do you have Artisan or Subdivide and Smooth?
      • Jean LemireJ
        Jean Lemire
        Hi folks.
        A few tricks:
        1 - Size of the model
        After seeing the dimensions shown I suspect that some edges in this model may end up smaller than 1 mm or about 1/16 inch in length. This will create open faces. The solution is to draw larger than real life and then to scale down when done. Use a factor of 10 or even 100.
        2 - Symmetry of the model
        Since this model has a twofold and maybe a fourfold symmetry, you can probably create only one half or one quarter of it and obtain the other half or quarters by copying and flipping the already done half or quarter.
        3 - Using the Sand Box From Contours tool (SBFC)
        Using the abomentionned tool, I got a decent looking model. I had to flip a few edges after using the SBFC tool.
        Just ideas.
        • C
          costan83
          this is what i got
          how can i fix it?
          phone.skp
          • C
            costan83
            yes it worked perfectly
            thanks!
            edit:there's an error
            • Alan FraserA
              Alan Fraser
              Turn on Hidden geometry and erase all the bad geometry that lies between the outermost edge of the phone and the outermost lozenge shape (all the other, more inner faces look fine). Pay special attention to getting rid of any long edges that are running along the long axis of the phone. You'll then need to manually stitch all of the segments on the outer corners to the edges of the lozenge. No nodes on the outer edge should be connected to any others...all the connections ought to be between the outer edge and the lozenge...the shorter the better.
              3D Figures
              • jeff hammondJ
                these old-timer methods are going to drive you berserk *
                see this thread for some other ideas:
                http://forums.sketchucation.com/viewtopic.php?p=332971#p332971
                [*the old-timer/purist thing is a joke πŸ˜„ .. of course you should know how to do this stuff vanilla style as well]
                  An even more purist method than Jeff's πŸ˜‰
                  404 Not Found
                  (forums.sketchucation.com)
                  • Alan FraserA
                    Alan Fraser
                    Old Timer or not, I did actually try Curviloft...it was no better than autofold. Sometimes you just need to get in there and get your hands dirty. πŸ˜„
                    3D Figures
                    • gillesG
                      gilles
                      here is my attempt with Curviloft.
                      STEP BY STEP
                      • C
                        costan83
                        thanks..gilles method is perfect for my work
                        thanks to all again πŸ˜„
