    Tips and tricks for post rendering
    22 Posts 18 Posters 2.1k Views 18 Watching
      mwm5053
      I would definitely be interested great idea. I've been wanting to get into post-pro for sometime now but not sure how to.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • soloS
        I'd love a tutorial on post processing as I suck at it, hence I spend more time modeling, texturing and populating scenes so I have less post work to do.
        The only problem is I use Paintshop X4 and all the cool tutorials around are Photoshop πŸ˜•
        • unigamiU
          unigami
          Great idea - I'm definitely interested!
          • V
            Vicspa
            count me in since I do a lot of post pro
            • W
              wyatt
              Yes, please. πŸ‘
              • boofredlayB
                boofredlay
                • eidam655E
                  eidam655
                  also a +1 from me, the struggle for the best modeling/post-pro balance is neverending πŸ˜„
                  I'm using SketchUp 2017, V-Ray 3.4
                    sepo
                    • bazB
                      baz
                      • dazzaD
                        dazza
                        Yes please, great idea!
                        All people have the right to stupidity but some abuse the privilege.
                          davidh
                          OK,here are 2 more tips,still in the winter theme.The first is making plants look icy/frosty.
                          FROST COVERED PLANTS:
                          1.open green plant and duplicate layer
                          2.desaturate the copied layer
                          3.Increase curves(see seting on jpg attached).This results in an almost white image.
                          4.selectively erase the copied white image from the bottom up.
                          BLENDING LARGE AREAS OF FOREGROUND:
                          The first image shows a screensnap of a recent project.What is missing is the main snow foreground.
                          1.Find a source image with the correct/similar lighting.
                          2.select the part you want -but use a feathering of 20-25 in the selection so the edges are blurred.You can see in the middle image that there are elements projecting up but these can easily be hidden with vegetation.Then start copying the layer around,again selectively erasing.
                          The main thing to understand with adding large areas of foreground is to feather/blur the edges.It isnt any more complicated than that.
                          I will upload a new one later showing how I add individual parts of snow,such as is on the lower wall in this image.I can promise you it wont be complicated.
                            john.warburton
                            Go for it - would suit me!
                            Life's a reach, and then you gybe.
                            • utilerU
                              utiler
                              And me too.... πŸ‘
                              What else do you need now Rich? πŸ˜‰
                              Just Curious...
                                Money
                                  MartinK
                                  πŸ‘ πŸ‘
                                  • marked001M
                                    marked001
                                    +10 from me.... i def need to up my post processing game! thanks David.
                                    http://www.revision21vis.com
                                    instagram: revi21on
                                      davidh
                                      This is how I add snow to walls buildings etc.:
                                      1.select a piece of snow that matches your image
                                      2.select the outline and copy
                                      3.paste - then distort,scale to fit the scene
                                      4.add a layer mask- use a gradient light to dark from top downwards-this will help melt the snow onto the wall.depending on which way the sun is shining,you can add additional layer masks to show the snow melting in the light,and more solid in the shade.
                                      As I said,this is not complicated,
                                      but I would also add,surely there is someone else out there that has some other post-processing ideas.
                                        Here you go.
                                        http://forums.sketchucation.com/viewforum.php?f=351
                                        If you're posting a tutorial please use the tutorial tag [Tutorial]
                                        • GaieusG
                                          This is also Rich' virgin forum so easy with him! πŸ˜„
