License Server
We are having issues with the license server. Does anyone know if this is somethign that's buggy? I am running the license server on my workstation and we have 2 other computers that we would like to install VR4S on. Our IT manager is telling me that SketchUp uses a different port everytime it opens so that is making it hard to connect to. Also, he cannot get the license server to start. When I click Start License Server, it opens a DOS window that says 'import site' failed; use -v for traceback.
How are you starting the license server? I got instructions that the license server needs starting with some special commands in order for it to start correctly.
Here's the bat file I got running on our server - per instructions of ASGVis support:
<span class="syntaxdefault"><br /></span><span class="syntaxkeyword">@ECHO </span><span class="syntaxdefault">OFF<br />set license_folder</span><span class="syntaxkeyword">=%</span><span class="syntaxdefault">ALLUSERSPROFILE</span><span class="syntaxkeyword">%</span><span class="syntaxdefault">Application DataASGVISLicensing<br /></span><span class="syntaxkeyword">if </span><span class="syntaxdefault">NOT </span><span class="syntaxstring">"%PROGRAMDATA%" </span><span class="syntaxkeyword">== </span><span class="syntaxstring">"" </span><span class="syntaxdefault">set license_folder</span><span class="syntaxkeyword">=%</span><span class="syntaxdefault">PROGRAMDATA</span><span class="syntaxkeyword">%</span><span class="syntaxdefault">ASGVISLicensing<br /><br /><br />set VRAY_AUTH_CLIENT_FILE_PATH</span><span class="syntaxkeyword">=%</span><span class="syntaxdefault">license_folder</span><span class="syntaxkeyword">%<br /></span><span class="syntaxdefault">set VRAY_AUTH_SERVER_FILE_PATH</span><span class="syntaxkeyword">=%</span><span class="syntaxdefault">license_folder</span><span class="syntaxkeyword">%<br /><br />@ECHO </span><span class="syntaxdefault">ON<br /></span><span class="syntaxstring">"%LICENSE_FOLDER%\vrlserver2.exe"<br /> </span><span class="syntaxdefault"></span> -
As for the port - you probably want to contact support for that.
run that bat on the workstation that is running the license server?
Correct. We have to direct the license server to the folder where the licenses are, this bat file does exactly that.
