    Curved Railing
    17 Posts 7 Posters 4.2k Views 7 Watching
    • pmolsonP
      pmolson
      My favorite tool for curved railing is this plug in.
      404 Not Found
      (forums.sketchucation.com)
      it is the follow me and keep plugin.
      very easy to use.
      p
      • G
        gidominik
        404 Not Found
        very easy to use.
        p
        Thanks P...I like that plug in too. But I need that railing to follow the curve. See the SKP attachment..Thanks
          I'll try to make an example for you when I have some time. Paying projects have to come first as I'm sure you understand.
            mac1
            @gidominik said:
            404 Not Found
            very easy to use.
            p
            Have not tried to make the railing yet but some observations for your consideration.
            The railing has a very high number of groups make from the same entity. You have a possible large model and need to consider how to keep the model size down as you model or you will have some down stream problems with "slowness'. One way to help is to use components as much as you can. Suggest you watch the youtube tuts on that subject and factor that into your model while you have this " early" chance.
            Just some thoughts
            • oganocaliO
              oganocali
              For this, Tgi3D's latest released terrain tools can be useful. See topic http://forums.sketchucation.com/viewtopic.php?f=323&t=41062&p=363876&hilit=tgi3d#p363876. Training version and/or 30 day trial is free.
              You need to follow mac1's advice too. Make a component from the repetitive blocks of the railing. First draw the railing on flat ground. ( I used Chris Fulmer's component stringer on the small block with the projection of the railing path to the ground plane. The path is also resampled at regular intervals matching component width). Then I drew a surface using channel extrude (you could use follow and keep as well I suppose) and I set that surface as the mapping target. Finally I used map to terrain on the railing using affine mode. The nice thing here is that the component hierarchy is preserved, i.e you can further edit the block component and it will be reflected to the whole of the design (check the attached skp file).
              stairs7_edit.skp
              • G
                gidominik
                @mac1 said:
                @gidominik said:
                404 Not Found
                very easy to use.
                p
                Just some thoughts
                Thank you Mac1
                I didn't realize that I had some hidden groups till you mentioned about it. I did watched some tuts in youtube with some are very informative and useful too in a simple manner.Thank you for your thoughts
                • G
                  gidominik
                  [attachment=1:3emp8abb]<!-- ia1 -->stairs.jpg<!-- ia1 -->[/attachment:3emp8abb]
                  Hi Oganconali, This is beautiful.. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜ฎ ๐Ÿ˜ฎ amazing..Thank you so much, for your time. Consider this is done, I still need to do few tweaks to match the design.
                  • gillesG
                    gilles
                    TIG extrusion tools
                    CF shape bender
                    follow-me
                    some_work.rb
                    You should really decrease the amount of segments of arcs and radius and use components as often as possible ( my model is only 440 KiB and could be reduce).
                    Just for the pleasure.
                    STAIR.skp
                    • G
                      gidominik
                      Thank you guys for being so kind and generous. I really appreciate your time and effort. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ’ญ ๐Ÿ’ญ ๐Ÿ’ญ
                      • G
                        gidominik
                        @gilles said:
                        TIG extrusion tools
                        CF shape bender
                        follow-me
                        some_work.rb
                        Thanks Gilles..hats off man... ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ’ญ
