    [Plugin] DXF_export v0.0.4 (2011-10-28)
    54 Posts 22 Posters 103.0k Views 22 Watching
      Dubman1013
      I imported this plug-in, when I select the items & export, it does not give me any file types to choose from, no DXF. Is there something I'm missing or is there another plugin to make this work? Thanks for any advice!
      I just downloaded the new version, but it still does not give the dxf file type to save as. Any suggestion ?
        joergber
        @Dubman1013
        There is no filetype to choose from!
        The Plugin takes the current skp-filename and exchanges '.skp' with '.dxf' thats all!
        (For unsaved models the default filename is 'Untitled.dxf')
        Just click 'Export to DXF' then choose the folder to save to and save the dxf.
        Before saving you may change the filename to your needs!
        (But don't forget '.dxf' at the end of the filename)
        Have a nice day!
        Jörg
        • G
          Gumleguf
          Thanks for a great plugin! I just sent a .dxf file to a friend and he could open it perfectly in SolidWorks. Next step is to CNC the part. 😍
          Edit: One thing. My friend just mentioned that when he opened the .dxf in SolidWorks it was in Inches even though I made it in mm. He could just change to mm, but still...
            joergber
            Hi!
            Gumleguf:
            I can not reproduce here ...
            The only thing I could imagine is that you disabled the
            'Display units format' setting (Window->Model Info->Units) but then there should have been a messagebox saying "Unable to detect the actual unit setting ...\nGenerate Output in inch?" and the whole DXF would have been 'inverted' because the units calculation factor is -1 in this case ...
            (will be fixed in next release! 😳 )
            Pls. let me know if the problem persists!
            And maybe you do have a screenshot that could help or the .skp file of your model ... ... ... 😄
            Anyway, thank you very much for the feedback 👍
            ❓ More than 120 downloads and just this few problems/bugs/featurerequests/... 😄
            Enjoy,
            Jörg
            • G
              Gumleguf
              You are welcome, and thank you (!) for the plugin! 😄
              Here is an example of a sketchup that he says opens in Inches:
              GMaxx_bagplade1_1.skp
                joergber
                Wohooo, that was fast 😲
                I exported without any problems ...
                dxf opened in HEEKSCNC
                Here is my output ...
                unitsFactorProblem.dxf
                Could you pls. send this file to your friend to doublecheck?
                Could you pls. check the setting and try again?
                ❓ If you select the measure tool in SU ...
                is the length displayed like '371,25mm'?
                Thank you!
                Cheers
                Jörg
                • utilerU
                  utiler
                  Hi joergber,
                  Can you explain how this plugin differs to a standard SU export?
                  Just Curious...
                    joergber
                    utiler:
                    It might not have come out clearly ...
                    I'm using SU 8 free (just updated my profile 😳 )
                    And the standard dxf-exporter is for pros only ( as far as I know )
                    So ...
                    I don't know how it differs to standard SU export 😕
                    Is there a specific reason why you are asking?
                    Respects
                    Jörg
                    • utilerU
                      utiler
                      Only that I'm using PRO and wanted to know the difference; that's all....
                      thanks for the explain! 👍
                      Just Curious...
                        marcomartim
                        I also need DXF for CNC milling.
                        @joergber said:
                        I did this because I use the DXF with heekscnc to generate milling operations (G-Code).
                        Milling a circle or an arc is much faster than several lines ...
                        Thanks for the plugin!
                        I also use SketchUp to create files for CNC cutting.
                        There is an excellent plugin to do the right Gcode in Sketchup, Phlatscript (SketchUcam)
                        For more information, visit the site:
                        http://www.phlatforum.com/
                        http://forums.sketchucation.com/viewtopic.php?f=15&t=38150&p=337062&hilit=phlatscript#p337062
                        Hugs
                        • dereiD
                          derei
                          I just found a bug in the program. As seen in image below, the unit format is disabled (to not show it in dimension lines). But, the exporter doesn't recognize the units that I used and wants to export by default in inch. My suggestion: if there is a program limitation for this situation, to replace the YES/NO message box with a list box with all units available. So, if the exporter doesn't recognize the units, to let the user choose.
                          Another thing... I selected only the contour lines from a 3d object (the lines that formed one face), the exporter reported "one shape",but in DXF I had all lines exported of the solid. Is it possible to export ONLY what is selected? I mention that I was inside a component when I selected the outer shape of the face.
                          One more thing: it would be useful to have the possibility to export in XY plane for all 2D shapes, regardless they are oriented on a different plane.
                          This is the most useful DXF exporter I ever used. Actually, is the only one that is helping me 😄
                          Thank you.
                          DESIGNER AND ARTIST DEREI.UK
                            joergber
                            dereeei:
                            I recognized too that my unit detection was not fool proof and added a listbox ...
                            It seems that we are working on similar tasks ...
                            since I came across the same problems than you.
                            Currently the exporter exports all connected entities of the current selection.
                            So selecting a contour of a object will export the whole thing
                            I am in the process of developing some kind of peprocessing tools ...
                            The first one will be a drop tool where you can select any face of a model and it will be copied to z=0 and rotated to ground plane.
                            But I'm neither familiar with Ruby nor Sketchup toolbars ...
                            So this will take some time 😉
                            Thanks again for your feedback!
                            We read!
                            Jörg
                            • dereiD
                              derei
                              @joergber
                              Why don't you simply use selected entities to build the dxf? Is more simpler for start... You can iterate trough all selected and check what are they. If there are edges only, use them to build a dxf. If there are also faces, add to dxf the edges that build that face.
                              Because selecting a face is simple by double clicking. Usually a tool that selects a face, will select only a planar face, not a curved one (like a cylinder). To select that, I think you have to take into consideration the edge smoothing angle. So, I'm guessing that double click on a smooth face is pretty fast to not require a select tool (for now, at least).
                              Thanks for still working on it 😄
                              • G
                                Gumleguf
                                Sorry for the late reply.
                                No, I haven't disabled "Display units format" and it still opens in inches:
                                • G
                                  Gumleguf
                                  Hi Jörg,
                                  Maybe I'm doing something wrong but here's one problem I have.
                                  1. I create a 100mm x 100mm rectangle with some random circles, see attached file "Untitled.skp".
                                  2. Using your fine tool I export it as "Untitled.dxf".
                                  3. To print out my drawing I open the .dxf file in eDrawings (from Solidworks, version 12.2.0.110) and press the print button. I then see a windows where the drawing is scaled to 1:18.3926?
                                  4. If I change the "Active sheet" setting "To scale (1 to 1)" the result is that the drawing get's massive big - you can only just see a small corner of a circle on an A4 sized paper.
                                  Isn't that strange? And by the way, if I print out from step 3 the actual rectangle on paper is something like 137mm x 137mm and not 100mm x 100mm.
                                  /Greg
                                  Untitled.skp
                                  Untitled.dxf
                                  • C
                                    cgprosjekt
                                    Hello Jörg!
                                    Just wanted to thank you for a wonderful plugin. We have struggeled alot with exporting .dxf files with true circle to our CNC machine software. And yours works perfect so far.
                                    You really made my day! Thanks
                                    br
                                    Lars
                                    • P
                                      pumplerod
                                      Sorry, I must be missing something. Does this .rb file install into:
                                      "/Applications/Google\ SketchUp\ 8/SketchUp.app/Contents/Plugins/"
                                      Doing this doesn't seem to work for me. Is there another plugins directory that SketchUp 8 uses?
                                        You have it all wrong 😒
                                        There are many helpful posts on the forum - including how to install 'plugins'...
                                        Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
                                        On a MAC this folder is the one and only location for such scripts.
                                        They'll auto-load from there, and the tool's activation/menu/usage/etc is then as indicated in each tool's notes...
                                          sli21
                                          hi all
                                          i'm a newbie so hi to all!
                                          im trying to export the side view of a 400mm*700mm egg shape component as a dxf. when i load it up in VCarvePro instead of getting the full view i just get the 400mm wide top view. what am i doing wrong - cheers
                                          Scott
                                          • G
                                            Gumleguf
                                            Hi Scott,
                                            Perhaps your shape is too advanced for the DXF_export tool to handle or there are errors in your drawing.
                                            Try to upload your Sketchup model here and perhaps someone with a Sketchup Pro version could try to export it to dxf. If it also fails your drawing is bad, if it works the DXF_export tool doesn't support your model.
                                            /Greg
                                            • 2 / 3
