    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 186.0k Views 79 Watching
      @sir.swaffel said:
      I like this tool, but it is lacking a basic feature that 1001bit's version does have: a reference point.
      FollowMeAndKeep automatically uses the center of the face that it wants to extrude as the reference point for the path. When using a more complex face that needs to be extruded along a path relative to let's say the bottom left corner, you're out of luck πŸ˜•
      It's good to have the option of using 1001bit, isn't it?
        Sir.Swaffel
        haha, yes, unfortunately 1001bit lacks a feature that FollowMeAndKeep does have, it doesn't lock the z orientation. So basically both of them lacks an essential feature of the other... and I don't know a way to combine them πŸ˜„.
        comparison
          I suppose for FaK you could add some temporary geometry to get the bottom left corner to be the center. Not idea but it could work.
          • W Offline
            wikii
            Reference point?
            select a cpoint ,curve and face,then run fak.
            the cpoint will be treat as reference poing.
            try it.
            wikii
              Sir.Swaffel
              ah thanks, it never worked when I tried it, so I thought it was broken. But apparently my SU has some trouble making correct faces with FAK and complex curves and precise helixes. Got it working now though, so thx πŸ˜„.
              • dereiD Offline
                derei
                I'm trying to run FAK on a face + path but it doesn't o anything.
                Can anyone point me where I'm wrong? I tried with a simpler shape (arc + rectangle) and it worked. Is it something wrong with this particular model?
                Model attached. Thank you.
                no_FAK.skp
                DESIGNER AND ARTIST DEREI.UK
                  The extrude edges familly by Tig must make the trick πŸ˜‰
                  • gillesG Offline
                    gilles
                    @ dereei, rotate the whole model so the face isn't horizontal and it works.
                    I suggest to separate your path in two parts to avoid strange results.
                      destroyer1095
                      ITS NOT WORKING FOR SKETCH UP 8!!!!! 😑 πŸ‘Ž
                        Yes it is - and please, do not use ALL CAPS on the forums.
                        A "not working" remark will never help trouble shooting what you are doing wrong. First of all, did you install it correctly?
                        • dereiD Offline
                          derei
                          is working ! read the previous post! I'm sure you used a path that was vertically aligned.
                            How ironic is his nickname...? πŸ˜’
                              Nice entrance to the forum. πŸ˜’
                                MartinK
                                ASS
                                  JMdesigns
                                  cant get this to work sor SU8 ?...any updates
                                    Works fine on SU8 for me.
                                    If you want help, why not help us help you and give us some information about what's happening? Post an example SKP or something. πŸ˜’
                                      jjshannon
                                      Greeting. This is my first post here. I have been trying to model a roller coaster type object and the "follow me" tool in sketchup was twisting my shape. I think found the "follow me and keep" tool here which is great. My only problem now is that my shape is not symetrical and the follow me and keep tool is flipping my shape as it makes turns. It is one shape I am extruding by somehow it doesn't quite work. I tried this shape with the native follow me in sketchup and it does maintain the general shape but, as mentioned before it twists the shape. Is there something I am doing wrong, or is there any way to fix this? I have attached my sketchup file.
                                      rollar coaster test 2.skp
                                        blajnov
                                        All works, simply draw again a structure...
                                          tspco
                                          I hate drawing railings on staircases, that said this plugin works fine, but it would be better if it didn't have auto-smoothing, or an option that would allow the user to turn it off. I have to explode the group the plugin created to make the railing look right. I also have to add lines between segments of railing, to make the railing look sharper. Any thoughts?
                                          SU make 2017, /Twilight Render Hobby
                                          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                            I have just one thought. Well, two but one of them isn't related. πŸ˜›
                                            Open the railing group for editing and then select all of the geometry. Right click Smooth/Soften and adjust the slider down slightly. That should give you the lines you're looking for at the turns.
                                            • 11
                                            • 12
                                            • 11 / 12
