    Does anyone have...
    59 Posts 11 Posters 4.5k Views 11 Watching
    • jeff hammondJ
      So the square of Jeff 12" must be 30.5 cm or 30.48 cm ? ๐Ÿ˜’
      any way we call it, that's still an awful lot of cardboard! ๐Ÿ˜„
        Quasi like yours ๐Ÿ’š
        By Studio Lazerian
        http://www.orgone-design.com/blog/wp-content/uploads/2010/05/Lazerian_Studio-Fauteuil_en_carton-1.jpg
        http://www.orgone-design.com/blog/wp-content/uploads/2010/05/Lazerian_Studio-Fauteuil_en_carton-2.jpg
        http://www.orgone-design.com/blog/wp-content/uploads/2010/05/Lazerian_Studio-Fauteuil_en_carton-3.jpg
          d12dozr
          i guess you could say that ๐Ÿ˜„
          Ha...Nice, that makes sense because its so hard to reliably make something like that in SU that corresponds to real-world requirements
          http://goo.gl/f7ooYh
          • X
            xrok1
            @tig said:
            Did you make the model out of Slicer cuts or ModelSlicer ?
            I have a project on the backburner to make a Slicer+Slotter using components in the assembled set and flattened... ๐Ÿ˜•
            can't wait for that ๐Ÿ˜
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
              As I said it's on the "backburner" - it's item #9 today - but it was #8 last week !
              ๐Ÿ˜’
              • X
                xrok1
                ๐Ÿ˜• I'm still excited. I can wait u out. ๐Ÿ˜†
                • utilerU
                  utiler
                  for skateboarding ... of course!... why waste it by putting water in there? ๐Ÿ˜„
                  I don't think you have a choice, Jeff. Doesn't it ever rain in NYC...?
                  Beaut model though!!
                  Just Curious...
                  • jeff hammondJ
                    I rarely work in the city.. I just live here then fly out to build.
                    regardless, I generally build inside..
                    If outside, I use other surface materials & p.t. framing but nothing beats using the european plywood for the final layer. great material to work with (very strong/durable yet still pliable/workable) and the surface is super good for riding on. (fast/smooth with just the right amount of tack)
                      Seems for you at little scale ๐Ÿ˜‰
                      123D MAKE
                      [flash=560,315:3e5fvyrn]http://www.youtube.com/v/hBHxFGXI7nQ[/flash:3e5fvyrn]
                        PS Only for Mac! ๐Ÿ˜‰ ๐Ÿ˜ข
                        But in SU We have TIG and its Slicer ๐Ÿ˜‰
                        • jeff hammondJ
                          i think it's only for windows actually ๐Ÿ˜‰
                          http://www.123dapp.com/123D
                          Edit -- oh wait.. 123D Make is a different app and it is mac only.. weird.
                          http://www.123dapp.com/make
                            I took my infos directly from to Todesk! ๐Ÿ’š
                            • jeff hammondJ
                              ha! pretty neat..
                              here's the pdf output:
                              kidKnee_reducedsize.pdf
                              and a screenshot:
                              click pic -> bigger
                                Original model was SU or Rhino?
                                Seems perfect for prototype! ๐Ÿ‘
                                Any idea of time for the process till the edition to the PDF file ?
                                Next : in what material you want to make it ?
                                • X
                                  xrok1
                                  SWEET! ๐Ÿ˜ฎ
                                  was it easy to get your sketchup model inti make?
                                  • jeff hammondJ
                                    print it onto paper then cut it out yourself! ๐Ÿ˜„
                                    or, take the pdf or eps file to your local laser cutting service (there are a bunch of those nearby.. not sure if they're easy to find in smaller cities)
                                    if you send the file off then have the kit mailed back to you, i'm not sure how long it will take..
                                    Next : in what material you want make it ?
                                    i want to make it full size out of wood ๐Ÿ˜„
                                    that said, i might take my computer or file to the guy down the street to get a $quote.. i'm curious now.
                                    kidknee2_reducedfilesize.pdf
                                    • jeff hammondJ
                                      @xrok1 said:
                                      SWEET! ๐Ÿ˜ฎ
                                      took me a while to find a format that will import but eventually tried .obj and it worked fine..
                                      curiously, dwg or dxf weren't acceptable formats ๐Ÿ˜„
                                      • X
                                        xrok1
                                        thats neat. did u send it as a solid? or as a matrix like you showed your SU model earlier? I would imagine a solid.
                                        • jeff hammondJ
                                          yeah, just a single outer shell.. (sketchup solid)
                                          I'll try some other non-solid exports later to see what happens
                                          • X
                                            xrok1
                                            Thanks for the info Jeff. I look forward to seeing your other exports too. ๐Ÿ‘
                                            • 2 / 3
