    CPoints at Bounding Box corners?
    15 Posts 3 Posters 642 Views 3 Watching
      Is there a CPoints at Bounding Box corners plugin?
        hmm... not sure... a two step would be to use my Bounding box plugin and then run xLine on it.
        • TIGT Online
          This one liner does it, adding the 8 cpoints to the corners of the bounding-box of any selection
          m=Sketchup.active_model;b=Geom;;BoundingBox.new;m.selection.each{|e|b.add(e.bounds)};8.times{|i|m.active_entities.add_cpoint(b.corner(i))}
          It could probably do with some trapping etc... but you get the idea ?
            Not really πŸ˜•
            • TIGT Online
              If you read the code it gets the bounds of the selection and adds cpoints at the bounds corners - that's all you need to know πŸ˜•
              Select some geometry and copy/paste the code into the Ruby Console to see what it does...
                Doesn't take into account groups / components that are not aligned to the model axis.
                  I realise how to use it. It's was the trapping comment that had me puzzled.
                  Thanks anyway. Both of ye πŸ‘
                  • TIGT Online
                    It does... in that it returns the bounds of the selection, and NOT individual objects within the selection, and a selection's bounding-box is always parallel to the axes irrespective of the selected objects' transformation... πŸ˜•
                    Rich didn't ask for cpoints at the corners of one selected object's bounds.
                    I gave him cpoints at the corners of the selection's bounds - which might not be the same thing for rotated individual groups/instances...
                      Being able to select a series of groups and components then it places cpoints at all bounding boxes would be sweet.
                      • TIGT Online
                        Try this
                        m=Sketchup.active_model;m.start_operation("BBcpts");m.selection.each{|e|next unless e.class==Sketchup;;Group or e.class==Sketchup;;ComponentInstance;t=e.transformation;e=e.definition if e.class==Sketchup;;ComponentInstance;b=Geom;;BoundingBox.new;e.entities.each{|a|b.add(a.bounds)};8.times{|i|m.active_entities.add_cpoint(b.corner(i).transform(t))}};m.commit_operation
                        adds cpoints at the 8 corners of each selected group/instance's bbox, accounting for transformations... One step undoable.
                          Is getting these control point within the group/component possible?
                          It's anchors for alignment that I'm looking for. If it's too much hassle forget it.
                          On a layer would be kinda cool too πŸ˜•
                          • TIGT Online
                            I originally has them inside each container but [foolishly] assumed you wanted them outside!
                            m=Sketchup.active_model;m.start_operation("BBcpts");m.selection.each{|e|next unless e.class==Sketchup;;Group or e.class==Sketchup;;ComponentInstance;e=e.definition if e.class==Sketchup;;ComponentInstance;b=Geom;;BoundingBox.new;e.entities.each{|a|b.add(a.bounds)};8.times{|i|e.entities.add_cpoint(b.corner(i)).layer=m.layers.add("BBCP")}};m.commit_operation
                            This version puts the cpoints within each container and uses layer 'BBCP' for them.
                              Can i put it in a class then a def and load it to plugins?
                              Or is it a module?
                              Actually forget it πŸ˜’
                                Sorry, Thanks TIG πŸ‘
                                • TIGT Online
                                  module ROB
                                  menu=UI.menu("Plugins").add_item("BBcpts"){self.bbcpts()}unless file_loaded?(File.basename(__FILE__))
                                  file_loaded(File.basename(__FILE__))
                                  def self.bbcpts()
                                  ### paste the main code here...
                                  Copy/paste the code into a file in the Plugins folder called ROB-bbcpts.rb
                                  Usage: type ROB.bbcpts OR pick "BBcpts" off the Plugins menu etc...
