    [Plugin] Chronolux for Sketchup
    39 Posts 24 Posters 45.6k Views 24 Watching
    • K
      kirill2008
      Is there any way it can take transparent materials in account?
      Yes it is possible. It's necessary to set "Handle transparency" flag in "Global Settings" dialog to "Yes". It is also necessary to pay attention to "Transparency threshold" value.
      !["Handle transparency" flag in "Global Settings" dialog.](/uploads/imported_attachments/LgeC_handletransp.png ""Handle transparency" flag in "Global Settings" dialog.")
      This flag is set to "No" by default because it takes a little bit more time to handle transparency so when it's set to "Yes" it slows down script processing.
      • EdsonE
        Edson
        have you tested it on mac? perhaps all one has todo for it to run on mac is to perform a manual installation. if this is the case, could you please instruct us on how to make a manual installation? should I place the whole thing in my plugins folder?
        http://www.mahfuz.arq.br
          driven
          NO...
          the manual installation requires placing different folders in different locations.
          the 'Help' button in tools won't work from inside SU so I suggest you 'first' open the 'Help Pages' in safari to check if you want to instal it.
          to do this 'unzip' Chronolux 1_0 beta.zip and you'll have a new folder Chronolux 1_0 beta,
          follow the path to Chronolux 1_0 beta/Resources/en-US/chronolux/index.html and double click to open in Safari.
          If you still want to instal manually he's a pic of the paths...
          the main files go here
          Support files go here
          I haven't tested the whole thing yet, but you do need to turn on the toolbar in 'View' >> 'Tool Palates'
          • EdsonE
            Edson
            thanks, john. it seems easy enough o install. I will give it a try soon.
              mirale999
              Wonderful thing! This is a good plugin for me to decide the shape of a building intuitively πŸ˜†
              "Test face results presenting" can give us one more choice: Pseudo-color map, like that in ecotect,
              and in qpik's plugin: simple rays, the ray casting is more even and smooth. I think with this great plugin, we can get rid of the ecotect! haha~
              paranoia is a higher form of awareness...
              • K
                kirill2008
                Well, actually solar radiation studies is not the only merit of ecotect πŸ˜‰ but thanks anyway πŸ˜†
                • urgenU
                  urgen
                  ....супСр! πŸ‘ πŸ‘ πŸ‘
                  --pupil forever...------
                  • G
                    georglorenz
                    This is incredible. This is unbelievable awesome. I was amazed by simple rays but now years after. And working with Revit all the time. This is incredible.
                    • G
                      georglorenz
                      Ok this is really interesting and the user interface is just great.
                      I do understand that it calculates the shading from a specific test point but could you elaborate a little bit on the difference between short rays and long rays and what exactly they do?
                      Thank you so much / gxl
                      • G
                        georglorenz
                        Oh and then there are construction points and test points? I understand test points but what are construction points? Thank you / gxl
                        • EarthMoverE
                          EarthMover
                          Kirill, looks amazing. I am also trying to find a sketchup plugin method which will chart sun path and perform a reflection/glare study. I need it for solar panel applications to determine the amount of glare produced based on the angle of the panels per geolocation and it's affect on neighboring buildings in a given radius. I was wondering if something like this could be adapted from the tools you have created here, with a similar raytrace, but charting also a single light bounce for a visual representation? Or, if anyone is aware a software/plugin on the market that will accomplish this?
                          Content Creator at Skapeup
                          • K
                            kirill2008
                            Well it is possible to place construction points using Sketchup "Tape Measure" tool instead of placing test points using Chronolux "Add Test Point..." tool. Then it is possible to select construction points and process all of them at once using "Make Ray Cluster(s)" or "Calculate SVF" commands. So it's just an optional usage scenario.
                            I think it could be more convenient sometimes to use construction points for some reason.
                            Short rays and long rays are only for graphical representation of calculation results. It is possible to adjust their length if it is necessary for drawing layout.
                            Adam, I think, it is possible to implement. I think, I need to read somewhere about how to calculate reflection/glare amount and then think of how to represent calculation results. I suspect, that glare amount depends on direct sunlight duration, but I don't know how exactly. I'm not sure but I guess the other thing, that glare amount depends on, is an angle between sunlight direction and panel plane. In short it is necessary to search for some additional information on this subject.
                            • B
                              boilingsnow
                              Hi,kirill2008
                              Thank you for your wonderful tools.
                              Just as brilliant as your earlier plugins such as ControlPoints...
                              It's sad that most of your earlier plugins dont work in Sketchup 8....Could you please update them? I would pay for these great tools.
                              • K
                                kirill2008
                                Yes, I'm going to update "LSS Toolbar", but I don't know exactly when. I'll try to make it in the coming months.
                                • B
                                  boilingsnow
                                  Glad to hear about this!
                                    DOD3R
                                    Hello Krill,
                                    Can your plug in do this somehow ?
                                    Any plans or info about any of your plug-ins. I am big fan of those.
                                    D.
                                    revit plugin
                                    • K
                                      kirill2008
                                      Hello,
                                      @dod3r said:
                                      Hello Krill,
                                      Unfortunately plug-in can not estimate daylight in Lux. It can only measure time of direct sunlight and sky view factor.
                                      I planned to update LSS Toolbar to make it compatible with Extension Warehouse requirements, but due to significant load at my official work I'm not sure when I'll finally complete this task.
                                      • U
                                        unearthed
                                        DOD3R - have you had a look at this http://sketchucation.com/forums/viewtopic.php?t=21077 - I haven't played with it yet but the images and discussion look very promising.
                                        Growplan - People ∩ Plants ∩ Place
                                        windows 7 64b, 4GB RAM, SU 8.0.16846
                                        Gimp, QGIS, Vectorworks 12, Bricscad 11
                                          DOD3R
                                          Great news. Good luck with your official work and plugins.
                                          • K
                                            kirill2008
                                            Yes I've seen this plugin. I think it might evolve into something really powerful. I didn't test it personally though.
                                            • 2 / 2
