    [Plugin] Chronolux for Sketchup
    38 Posts 23 Posters 43.4k Views 23 Watching
      Panga
      Awesome tools !! Thanks a lot!!
      • PixeroP Offline
        Pixero
        Is there any way it can take transparent materials in account?
        In my tests it acts as if a glass surface is opac.
          kirill2008
          Yes it is possible. It's necessary to set "Handle transparency" flag in "Global Settings" dialog to "Yes". It is also necessary to pay attention to "Transparency threshold" value.
          !["Handle transparency" flag in "Global Settings" dialog.](/uploads/imported_attachments/LgeC_handletransp.png ""Handle transparency" flag in "Global Settings" dialog.")
          This flag is set to "No" by default because it takes a little bit more time to handle transparency so when it's set to "Yes" it slows down script processing.
          • EdsonE Offline
            Edson
            have you tested it on mac? perhaps all one has todo for it to run on mac is to perform a manual installation. if this is the case, could you please instruct us on how to make a manual installation? should I place the whole thing in my plugins folder?
            http://www.mahfuz.arq.br
              driven
              NO...
              the manual installation requires placing different folders in different locations.
              the 'Help' button in tools won't work from inside SU so I suggest you 'first' open the 'Help Pages' in safari to check if you want to instal it.
              to do this 'unzip' Chronolux 1_0 beta.zip and you'll have a new folder Chronolux 1_0 beta,
              follow the path to Chronolux 1_0 beta/Resources/en-US/chronolux/index.html and double click to open in Safari.
              If you still want to instal manually he's a pic of the paths...
              the main files go here
              Support files go here
              I haven't tested the whole thing yet, but you do need to turn on the toolbar in 'View' >> 'Tool Palates'
              • EdsonE Offline
                Edson
                thanks, john. it seems easy enough o install. I will give it a try soon.
                  mirale999
                  Wonderful thing! This is a good plugin for me to decide the shape of a building intuitively πŸ˜†
                  "Test face results presenting" can give us one more choice: Pseudo-color map, like that in ecotect,
                  and in qpik's plugin: simple rays, the ray casting is more even and smooth. I think with this great plugin, we can get rid of the ecotect! haha~
                  paranoia is a higher form of awareness...
                    kirill2008
                    Well, actually solar radiation studies is not the only merit of ecotect πŸ˜‰ but thanks anyway πŸ˜†
                    • urgenU Offline
                      urgen
                      ....супСр! πŸ‘ πŸ‘ πŸ‘
                      --pupil forever...------
                        georglorenz
                        This is incredible. This is unbelievable awesome. I was amazed by simple rays but now years after. And working with Revit all the time. This is incredible.
                          georglorenz
                          Ok this is really interesting and the user interface is just great.
                          I do understand that it calculates the shading from a specific test point but could you elaborate a little bit on the difference between short rays and long rays and what exactly they do?
                          Thank you so much / gxl
                            georglorenz
                            Oh and then there are construction points and test points? I understand test points but what are construction points? Thank you / gxl
                            • EarthMoverE Offline
                              EarthMover
                              Kirill, looks amazing. I am also trying to find a sketchup plugin method which will chart sun path and perform a reflection/glare study. I need it for solar panel applications to determine the amount of glare produced based on the angle of the panels per geolocation and it's affect on neighboring buildings in a given radius. I was wondering if something like this could be adapted from the tools you have created here, with a similar raytrace, but charting also a single light bounce for a visual representation? Or, if anyone is aware a software/plugin on the market that will accomplish this?
                              Content Creator at Skapeup
                                kirill2008
                                Well it is possible to place construction points using Sketchup "Tape Measure" tool instead of placing test points using Chronolux "Add Test Point..." tool. Then it is possible to select construction points and process all of them at once using "Make Ray Cluster(s)" or "Calculate SVF" commands. So it's just an optional usage scenario.
                                I think it could be more convenient sometimes to use construction points for some reason.
                                Short rays and long rays are only for graphical representation of calculation results. It is possible to adjust their length if it is necessary for drawing layout.
                                Adam, I think, it is possible to implement. I think, I need to read somewhere about how to calculate reflection/glare amount and then think of how to represent calculation results. I suspect, that glare amount depends on direct sunlight duration, but I don't know how exactly. I'm not sure but I guess the other thing, that glare amount depends on, is an angle between sunlight direction and panel plane. In short it is necessary to search for some additional information on this subject.
                                  boilingsnow
                                  Hi,kirill2008
                                  Thank you for your wonderful tools.
                                  Just as brilliant as your earlier plugins such as ControlPoints...
                                  It's sad that most of your earlier plugins dont work in Sketchup 8....Could you please update them? I would pay for these great tools.
                                    kirill2008
                                    Yes, I'm going to update "LSS Toolbar", but I don't know exactly when. I'll try to make it in the coming months.
                                      boilingsnow
                                      Glad to hear about this!
                                        DOD3R
                                        Hello Krill,
                                        Can your plug in do this somehow ?
                                        Any plans or info about any of your plug-ins. I am big fan of those.
                                        D.
                                        revit plugin
                                          kirill2008
                                          Hello,
                                          @dod3r said:
                                          Hello Krill,
                                          Unfortunately plug-in can not estimate daylight in Lux. It can only measure time of direct sunlight and sky view factor.
                                          I planned to update LSS Toolbar to make it compatible with Extension Warehouse requirements, but due to significant load at my official work I'm not sure when I'll finally complete this task.
                                          • U Offline
                                            unearthed
                                            DOD3R - have you had a look at this http://sketchucation.com/forums/viewtopic.php?t=21077 - I haven't played with it yet but the images and discussion look very promising.
                                            Growplan - People ∩ Plants ∩ Place
                                            windows 7 64b, 4GB RAM, SU 8.0.16846
                                            Gimp, QGIS, Vectorworks 12, Bricscad 11
                                            • 2 / 2
