    [Plugin] DXF_export v0.0.4 (2011-10-28)
    54 Posts 22 Posters 99.2k Views 22 Watching
    • dereiD Offline
      derei
      Thanks a lot for this plugin!
      I tested it and it seems to have some bugs as follows:
      -it explodes everything in model.
      -it doesn't export faces.
      -some arcs are oriented wrongfully. - funny fact is that the built-in SU8-PRO exporter does the same.
      -it behaves differently if everything in model is selected, or if nothing is selected.
      -what DXF version does it export? (most milling software need DXF2000)
      I also need DXF for CNC milling. I posted some request here: http://forums.sketchucation.com/viewtopic.php?f=323&t=40311&p=357180&hilit=batch+dxf#p356582 . Maybe your plugin can be tweaked to batch export each Component Definition(/group?) in a different file, on same folder, using Definition's name?
      Beloy you have:
      -resulted (exploded) SKP file
      -DXF from ALL SELECTED
      -DXF from NONE SELECTED (it asked to export entire model)
      -Image from NC HOPS (software for CNC Milling) which shows the wrongfully oriented arc.
      Sektchup2dxf.skp
      Selected ALL.dxf
      Nothing Selected.dxf
        joergber
        thanks for your comments!
        This is a quick and dirty release ...
        But I couldn't await to release it and see if anyone needs it's functionality.
        About the bugs ...
        Yes! It explodes everything and then it loops through all edges and get's each connected.
        That's the way I try to find 'Objects'.
        I will change it to respect Groups and Components!
        But first I have to get rid of the orentation problem of the arcs!!!!!!
        This plugin does not process any faces (by now 😉 ).
        I know 😢
        If anyone knows a solution ... ... ...
        I didn't know 😄
        Not in my environment (but I changed the script a bit).
        Pls. try again with the next release!
        Ups! I didn't care about any DXFversion!
        Just took the first spec I found.
        But in future I'll use DXF2000!
        dereeei, thanks for all information!
        Stay tuned!
        Jörg
        • dereiD Offline
          derei
          I'm very happy that I could help ! 😄 Indeed, I'm very interested in the development of this script, I'll be glad to test the next releases.
          For now, it doesn't bother me if it doesn't export faces, because for milling purposes, all I need are contours, arcs, circles, correct orientation and Layers (name, color).
          Indeed, respecting components (and groups, but not necessary), it would be a great thing! But take care to not process each instance of a Component Definition, because that would be redundant. Also, as I mentioned in the earlier post, if the content of each component would be saved as separate file in a chosen directory, would be awesome ☀
            joergber
            new Version v0.0.3 available!
            I updated the text and the dl-link in the first post and added something like a version history.
            Still feel free to comment ...
            And use the plugin as often as you can 😄
            Greetings
            Jörg
              blajnov
              @joergber said:
              ...new Version v0.0.3 available!........
              Error persists arc oriented incorrectly.
                joergber
                Hi blajnov,
                can you pls. provide the source .skp file?
                So that I can reproduce here ...
                I have drawn something similar and opened in heekscnc and freeCAD.
                Both seem to be fine!
                Kind regards
                Jörg
                  blajnov
                  @joergber said:
                  Hi blajnov,
                  Kind regards
                  Jörg
                  I opened the exported file in DraftSight.
                  In AutoCAD 2008, similar.
                  And when you export, create a file with no extension dxf
                  Here skp files and dfx
                  Untitled2.dxf
                  test_dfx.skp
                  • BepB Offline
                    Bep
                    My drawing imported exploded and flipped also.
                    I hope you get this fixed.
                    The audit report in Doublecad xt (free) reported:
                    AcDbArc(21). An invalid Normal direction (0 0 -2.54) was found. Validation: Invalid. Replaced by Normalized.
                    AcDbArc(22). An invalid Normal direction (0 0 -2.54) was found. Validation: Invalid. Replaced by Normalized.
                    AcDbArc(23). An invalid Normal direction (0 0 2.54) was found. Validation: Invalid. Replaced by Normalized.
                    AcDbArc(24). An invalid Normal direction (0 0 2.54) was found. Validation: Invalid. Replaced by Normalized.
                    AcDbCircle(25). An invalid Normal direction (0 0 2.54) was found. Validation: Invalid. Replaced by Normalized.
                    AcDbViewportTable(8). An invalid Viewport *Active missing was found. Validation: . Replaced by Created.
                    Audit recovered database.
                    AcDbBlockTableRecord(1D). An invalid BlockBeginId was found. Validation: Invalid. Replaced by Created.
                    AcDbBlockTableRecord(1D). An invalid BlockEndId was found. Validation: Invalid. Replaced by Created.
                    AcDbBlockTableRecord(1B). An invalid BlockBeginId was found. Validation: Invalid. Replaced by Created.
                    AcDbBlockTableRecord(1B). An invalid BlockEndId was found. Validation: Invalid. Replaced by Created.
                    54 objects audited
                    Total errors found during audit 10, fixed 10
                    Greetings,
                    Bep
                    "History is written by the winners"
                      The error report sounds like you are converting vectors from inches to cm when you should not - a vector [0,0,1] is normalized [0,0,2.54] is NOT. Only 'cm-ize' dimensions and leave vectors alone.
                        joergber
                        as mentioned above, the plugin does not export to correct DXF2000 format!
                        By now (for example) arcs with startangle of 245° and endangle 13° can happen!
                        I am not sure if this will be interpreted correctly by all importers or Autocad ...
                        And there is no HEADER or TABLE section or any (ENTITIES only!)
                        But I'll correct this in a future release!
                        But I also noticed that my 'orientation-algorithm' was incorrect for arcs with odd number of edges ...
                        I realized that the z-normal tells me if the arc was drawn cw or ccw ...
                        Thanks to TIG, which gave me food for thought 😉
                        Bep:
                        Thank you for the report!
                        I'll try Doublecad xt ...!
                        (or let you generate the reports 😉 )
                        TIG:
                        Yes, I converted everything although normals shouldn't.
                        Thank you!
                        Give me a day or two to
                        • 'fix' arc-orientation (again 😳 ).
                        • implement export of 3d oriented circles and arcs to lines ...
                        • support Faces (however ❓ )
                        • respect Components
                        • not explode everything anymore!
                        Thanks again to everybody!
                        Jörg
                        • dereiD Offline
                          derei
                          Thank you, Jörg ! Today I had the occasion to use the updated version of the plugin, as I had to export some sketchup drawings as DXF for CNC. Despite it turns some arcs in AutoCAD, they are right oriented in CNC Software, and that is what I'm interested in.
                          You made me very happy here! Good luck with the improvements 👍
                            joergber
                            new version v0.0.4 available ...
                            I updated the first post.
                            Have fun!
                            Jörg
                              Dubman1013
                              I imported this plug-in, when I select the items & export, it does not give me any file types to choose from, no DXF. Is there something I'm missing or is there another plugin to make this work? Thanks for any advice!
                              I just downloaded the new version, but it still does not give the dxf file type to save as. Any suggestion ?
                                joergber
                                @Dubman1013
                                There is no filetype to choose from!
                                The Plugin takes the current skp-filename and exchanges '.skp' with '.dxf' thats all!
                                (For unsaved models the default filename is 'Untitled.dxf')
                                Just click 'Export to DXF' then choose the folder to save to and save the dxf.
                                Before saving you may change the filename to your needs!
                                (But don't forget '.dxf' at the end of the filename)
                                Have a nice day!
                                Jörg
                                  Gumleguf
                                  Thanks for a great plugin! I just sent a .dxf file to a friend and he could open it perfectly in SolidWorks. Next step is to CNC the part. 😍
                                  Edit: One thing. My friend just mentioned that when he opened the .dxf in SolidWorks it was in Inches even though I made it in mm. He could just change to mm, but still...
                                    joergber
                                    Hi!
                                    Gumleguf:
                                    I can not reproduce here ...
                                    The only thing I could imagine is that you disabled the
                                    'Display units format' setting (Window->Model Info->Units) but then there should have been a messagebox saying "Unable to detect the actual unit setting ...\nGenerate Output in inch?" and the whole DXF would have been 'inverted' because the units calculation factor is -1 in this case ...
                                    (will be fixed in next release! 😳 )
                                    Pls. let me know if the problem persists!
                                    And maybe you do have a screenshot that could help or the .skp file of your model ... ... ... 😄
                                    Anyway, thank you very much for the feedback 👍
                                    ❓ More than 120 downloads and just this few problems/bugs/featurerequests/... 😄
                                    Enjoy,
                                    Jörg
                                      Gumleguf
                                      You are welcome, and thank you (!) for the plugin! 😄
                                      Here is an example of a sketchup that he says opens in Inches:
                                      GMaxx_bagplade1_1.skp
                                        joergber
                                        Wohooo, that was fast 😲
                                        I exported without any problems ...
                                        dxf opened in HEEKSCNC
                                        Here is my output ...
                                        unitsFactorProblem.dxf
                                        Could you pls. send this file to your friend to doublecheck?
                                        Could you pls. check the setting and try again?
                                        ❓ If you select the measure tool in SU ...
                                        is the length displayed like '371,25mm'?
                                        Thank you!
                                        Cheers
                                        Jörg
                                        • utilerU Offline
                                          utiler
                                          Hi joergber,
                                          Can you explain how this plugin differs to a standard SU export?
                                          Just Curious...
                                            joergber
                                            utiler:
                                            It might not have come out clearly ...
                                            I'm using SU 8 free (just updated my profile 😳 )
                                            And the standard dxf-exporter is for pros only ( as far as I know )
                                            So ...
                                            I don't know how it differs to standard SU export 😕
                                            Is there a specific reason why you are asking?
                                            Respects
                                            Jörg
                                            • 1 / 3
