    Needed plugin to turn "hidden geometry" into proper edges
    7 Posts 4 Posters 470 Views 4 Watching
      Bertier
      it's all in the title, I couldn't find it in the plugin list ...
      all help welcome.
      • massimoM Offline
        massimo Moderator
        Just triple left click on the object-->right click-->soften/smooth edges and drag the cursor to 0,0 degrees. It only works with soften/smooth edges though.
          Select your edges, then use the Entity Info window to control Hidden, Soft and Smooth properties of the edges. No plugin needed.
          • TIGT Online
            And... to avoid having faces in a selection use 'Wireframe' mode before making it...
              Bertier
              that simple... thank you !
              too much modeling this week end.... very large complex files to be released soon !
              since I am there asking questions : is there a plugin to paint front & back face with the same material ?
              lets say I have a window texture on one side and an other texture on the other side... I'd like to right click the face I am interested into and copy the texture to the other face.
                UV Toolkit: http://forums.sketchucation.com/viewtopic.php?t=18992
                or, if your mesh is built of Quads: QuadFace Tools http://forums.sketchucation.com/viewtopic.php?t=39442
                  Bertier
                  great ! 😄
