    Needed plugin to turn "hidden geometry" into proper edges
    7 Posts 4 Posters 421 Views 4 Watching
      Bertier
      it's all in the title, I couldn't find it in the plugin list ...
      all help welcome.
      • massimoM Offline
        massimo Moderator
        Just triple left click on the object-->right click-->soften/smooth edges and drag the cursor to 0,0 degrees. It only works with soften/smooth edges though.
          Select your edges, then use the Entity Info window to control Hidden, Soft and Smooth properties of the edges. No plugin needed.
            And... to avoid having faces in a selection use 'Wireframe' mode before making it...
              Bertier
              that simple... thank you !
              too much modeling this week end.... very large complex files to be released soon !
              since I am there asking questions : is there a plugin to paint front & back face with the same material ?
              lets say I have a window texture on one side and an other texture on the other side... I'd like to right click the face I am interested into and copy the texture to the other face.
                UV Toolkit: http://forums.sketchucation.com/viewtopic.php?t=18992
                or, if your mesh is built of Quads: QuadFace Tools http://forums.sketchucation.com/viewtopic.php?t=39442
                  Bertier
                  great ! 😄
