    [Plugin] Material Tools
    124 Posts 44 Posters 195.2k Views 44 Watching
      Stop breaking things!
        They call me Mr.Glass
          As a DIY quick-fix - change
          if ents.respond_to?( :back_material )
          to
          if e.respond_to?( :back_material )
            Sorted πŸ‘
            Now I'll break something else
              Go'n run with scissors or something...
                Pherim
                I like find this plugin very useful, especially the possibility to transfer the instance material to the faces inside the group or component, but that results in the backfaces also being painted. But sometimes I just want all the instance material gone as I sometimes accidentally assign a material to a group or component and later I can't find it any more. This is especially annoying if the material is not used any more in the rest of the model but remains in the material browser and doesn't get purged. I tried removing all backface materials after transferring the instance material but that resulted in also losing all backface materials I assigned intentionally. Is there a way to simply remove all instance materials?
                  jorge2011
                  Hello sr thomthom.
                  I think I'm doing something wrong or is there a bug in the plugin.
                  1 - Remove From Selection.
                  Error: # undefined local variable or <NameError: ents' method for TT::Plugins::MaterialTools:Module> C: / Program Files / Google / Google SketchUp 8/Plugins/tt_material_tools.rb: 270: in remove_all_from_selection '
                  πŸ˜„ / Program Files / Google / Google SketchUp 8/Plugins/tt_material_tools.rb: 256: in each ' C: / Program Files / Google / Google SketchUp 8/Plugins/tt_material_tools.rb: 256: in remove_all_from_selection '
                  πŸ˜„ / Program Files / Google / Google SketchUp 8/Plugins/tt_material_tools.rb: 62
                  add
                  Groups only erases materials or components. If you edit a component or group and select faces and edges were deleted material.
                  If I select faces or edges that are not in a group or component, the materials are not deleted.
                  If I select a group / component, which contains within groups / components nested, the materials are not deleted.
                  if I apply a material to a group / component and other material to the face that contains this group, only delete the material applied inside to the faces in the group / component
                  2 - Remove Specific Material
                  only works with colors. Textured materials does not work.
                  In addition, when shown the list of materials to remove, it only shows the name of the texture of the material, rather than the name of the material
                  is possible to solve this problem.
                  Thank you very much for your time
                    Is this the latest version 2.2.0?
                    if so it looks to me like you have some code 'missing' in the script - you haven't opened the .rb script with a wordprocessor and then saved or edited it with say Notepad.exe ??
                    Line #270 is actually about if e.respond_to?( :back_material ) while the offending error for ' ents' should occur earlier in line #260 where it first appears as parent.entities.each { |ents| or the next three lines #262/263/264 - so there's obviously something wrong here...
                    Try reinstalling the tool and come back...
                      jorge2011
                      tig thanks for your reply.
                      But reinstalling the plugin and the library. The plugin still generates the same error.
                      I use sketchup in Spanish, has something to do this?
                      Error: #<NameError: undefined local variable or method ents' for TT::Plugins::MaterialTools:Module> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:270:in remove_all_from_selection'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:256:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:256:in remove_all_from_selection'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:62
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:270:in `call'
                        I think we must wait for thomthom himself to reply.
                        As far as I can see you can't get that error with a correctly installed script πŸ˜•
                          I have an update for this in an unreleased version. I'll get it online soon.
                            jorge2011
                            many, thank you very much. is a very useful tool
                              Version 2.5.1
                              # 2.5.1 - 29.06.2011
                              #    * Fixed typo bug in Remove From Selection.
                              # 2.5.0 - 15.12.2010
                              #    * Paint roof.
                              # 2.4.0 - 15.12.2010
                              #    * Ensure Unique Filenames.
                              # 2.3.0 - 31.10.2010
                              #    * Remove All Textures.
                                jorge2011
                                thom excellent update.
                                still not cleared yet assigned to groups of materials / components.
                                You can correct this?
                                Sin tΓ­tulo.skp
                                  ? You're still getting errors?
                                    jorge2011
                                    no, no errors.
                                    but does not remove the materials assigned to a group.
                                    if you remove the materials assigned to faces and edges contained within the group.
                                    see the file
                                    and
                                      Version 2.5.2
                                      Fixed bug in Remove From Selection
                                        jorge2011
                                        Thank you very much. πŸ˜„
                                        • irwanwrI Offline
                                          irwanwr
                                          thank you very much for this plugins. πŸ‘
                                          it's very useful for me to keep the file size as small as it could.
                                          • halroachH Offline
                                            halroach
                                            1. Does the 'remove specific material work on textures?
                                            2. I've got a problem when trying to remove a specific material. Have many many materials in my model and the list of materials in the plugin is not long enough for me to see all of them. Any solution?
                                            3. The reason I am trying to use this plugin is for removing a material that has a TGA in it (which causes annoying errors when I first open the model). I am not able to find the TGA in the model, but am able to find the material it is in. When I try to right click on the material in the regular materials window, sketchup freezes for 10 seconds or so, and then I see the context menu for only a fraction of a second, and I am not able to actually delete the material. This happens a lot when I have a lot of materials in a model.
                                            This is a sketchup bug that's been around for quite a long time! Any suggestions?
                                            1. 'List textures in console' doesn't seem to do anything other than opening the console box, but nothing happens.
                                            (I'm using latest sketchup pro 8 with windows 7 64bit)
                                            FlexTools - Super Quick Windows, Doors, Slats...
                                            • 4 / 7
