    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 442.8k Views 75 Watching
      @kulaczek said:
      Its there any posibility to reduce polygons?
      @kulaczek said:
      Can you recomend something to speed it up?
      Scale the bitmap down before processing it. Smaller image = simpler mesh = faster generation.
      • ichiI Offline
        ichi
        Thanks for the update thomthom,it's one of my favorite plugins πŸ˜„
        Blog
        • 66searcher6 Offline
          66searcher
          @ TT : well done ! it's great plugin . πŸ‘
          http://hamidtoliat.deviantart.com/
          • Y Offline
            yuchunGong
              daveydave
              thanks, works in verion 6 too.
                kgregorian
                Hey everyone, I am new to these forums and I have a quick question, I'm sorry in advance if it's already been answered. I just downloaded this plugin, and placed it in the right location...I have a Mac, so I wen to my internal hdd>app support>google sketchup 8>sketchup>plugins. Yet when I open sketchup it says the following: 'Error Loading File tt_bitmap2mesh.rb no such file to load -- TT_Lib2/core.rb'. This happened to me before, what I did to correct it. Any help would be appreciated. Thanks!
                  You have missed the "Requirements" in the first post:
                  You also need this plugin:
                  http://forums.sketchucation.com/download/file.php?id=63393
                    kgregorian
                    [attachment=0:2ey2mpwh]<!-- ia0 -->tt-lib.png<!-- ia0 -->[/attachment:2ey2mpwh]
                    Oh ok that makes sense, thanks for the help!
                      marcomartim
                      I've downloaded and
                      put the two files in the folder plugin (SU)
                      does not work (in SU7 and SU8)
                      I've downloaded tt_bitmap2mesh and TT_Lib2 - 2.5.8 (also tested TT_Lib)
                      put the 2 files in the folder plugin
                      I've used this plugin often with WinXP on the old PC, I am now using Win7 64
                      Thanks a solution.
                        Could you post a screen shot of the plugins folder showing the files?
                          @marcomartim said:
                          I've downloaded and
                          Thanks a solution.
                          What 'two files' ? πŸ˜•
                          You should have tt_bitmap2mesh.rb that downloads as it is and that goes into the Plugins folder.
                          Then you need to get the required TT_Lib2 set - it downloads in a zip file [currently named TT_Lib2 - 2.5.8.zip], you MUST extract the folder that's in that zip file. That folder us called TT_Lib2 and it goes into the Plugins folder. It should contain lots of files and some subfolders inside it after the extraction, just as they are in the zip file when you view its contents... πŸ˜•
                          When correctly installed it should work on all OSs and v7 or v8...
                          Check that you have full access rights to add files/folders into the Plugins folder - Windows might let you think you have done so but it can surreptitiously move them into a 'compatibility files' folder pending someone in authority OKing it - you need to be an Admin and have proper rights to do this...
                          After a restart of Sketchup... The menus are:
                          Draw > Mesh From Heightmap Context Menu > Mesh From Heightmap Context Menu > Mesh From Bitmap
                            marcomartim
                            http://img593.imageshack.us/img593/5576/su7d.jpg
                            http://img577.imageshack.us/img577/7910/su8g.jpg
                              What's inside the TT_Lib2 folder ?
                              When you say, 'It does not work...', what do you mean ?
                              For example...
                              Are there no menu items visible ? [see my recent post for detail of these]
                              Or do the menu items seem to do nothing ?
                              Are there are error messages displayed in the Window > Ruby Console when you run it ?
                              If you type [or copy+paste] this
                              TT::Plugins::BitmapToMesh.bitmap_to_mesh_tool()
                              • <enter> in the Ruby Console what happens ?
                                It it works recheck the menu items I mentioned... πŸ˜’
                                marcomartim
                                Test File (bimap)
                                http://img26.imageshack.us/img26/8451/quadradoi.png
                                  marcomartim
                                  I know the plugin and its installation.; Used often
                                  Everything is correct, the files are all present, but for some reason does not work.
                                  tested with various BMP 100x100 pixels.
                                  It does not work, nothing happens.
                                    marcomartim
                                    • <enter> in the Ruby Console what happens ?:
                                    He opens the window to call the bimap,
                                    made the selection BMP + enter​​,
                                    window appears after the figure:
                                    http://img840.imageshack.us/img840/882/erro2d.jpg
                                      I can see a problem πŸ’­ - accented-characters in file-paths can cause problems in some Ruby functions - like File reading and checking.
                                      When you moved the bitmap file to C:/quadrado.bmp it worked because there were no accents in the path, BUT Usu**Γ‘**rio [your name!] has the accent in the path to the file on your Desktop!
                                      Try renaming your account to Usu**a**rio and it should then work!
                                      So the lesson is avoid accented-characters in folder-names and file-names that might be needed in Ruby code...
                                      πŸ˜’
                                        marcomartim
                                        πŸ˜’
                                        These folder names are standard Windows version in Portuguese, rename it can cause problems in other software
                                        Probably, other users have the same problem and without discovering the cause, leave this excellent plugin, at least if they read these posts will know why.
                                        Thank you, hugs ...
                                          marcomartim
                                          I discovered what may be causing the problem
                                          I put the file "quadrado.bmp" at the root of πŸ˜„ / / and it worked.
                                          Thus probably a plugin or library has problems with Win7 versions in other languages (not find the BMP)
                                          http://img202.imageshack.us/img202/9007/workedg.jpg
                                          Thanks for the help
                                            You misunderstood me...
                                            The user-folder path is always
                                            C:/Users/**THE_USERS_NAME**/
                                            'UsuΓ‘rio' [=='User'] is the default user-name in Portuguese.
                                            BUT if it were me it would become
                                            C:/Users/**TIG**/Desktop/quadrado.bmp
                                            So for you the account ought to be something like
                                            C:/Users/**MARCO**/Desktop/quadrado.bmp
                                            or
                                            C:/Users/**MARCOMARTIM**/Desktop/quadrado.bmp
                                            Why would you use 'User' as your account name - it's supposed to be personalized !
                                            You are NOT renaming a standard path - it's meant to be customized.
                                            All I'm saying is avoid accented letters in the folder path / file names πŸ˜’
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 13 / 14
