    [REQ] Component array formerly Triangular array
    27 Posts 7 Posters 4.2k Views 7 Watching
      Justo
      Sorry, the 2nd one is directional changing (I think?) I didnt explain properly, I think I meant like a rectangular array of the same based on the triangular array concept, but you can change the angle to 45deg as below.
      I imagine it must have to be a seperate plugin?
      Cheers
      Justin
        Justo
        @sdmitch said:
        @justo said:
        :sketchstatic:
        so all the arrays are in one spot?
        Not sure what you mean.
        One plugin to rule them all.
        'Array plugin' which has the Triangular, Rectangular, and Rectangular on 45deg (or defineable angle) arrays.
        Possible?
        Thanks again!
        Cheers
        Justin
          Justo
          Awesome thanks for that
          Cheers
          Justin
          • dereiD Offline
            derei
            Please put in the first post the final version.
            Thank you. I can't wait to try it!
            DESIGNER AND ARTIST DEREI.UK
            • Chris FullmerC Offline
              Sam, to make it easier to maintain for us mods, you could post a new topic for the plugin, and remove the plugin from this thread. And add some links in this thread to the plugin thread.
              That way we can easily update our plugins list and give you credit for the plugin. Thanks!
                Justo
                Having a play with the first script (The Triangular array)
                Changing
                pt0.offset!(Y_AXIS,interval*0.866);#puts"next pt0=#{pt0}"
                to
                pt0.offset!(ya,interval*1);#puts"next pt0=#{pt0}"
                I end up with the below image
                Paving running bond/stretcher
                The axis is on the left bottom of the paver
                and the spacing is almost 0.492 (from memory) from the side on x and y axis, using a 1m square component.
                With the below if I centralise the axis it overlaps as shown below.
                How is the start point defined? (to have them start on the edge?)
                Also, if i was to have a 2m x 1m component, where do I change that?
                Paver with centralised axis
                Once again... Thanks
                Cheers
                Justin
                  Justo
                  Oops sorry guys
                  Cheers
                  Justin
                    Thanks sdmitch
                    can I suggest you also tweak
                    @ent = mod.entities
                    to
                    @ent = mod.active_entities
                    so the user can place things inside groups while editing them - at the moment everything goes into the model even if you run the tool inside an edit context!
                    I also reiterate Chris's request to start a new thread so the plugin is 'managed' better...
                    • jolranJ Offline
                      jolran
                      Way to go Sdmitch. Nice update πŸ‘
                      There is only one issue as I see it(look pic). But then again fixing this could be going into the domain of one of Chris Fullmer tools. And if we are gonna follow point 1) http://forums.sketchucation.com/viewtopic.php?f=180&t=12423 then you might already have what is needed in your plugin..
                      Congrats!
                      • sdmitchS Offline
                        sdmitch
                        Justin, If you have a 1m X 2m component then,pt0.offset!(xa,interval) and pt0.offset!(ya,interval*2) or add a seperate input for the Y interval.
                        Jolran, I assume you want the option to place the components perpendicular to the face?
                        TIG, done.
                        Chris, will do.
                        http://sdmitch.blogspot.com/
                        • sdmitchS Offline
                          sdmitch
                          justo, try this plugin, I think it will do what you want.
                          Plugin can be found at
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=40244
                          results tor Triangular Array.rb
                          • sdmitchS Offline
                            sdmitch
                            @justo said:
                            :sketchstatic:
                            Would I be painful if I was to ask if the angle could be selectable so it could be set for 45deg and 0 deg, just so all the arrays are in one spot? (Im looking at the script and dont understand any of it to try to do it myself)
                            Thanks everyone for your input!
                            Added angle input and 3d capability so face can be tilted.
                            • sdmitchS Offline
                              sdmitch
                              Possible?
                              Sure.
                              • jolranJ Offline
                                jolran
                                Well yeah.! But Chris F's Components onto Faces already does that function, so...
                                Obviously you are a very talented programmer, so in my opinion it's a little waste for you to do something does already exist. Or might exist in next versions of thoose plugins.
                                • sdmitchS Offline
                                  sdmitch
                                  Well I don't know all that exists. I simply see a request and try to offer a solution. If Chris has a plugin that does this then it is no doubt better than mine I would suggest you use it.
                                  • jolranJ Offline
                                    jolran
                                    No, you are right. That did not exist exactley.
                                    What I ment was you did not go to that trouble for my sake. Now that you have. I'm greatful πŸ˜„ .
                                    Thanks.
                                      Justo
                                      Adam ended up doing a 0.5 instead of 2... i think thats what you meant? or did i get my x/y's the wrong way... πŸ˜‰
                                      pt0.offset!(ya,interval*0.5)
                                      either got it
                                      I'll post further questions to the plugin page πŸ˜’
                                      Cheers
                                      Justin
