    [REQ] Component array formerly Triangular array
    27 Posts 7 Posters 5.0k Views 7 Watching
      Justo
      2d hatchfaces seems to be the closest thing to what Im looking for... Although, using the 2d hatchfaces plugin within a polygon selecting cross hatching and 30deg gives the right shape triangles, although entering 1m spacing ends up being 1.155m, and then using components or contruction points on the intersections, and delete the group.
      Is it possible to populate intersections with components or construction points (or whatever)?
      Apologies if this makes no sense, im tired and its past my bedtime...
      Cheers
      Justin
      • jolranJ Offline
        jolran
        Ahhhh.. I did not understand that TIG meant to use crosshatching in current version of hatchfaces. Rather tiling of some triangular pattern in upcoming versions..Never mind.
        Well acctually it's not. For each edge that is. Spacing is perpendicular to degrees selection.
        It only looks that way when crosshatching skews lines together.
        Try using 45 degrees. Or if you want to use 30 degrees try using 866 mm spacing instead.
        Not quite yet. Thats a whole new plugin. But try exploding lines onto face. The you will get an intersection where you can put stuff.
        • jolranJ Offline
          jolran
          Shark πŸ˜‰
          Maybe use selected component instead of a list. When I tried it the list went out of screen, filled with components. It remembers last created/selected component? That's nice and enough then?
          Some components get outside the bounds, but that behavior is hard to predict IF you are going to expand the plugin to work in all axes.
          Nicely done.
            Justo
            I do believe thats what I was after. Thanks sdmitch!
            Triangular Array with plants
            Some components did place outside area, more to do with origin center (which was in the area) of the individual component i think
            I didnt have a problem with the dropdown menu, mainly cos I didnt have components in the new file
            Would I be painful if I was to ask if the angle could be selectable so it could be set for 45deg and 0 deg, just so all the arrays are in one spot? (Im looking at the script and dont understand any of it to try to do it myself)
            Thanks everyone for your input!
            Cheers
            Justin
              Justo
              Sorry, the 2nd one is directional changing (I think?) I didnt explain properly, I think I meant like a rectangular array of the same based on the triangular array concept, but you can change the angle to 45deg as below.
              I imagine it must have to be a seperate plugin?
              Cheers
              Justin
                Justo
                @sdmitch said:
                @justo said:
                :sketchstatic:
                Not sure what you mean.
                One plugin to rule them all.
                'Array plugin' which has the Triangular, Rectangular, and Rectangular on 45deg (or defineable angle) arrays.
                Possible?
                Thanks again!
                Cheers
                Justin
                  Justo
                  Awesome thanks for that
                  Cheers
                  Justin
                  • dereiD Offline
                    derei
                    Please put in the first post the final version.
                    Thank you. I can't wait to try it!
                    DESIGNER AND ARTIST DEREI.UK
                    • Chris FullmerC Offline
                      Sam, to make it easier to maintain for us mods, you could post a new topic for the plugin, and remove the plugin from this thread. And add some links in this thread to the plugin thread.
                      That way we can easily update our plugins list and give you credit for the plugin. Thanks!
                        Justo
                        Having a play with the first script (The Triangular array)
                        Changing
                        pt0.offset!(Y_AXIS,interval*0.866);#puts"next pt0=#{pt0}"
                        to
                        pt0.offset!(ya,interval*1);#puts"next pt0=#{pt0}"
                        I end up with the below image
                        Paving running bond/stretcher
                        The axis is on the left bottom of the paver
                        and the spacing is almost 0.492 (from memory) from the side on x and y axis, using a 1m square component.
                        With the below if I centralise the axis it overlaps as shown below.
                        How is the start point defined? (to have them start on the edge?)
                        Also, if i was to have a 2m x 1m component, where do I change that?
                        Paver with centralised axis
                        Once again... Thanks
                        Cheers
                        Justin
                          Justo
                          Oops sorry guys
                          Cheers
                          Justin
                            Thanks sdmitch
                            can I suggest you also tweak
                            @ent = mod.entities
                            to
                            @ent = mod.active_entities
                            so the user can place things inside groups while editing them - at the moment everything goes into the model even if you run the tool inside an edit context!
                            I also reiterate Chris's request to start a new thread so the plugin is 'managed' better...
                            • jolranJ Offline
                              jolran
                              Way to go Sdmitch. Nice update πŸ‘
                              There is only one issue as I see it(look pic). But then again fixing this could be going into the domain of one of Chris Fullmer tools. And if we are gonna follow point 1) http://forums.sketchucation.com/viewtopic.php?f=180&t=12423 then you might already have what is needed in your plugin..
                              Congrats!
                              • sdmitchS Offline
                                sdmitch
                                Justin, If you have a 1m X 2m component then,pt0.offset!(xa,interval) and pt0.offset!(ya,interval*2) or add a seperate input for the Y interval.
                                Jolran, I assume you want the option to place the components perpendicular to the face?
                                TIG, done.
                                Chris, will do.
                                http://sdmitch.blogspot.com/
                                • sdmitchS Offline
                                  sdmitch
                                  justo, try this plugin, I think it will do what you want.
                                  Plugin can be found at
                                  http://forums.sketchucation.com/viewtopic.php?f=323&t=40244
                                  results tor Triangular Array.rb
                                  • sdmitchS Offline
                                    sdmitch
                                    @justo said:
                                    :sketchstatic:
                                    Added angle input and 3d capability so face can be tilted.
                                    • sdmitchS Offline
                                      sdmitch
                                      Possible?
                                      Sure.
                                      404 Not Found
                                      (forums.sketchucation.com)
                                      • jolranJ Offline
                                        jolran
                                        Well yeah.! But Chris F's Components onto Faces already does that function, so...
                                        Obviously you are a very talented programmer, so in my opinion it's a little waste for you to do something does already exist. Or might exist in next versions of thoose plugins.
                                        • sdmitchS Offline
                                          sdmitch
                                          Well I don't know all that exists. I simply see a request and try to offer a solution. If Chris has a plugin that does this then it is no doubt better than mine I would suggest you use it.
                                          • jolranJ Offline
                                            jolran
                                            No, you are right. That did not exist exactley.
                                            What I ment was you did not go to that trouble for my sake. Now that you have. I'm greatful πŸ˜„ .
                                            Thanks.
