    [REQ] Component array formerly Triangular array
    27 Posts 7 Posters 4.5k Views 7 Watching
      Using a few guide-lines and the Move+Ctrl > Copy + Nx can duplicate objects at any angle in a linear array, then repeat on an angled line of objects Nx to make a 2d array [or repeat again even up in Z to make a 3d array!]. Erase unwanted objects outside of any 2d polygon you have?
      Jolran's new hatching tools could replicate this 2d arraying in a given polygon for you...
      • jolranJ Offline
        jolran
        There are eager young new code-sharks out there just waiting for a new idea to jump on, so it's a good idea putting [REQ] on it.
        Yes, but I think he want's 3d components. Besides, I'll think it will never get out in public, unless I become a JS expert. This webdialog stuff is hartbreaking πŸ˜„ .
        Seriously though. I think Justo have a good idea for a plugin here.
        I'm not gonna hijack this thread, but turning some of the parts in hatchfaces to make a new 3d components tiler based on patterns, would be cool. I can consider working on that..
          Justo
          2d hatchfaces seems to be the closest thing to what Im looking for... Although, using the 2d hatchfaces plugin within a polygon selecting cross hatching and 30deg gives the right shape triangles, although entering 1m spacing ends up being 1.155m, and then using components or contruction points on the intersections, and delete the group.
          Is it possible to populate intersections with components or construction points (or whatever)?
          Apologies if this makes no sense, im tired and its past my bedtime...
          Cheers
          Justin
          • jolranJ Offline
            jolran
            Ahhhh.. I did not understand that TIG meant to use crosshatching in current version of hatchfaces. Rather tiling of some triangular pattern in upcoming versions..Never mind.
            Well acctually it's not. For each edge that is. Spacing is perpendicular to degrees selection.
            It only looks that way when crosshatching skews lines together.
            Try using 45 degrees. Or if you want to use 30 degrees try using 866 mm spacing instead.
            Not quite yet. Thats a whole new plugin. But try exploding lines onto face. The you will get an intersection where you can put stuff.
            • jolranJ Offline
              jolran
              Shark πŸ˜‰
              Maybe use selected component instead of a list. When I tried it the list went out of screen, filled with components. It remembers last created/selected component? That's nice and enough then?
              Some components get outside the bounds, but that behavior is hard to predict IF you are going to expand the plugin to work in all axes.
              Nicely done.
                Justo
                I do believe thats what I was after. Thanks sdmitch!
                Triangular Array with plants
                Some components did place outside area, more to do with origin center (which was in the area) of the individual component i think
                I didnt have a problem with the dropdown menu, mainly cos I didnt have components in the new file
                Would I be painful if I was to ask if the angle could be selectable so it could be set for 45deg and 0 deg, just so all the arrays are in one spot? (Im looking at the script and dont understand any of it to try to do it myself)
                Thanks everyone for your input!
                Cheers
                Justin
                  Justo
                  Sorry, the 2nd one is directional changing (I think?) I didnt explain properly, I think I meant like a rectangular array of the same based on the triangular array concept, but you can change the angle to 45deg as below.
                  I imagine it must have to be a seperate plugin?
                  Cheers
                  Justin
                    Justo
                    @sdmitch said:
                    @justo said:
                    :sketchstatic:
                    Not sure what you mean.
                    One plugin to rule them all.
                    'Array plugin' which has the Triangular, Rectangular, and Rectangular on 45deg (or defineable angle) arrays.
                    Possible?
                    Thanks again!
                    Cheers
                    Justin
                      Justo
                      Awesome thanks for that
                      Cheers
                      Justin
                      • dereiD Offline
                        derei
                        Please put in the first post the final version.
                        Thank you. I can't wait to try it!
                        DESIGNER AND ARTIST DEREI.UK
                        • Chris FullmerC Offline
                          Sam, to make it easier to maintain for us mods, you could post a new topic for the plugin, and remove the plugin from this thread. And add some links in this thread to the plugin thread.
                          That way we can easily update our plugins list and give you credit for the plugin. Thanks!
                            Justo
                            Having a play with the first script (The Triangular array)
                            Changing
                            pt0.offset!(Y_AXIS,interval*0.866);#puts"next pt0=#{pt0}"
                            to
                            pt0.offset!(ya,interval*1);#puts"next pt0=#{pt0}"
                            I end up with the below image
                            Paving running bond/stretcher
                            The axis is on the left bottom of the paver
                            and the spacing is almost 0.492 (from memory) from the side on x and y axis, using a 1m square component.
                            With the below if I centralise the axis it overlaps as shown below.
                            How is the start point defined? (to have them start on the edge?)
                            Also, if i was to have a 2m x 1m component, where do I change that?
                            Paver with centralised axis
                            Once again... Thanks
                            Cheers
                            Justin
                              Justo
                              Oops sorry guys
                              Cheers
                              Justin
                                Thanks sdmitch
                                can I suggest you also tweak
                                @ent = mod.entities
                                to
                                @ent = mod.active_entities
                                so the user can place things inside groups while editing them - at the moment everything goes into the model even if you run the tool inside an edit context!
                                I also reiterate Chris's request to start a new thread so the plugin is 'managed' better...
                                • jolranJ Offline
                                  jolran
                                  Way to go Sdmitch. Nice update πŸ‘
                                  There is only one issue as I see it(look pic). But then again fixing this could be going into the domain of one of Chris Fullmer tools. And if we are gonna follow point 1) http://forums.sketchucation.com/viewtopic.php?f=180&t=12423 then you might already have what is needed in your plugin..
                                  Congrats!
                                  • sdmitchS Offline
                                    sdmitch
                                    Justin, If you have a 1m X 2m component then,pt0.offset!(xa,interval) and pt0.offset!(ya,interval*2) or add a seperate input for the Y interval.
                                    Jolran, I assume you want the option to place the components perpendicular to the face?
                                    TIG, done.
                                    Chris, will do.
                                    http://sdmitch.blogspot.com/
                                    • sdmitchS Offline
                                      sdmitch
                                      justo, try this plugin, I think it will do what you want.
                                      Plugin can be found at
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=40244
                                      results tor Triangular Array.rb
                                      • sdmitchS Offline
                                        sdmitch
                                        @justo said:
                                        :sketchstatic:
                                        Added angle input and 3d capability so face can be tilted.
                                        • sdmitchS Offline
                                          sdmitch
                                          Possible?
                                          Sure.
                                          • jolranJ Offline
                                            jolran
                                            Well yeah.! But Chris F's Components onto Faces already does that function, so...
                                            Obviously you are a very talented programmer, so in my opinion it's a little waste for you to do something does already exist. Or might exist in next versions of thoose plugins.
