πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Rendering issue
renderpluginsextensions
13 Posts 6 Posters 1.1k Views 6 Watching
  • I Offline
    izboos
    I downloaded a tutorial re: chairs_original.skp (was created under sketchup 6 - available for downlaod via 4shared or alternative).
    I opened the file under sketchup pro 7. In the tutorial, when they show the render before they show instructions, it looks like *vray tutorial image As per tutorialfrom Chia Fu Chiang.
    However, when i render it, it looks like *actual vray render rendered using sketchup pro 7.
    Can anybody assist me with this matter please? 😞 😞 ❓ 😠
    • H Offline
      hvanessen
      This has got to do with the render output, in de options. Turn the overide viewport off. And then should the result the same as in the tutorial
      • I Offline
        izboos
        That didn't work. Still got the same "balck & white" result.
        Any other suggestions?
        • I Offline
          izboos
          Tried that procedure, but it didn't work. Got the same result. 😞
            stefanq
            Enable physical camera.
              broomstick
              ditto
              • I Offline
                izboos
                OK, "CameraPhysical" has been checked, & the render has come out TOTALLY BLACK!!!
                • V Offline
                  valerostudio
                  Your opening an tutorial file meant for a much older version of Vray. I believe those files have been kicking around from the old 1.05 version. Try to open your Options and click Load Defaults. This will at least get you a image rendered with the Sky GI. If you are using the latest 1.49.01 plugin I would not use these files.
                    Might even be older, from the very first version... πŸ˜• I imagine I saw the same scene in the manual for the first release.
                    • I Offline
                      izboos
                      BLECH!!! well, that sucks. I only downloaded the file tyo learn from it.
                      I'm a "fresh meat" to vray u see.
                      I created a normal cube with a corner of it chipped away, and rendered it. Got the shadow shade, but the background was still white. Is that normal for all Vray renders @ the start?
                      Also, can anybody recommend any good sites so I learn more about Vray properties?
                      ps: thanks for all the help so far u guys!!!
                      • V Offline
                        valerostudio
                        Go to the Chaos page on YouTube and watch all the Vray for SketchUp videos and you will be well on your way.
                          The online V-Ray manual has good explanations - especially the examples section: http://www.spot3d.com/vray/help/150SP1/
                          • I Offline
                            izboos
                            This is more for 3ds max i see. Should I be worried?
