    Vrimg help urgent
    renderpluginsextensions
    14 Posts 5 Posters 3.7k Views 5 Watching
    • andybotA Offline
      andybot
      has the converter been updated for 1.49.01 vrimages?
      • N Offline
        nomeradona
        you dont need converter. you just save it directly in exr.. I made also a tutorial here. http://nomeradona.blogspot.com/2011/08/tutorial-how-to-render-extra-huge.html
        • andybotA Offline
          andybot
          For saving channel information other than alpha you do need the converter. Unfortunately that's not working past 1.48.99
          • V Offline
            valerostudio
            This is the latest converter that was sent to me from Chaos, not sure if its going to work with the latest version. I have not tested it out yet. Let me know how it works.
            vrimg2exr.zip
            • N Offline
              nomeradona
              i see thanks for the correction.
              • andybotA Offline
                andybot
                lol - dated december 2006. Definitely not current.
                • V Offline
                  valerostudio
                  They sent me this file a couple of weeks ago. I figured it was going to be old. Best advice is to stay away from VRIMG and go with EXR if you really need to go about this method to save memory. I want my channels for post processing, so I never use this method. I got burned once and never did it again.
                  • V Offline
                    valerostudio
                    @dkendig said:
                    you need the converter tool that's listed here? http://spot3d.com/vray/misc/tools/vsketchup.html In the future, I would recommend using the Chaos Group forums when you really need support for V-Ray for SketchUp, I believe this question has been answered before on those forums. SketchUcation is great for users interacting with each other, but if you need some sort of technical support for the product, I would really recommend that you ask the folks that make it, in addition to asking everyone on this forum πŸ˜‰
                    This converter just saved my life. It does work with 1.49.01 but you dont get the channels. I accidently ran an overnighter and forgot to set it to EXR! Thought I was screwed. but this did the job.
                    • andybotA Offline
                      andybot
                      hmmm. Did you have any channels selected besides RGB color?
                      • V Offline
                        valerostudio
                        You know, I may have not. Why? Does this converter export the channels? I thought it was not doing this in this version.
                        • andybotA Offline
                          andybot
                          That's what I mean, I think the channels may be what is messing up the vrimage. When I have alpha channel selected, the resulting vrimage won't convert correctly to exr. Good to know that it works with only the rgb channel.
