    Vrimg help urgent
    renderpluginsextensions
    14 Posts 5 Posters 3.2k Views 5 Watching
    • I Offline
      imabzeous
      hello to ll experts. plz help me out..
      i have recently seen a video of vry in which they explian how to render aa vrimg... but the min problem is that the scritp he use for converting i not available on the vray coz choas buy it [ and m hating it].. i have serched alot but didnt find that application naywhere there are some pages where some codes are written but i cant understand it. so pl if ny one hve that converter can u mail me or help me out if there is any other solution ..
      PS when i render i save it as n exr image but when render is finished it appear aas vrimage
      • andybotA Offline
        andybot
        when you select the vray raw format to save as, make sure you use the drop down selection to select exr...
        hope that helps
        -Andy
        • dkendigD Offline
          dkendig
          you need the converter tool that's listed here? http://spot3d.com/vray/misc/tools/vsketchup.html In the future, I would recommend using the Chaos Group forums when you really need support for V-Ray for SketchUp, I believe this question has been answered before on those forums. SketchUcation is great for users interacting with each other, but if you need some sort of technical support for the product, I would really recommend that you ask the folks that make it, in addition to asking everyone on this forum πŸ˜‰
          Devin Kendig
          Developer
          • andybotA Offline
            andybot
            has the converter been updated for 1.49.01 vrimages?
            • N Offline
              nomeradona
              you dont need converter. you just save it directly in exr.. I made also a tutorial here. http://nomeradona.blogspot.com/2011/08/tutorial-how-to-render-extra-huge.html
              • andybotA Offline
                andybot
                For saving channel information other than alpha you do need the converter. Unfortunately that's not working past 1.48.99
                • V Offline
                  valerostudio
                  This is the latest converter that was sent to me from Chaos, not sure if its going to work with the latest version. I have not tested it out yet. Let me know how it works.
                  vrimg2exr.zip
                  • N Offline
                    nomeradona
                    i see thanks for the correction.
                    • andybotA Offline
                      andybot
                      lol - dated december 2006. Definitely not current.
                      • V Offline
                        valerostudio
                        They sent me this file a couple of weeks ago. I figured it was going to be old. Best advice is to stay away from VRIMG and go with EXR if you really need to go about this method to save memory. I want my channels for post processing, so I never use this method. I got burned once and never did it again.
                        • V Offline
                          valerostudio
                          This converter just saved my life. It does work with 1.49.01 but you dont get the channels. I accidently ran an overnighter and forgot to set it to EXR! Thought I was screwed. but this did the job.
                          • andybotA Offline
                            andybot
                            hmmm. Did you have any channels selected besides RGB color?
                            • V Offline
                              valerostudio
                              You know, I may have not. Why? Does this converter export the channels? I thought it was not doing this in this version.
                              • andybotA Offline
                                andybot
                                That's what I mean, I think the channels may be what is messing up the vrimage. When I have alpha channel selected, the resulting vrimage won't convert correctly to exr. Good to know that it works with only the rgb channel.
