    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.7k Views 172 Watching
      Have you done ALL of the fixes that I suggested?
      The error message is incomplete.
      Can you post the full message...
      Hai fatto TUTTE le correzioni che ho suggerito?
      Il messaggio di errore è incompleto.
      Puoi inviare il messaggio completo...
      It may be that that you have to enter values into all dialog boxes - even if '0'...
      Può essere che che è necessario inserire i valori in tutte le finestre di dialogo - anche se '0'...
      • C
        carmelo
        yes, I followed your instructions. The attached images show the folders located.
        The error message comes up when the program starts.
        Also, when I start the script, the window does not shows me any command.
          Please open the file LiveIvy.rb with 'Notepad.exe' and see what it says.
          It should have these lines
          require "LiveIvy/LiveVector_core"
          require "LiveIvy/LiveIvy_branch"
          require "LiveIvy/LiveIvy_node"
          require "LiveIvy/LiveIvy_leaf"
          require "LiveIvy/LiveIvy_tool"
          If not the the file is corrupted 😕
          Si prega di aprire il file LiveIvy.rb con 'Notepad.exe' e vedere cosa dice.... Dovrebbe avere queste linee...
          Se non il il file è danneggiato
          You could type/copy+paste the five ' require...' lines into the Ruby Console in turn and see if the tool then works.
          Si potrebbe digitare/copia+incolla il cinque ' require...' linee in Console Ruby, a sua volta e vedere se lo strumento funziona allora.
          • C
            carmelo
            Now it works.
            Wrong with the folders...sorry 😄
            thank you very much 😉
            carmelo
              Hooray! [Evviva!] 😄
              • charly2008C
                charly2008
                A nice tool, it works beautifully, thanks. What I still do not understand is, how can you change the twigs and leaves. Would someone kindly explain this for example with the Wisteria Bloom from Adam (Eartmover). Thanks in advance.
                Charly
                • P
                  pibuz
                  Sorry guys, when I start SketchUp with the plugin correctly installed I get an error message: "Error Loading File LiveIvy.rb Can't insert empty component." Then, sketchup starts with no problems but the plugin works oddly: multiple clicks often do not produce an incremental growth, and similar...
                  How can I fix this? Sorry to bother...
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    In the Textures subfolder within the Plugins folder you should have various files like this Capture.PNG
                    Check that the .skp files exist and that they each contain something!
                    • bigstickB
                      bigstick
                      Mmf - not working on Mac Lion with SU8...
                      I have the latest version of SU Ivy, the files are in the right place, the menu is there, the dialog pops up and works fine.
                      It's the clicking and drawing that doesn't seem to be working.
                        Are there any error messages in Ruby Console as you do this ? 😕
                        • charly2008C
                          charly2008
                          I have exchanged the ivy files through the Wisteria files. The generation of Wisteria leaves works, but in the bush still appears ivy leaves. What do i wrong? I am grateful for any information.
                          Charly
                          • bigstickB
                            bigstick
                            TIG - there is no output at all in the Ruby console.
                            This is how my installation looks:-
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy.rb
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\gui
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\Textures
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_branch.rb
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_leaf.rb
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_node.rb
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_tool.rb
                            \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveVector_core.rb
                            The GUI works, but the growing ivy doesn't. When I start to grow the ivy, I have the usual snap cursor. Is this what I'm supposed to see? Does this have a special cursor or some kind of visual indicator as to where to start the growth from?
                            Am I missing something basic?
                              The ../Textures/ file should also contain this?Capture.PNG and the ../gui/ folder this?Capture1.PNG
                              • bigstickB
                                bigstick
                                Yes, those are all present. Should have confirmed this at the time - sorry!
                                  I suggest you revisit earlier posts in the thread and see what the optimum settings are for the dialog...
                                  • X
                                    xavier benoit
                                    hello ....i tried your plugins but i don't have leaf only branch....the version is 0.6.3
                                    • Z
                                      zhuhuai
                                      i can finish off the ivy by shift-click, its still in creating ivy mode and i cant finish it.when i close the small window, my ivy gone. anyone got any idea wats that about?? thanks!
                                      • Z
                                        zhuhuai
                                        i have problem with shift + click on SU 6,error msg as below:
                                        wrong number of arguments(2 for 1)>
                                        C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:233:in start_operation' C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:233:in birth_stem'
                                        C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:98:in onLButtonDown'
                                        anyone got solution?
                                          After v6 model.start_operation('name') can have additional arguments
                                          e.g. model.start_operation('name',true) - which now means it doesn't try to regen the screen and slow things down unnecessarily.
                                          However, v7/8 tools that use this improvement then run the risk of crashing v6 as it's not then compatible code.
                                          Most authors add a trap to allow backward compatibility - this author hasn't!
                                          The way to fix it for your v6 installation is this.
                                          Open the file displaying the error - helpfully shown in the error message C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb using a plain text-editor like Notepad or Notepad++ [NOT a wordprocessor].
                                          Make a backup copy if you expect to mess up!
                                          Find the lines saying
                                          Sketchup.active_model.start_operation "BuildIvy", true
                                          and change it to read
                                          and because it occurs twice, also find
                                          Sketchup.active_model.start_operation "BuildLeaves", true
                                          and change that to read
                                          Save the file and restart/retry...
                                          It should then work with v6.
                                          If you have v7/8 use the unedited version because it'll be faster...
                                            mickeeman
                                            i tried to open the ivyleaf_1 2 and 3 on SketchUp 8 then bug splat appears. this maybe the reason why some users cant produces leaves on the vines, like myself i can only make branches.
                                            http://i240.photobucket.com/albums/ff131/mickeeman/branches.jpg
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 36
                                            • 37
                                            • 17 / 37
