    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 512.9k Views 172 Watching
    • charly2008C
      charly2008
      I have exchanged the ivy files through the Wisteria files. The generation of Wisteria leaves works, but in the bush still appears ivy leaves. What do i wrong? I am grateful for any information.
      Charly
      • bigstickB
        bigstick
        TIG - there is no output at all in the Ruby console.
        This is how my installation looks:-
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy.rb
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\gui
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\Textures
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_branch.rb
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_leaf.rb
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_node.rb
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveIvy_tool.rb
        \Library\Application Support\Google SketchUp 8\SketchUp\plugins\LiveIvy\LiveVector_core.rb
        The GUI works, but the growing ivy doesn't. When I start to grow the ivy, I have the usual snap cursor. Is this what I'm supposed to see? Does this have a special cursor or some kind of visual indicator as to where to start the growth from?
        Am I missing something basic?
          The ../Textures/ file should also contain this?Capture.PNG and the ../gui/ folder this?Capture1.PNG
          • bigstickB
            bigstick
            Yes, those are all present. Should have confirmed this at the time - sorry!
              I suggest you revisit earlier posts in the thread and see what the optimum settings are for the dialog...
              • X
                xavier benoit
                hello ....i tried your plugins but i don't have leaf only branch....the version is 0.6.3
                • Z
                  zhuhuai
                  i can finish off the ivy by shift-click, its still in creating ivy mode and i cant finish it.when i close the small window, my ivy gone. anyone got any idea wats that about?? thanks!
                  • Z
                    zhuhuai
                    i have problem with shift + click on SU 6,error msg as below:
                    wrong number of arguments(2 for 1)>
                    C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:233:in start_operation' C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:233:in birth_stem'
                    C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb:98:in onLButtonDown'
                    anyone got solution?
                      After v6 model.start_operation('name') can have additional arguments
                      e.g. model.start_operation('name',true) - which now means it doesn't try to regen the screen and slow things down unnecessarily.
                      However, v7/8 tools that use this improvement then run the risk of crashing v6 as it's not then compatible code.
                      Most authors add a trap to allow backward compatibility - this author hasn't!
                      The way to fix it for your v6 installation is this.
                      Open the file displaying the error - helpfully shown in the error message C:/Program Files/Google/Google SketchUp 6/Plugins/LiveIvy/LiveIvy_tool.rb using a plain text-editor like Notepad or Notepad++ [NOT a wordprocessor].
                      Make a backup copy if you expect to mess up!
                      Find the lines saying
                      Sketchup.active_model.start_operation "BuildIvy", true
                      and change it to read
                      and because it occurs twice, also find
                      Sketchup.active_model.start_operation "BuildLeaves", true
                      and change that to read
                      Save the file and restart/retry...
                      It should then work with v6.
                      If you have v7/8 use the unedited version because it'll be faster...
                        mickeeman
                        i tried to open the ivyleaf_1 2 and 3 on SketchUp 8 then bug splat appears. this maybe the reason why some users cant produces leaves on the vines, like myself i can only make branches.
                        http://i240.photobucket.com/albums/ff131/mickeeman/branches.jpg
                          Have you installed all of the supplied files in the correct subfolders within Plugins etc? Capture.PNGDo you have a 'leaf type' selected in the dialog?
                          Are there any error messages in the Ruby Console when you run the tool?
                          Clearly it doesn't Bugsplat! all of the time as you managed the screen-shot 😕
                          What are the settings you used to get that far ?
                          • X
                            xanzan911
                            great post...thanks sir...=)
                            • I
                              iamarchitecture
                              strange, using Win7 SU8 and 0.6 and leaf size won't respond. can't go smaller than what seems to be size 5.
                              • B
                                bulbangs
                                looks amazing!
                                • I
                                  iamarchitecture
                                  can someone post on how to change leaves?
                                  every time I try to open the skp files within the plugin all i get is a bugsplat.
                                  it would be greatly appreciated and i know other want to know as well.
                                  Thanks a billion.
                                    mickeeman
                                    @tig said:
                                    Have you installed all of the supplied files in the correct subfolders within Plugins etc? [attachment=0:eeir6bnk]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:eeir6bnk]Do you have a 'leaf type' selected in the dialog?
                                    sorry for the very late reply. when i open the SKP files of the leaves, it crashes. (like iAMarchitecture's problem)
                                    and yes, i placed them in the correct folders. i just dont get it why it can produce any leaves when i use it.
                                      mickeeman
                                      just found out some settings for it to work. (seems like the default settings can't produce leaves for win7 SU8 ivy 6.3 users)
                                      Error 404 (Not Found)!!1
                                      (3.bp.blogspot.com)
                                      (2.bp.blogspot.com)
                                      the links are from sir nomer adona's blog.
                                      • B
                                        bedo
                                        Su 8 on windows
                                        the plugin is correctly installed, double checked, I read through most of the previous posts to find an answer but still:
                                        the plugin only works once, meaning..I can start over and over again with the I key , making several ivy's... however when open a new file, I can make stems(red line) make leafs(green x) but Finishing it up by clicking shift...does not work...It only creates a line on the main stem, and a little squaro on the bottom, which would be the starting point... and someone posted that before here I saw. I have to close sketchup in order to get it working again, and no there is no bug msg.
                                        Second thing..hów can I choose which leaf I want? does it only go by default? meaning I can change the Ivy leaf components in the plugin folder...but then im stuck with that... I can't load 6 different leafs and select the ones i want?
                                        Thanks for anybodys answer in advance 😄
                                        • T
                                          tomasz
                                          Excellent work Pierre!
                                          I have noticed that SU Ivy loads definition of Ivy components and materials every time SketchUp is being opened.
                                          Can you modify the script so it loads them on tool startup, not when the plugin loads itself, please?
                                          Currently every model loaded on Sketchup start-up gets them inserted.
                                          if (not file_loaded?(File.basename(__FILE__)))
                                            menuitem = "SketchupIvy #{LiveIvy;;VERSION}"
                                            mm       = UI.menu("Plugins")
                                            mm.add_item(menuitem) {
                                              Sketchup.active_model.select_tool LiveIvy;;IvyTool.new
                                            ###################LiveIvy;;IvyTool.load_definitions
                                            ###################LiveIvy;;Materials.ivy_materials
                                          • bigstickB
                                            bigstick
                                            Thanks Tomasz for explaining why I kept finding these leaf components in every single model!
                                            Pierreden, this is a really wonderful plugin, but it's not fully cooked IMHO. I accept that for some people it works fine, but there are lots of people still struggling with some aspects of it. For some it doesn't work at all, for others it has variable results.
                                            For me, the dialog works (it doesn't stay on top of the SU screen when I try to click to start growth, but it seems to work fine) but clicking in the model to start growth does nothing. Would it be worth creating a toolbar for this to start, and stop growth? The actual process of growing the ivy is the problematic thing for me. I have checked to see that all the required files are present, and everything seems normal. Is there some sort of debugging mode/action I can try?
                                            I don't mean to bitch, I would just really love this to work for not just me but for everyone else having difficulties. I'm very happy to help in any way I can if necessary.
                                            Context menu options to control growth might also be easier than remembering which key combinations to use. Oh, and a metric option. 😄
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 36
                                            • 37
                                            • 17 / 37
