    [Plugin] Randomize Sandbox TIN (Sep 12, 2011)
    24 Posts 11 Posters 58.4k Views 11 Watching
      Jim
      Adds some random height (Z Axis) to an existing Sandbox-created TIN (Group).
      To use, select a Group (don't "open" the Group) then select "Randomize TIN" item in the Plugins menu. It should work on any triangulated mesh.
      A dialog prompts for the Height (h). Mesh vertices are randomized between the range -h to h along the Z axis.
      The original Group is not modified, but a new Group is added in the same location as the original Group.
      2011-09-10
      • Keeps perimeter edges.
        2011-09-12
      • Works in Model units.
      • Added option to Keep/Randomize the perimeter.0082.png
      random_tin.rb
      • jujuJ Offline
        juju
        Thx for the heads-up Jim. This will make creating a water surface (amongst other things) much easier and more natural looking.
          gr8fzy1
          I downloaded this plugin, but I can't get it to function. Also, the tutorial on the site isn't working, is it hosted anywhere else?
          • numbthumbN Offline
            numbthumb
            What exactly doesn´t work? Do you have Sandbox tools enabled?
            Comfortably numb...
            • W Offline
              wyatt
              You need to select the terrain group and then run the plugin.
              • erikBE Offline
                erikB
                Thank you,
                this will come very handy for water surfaces.
                erikB
                  lapx
                  This is a great plugin. Is there something like randomize tin that will work on surfaces that have been subdivide or subdivided and smooth. I have a sculpture of a dolphin and would like it to look more rough like it has been carved out of rock. Any such ruby?
                    Panga
                    Nice One Jim. But I got a request if you don't mind... Would it be possible to keep the perimeter "untouched" in order to be able to randomize a TIN without modifying its limits ?!
                    Thanks.
                      Jim
                      Thanks.
                      I can try.
                        Perhaps if you exclude all vertices from the randomization set if they have fewer than 6 edges [that are in the selection to allow for 'island randomization'] OR perhaps if they have any edges that are not 'smooth?'...
                          Jim
                          Updated to exclude outer edges when randomizing.
                          http://forums.sketchucation.com/viewtopic.php?p=10503#p10503
                            👍 Thanks!
                              👍 Thanks Jim - I have also had this on the wish list!
                              @jim said:
                              2011-09-10
                              • Retains original edges.
                              Should it not read as "retains original perimeteredges"? If "all" edges are retained, there is no randomization.
                                Jim
                                You're welcome.
                                @gaieus said:
                                Should it not read as "retains original perimeter edges"? If "all" edges are retained, there is no randomization.
                                Yup. Fixed. Thanks.
                                  Jim
                                  Here's something I'm playing with: Drop TIN.
                                    Looks similar to my DropVertices - what will it do exactly ?
                                      Jim
                                      Satisfy my curiosity for a short time.
                                      • erikBE Offline
                                        erikB
                                        Jim,
                                        Sorry to bother you, but is it possible to let you choose if you want to keep the perimeter or let it be randomized (as it was in the first version).
                                        As I stated it is a wonderful tool to create water (for instance in swimming pools)but of course, in that case, the perimeter needs to be randomized as well.
                                        greetings, erikB
                                          Jim
                                          Updated with an option to Keep or Randomize the perimeter.
                                          See first post: http://forums.sketchucation.com/viewtopic.php?p=10503#p10503
                                          • erikBE Offline
                                            erikB
                                            Thnx Jim. It is a really useful plugin.
                                            erikB
