    [Plugin] Randomize Sandbox TIN (Sep 12, 2011)
    24 Posts 11 Posters 59.5k Views 11 Watching
      Perhaps if you exclude all vertices from the randomization set if they have fewer than 6 edges [that are in the selection to allow for 'island randomization'] OR perhaps if they have any edges that are not 'smooth?'...
        Jim
        Updated to exclude outer edges when randomizing.
        http://forums.sketchucation.com/viewtopic.php?p=10503#p10503
          👍 Thanks!
            👍 Thanks Jim - I have also had this on the wish list!
            @jim said:
            2011-09-10
            • Retains original edges.
            Should it not read as "retains original perimeteredges"? If "all" edges are retained, there is no randomization.
              Jim
              You're welcome.
              @gaieus said:
              Should it not read as "retains original perimeter edges"? If "all" edges are retained, there is no randomization.
              Yup. Fixed. Thanks.
                Jim
                Here's something I'm playing with: Drop TIN.
                  Looks similar to my DropVertices - what will it do exactly ?
                    Jim
                    Satisfy my curiosity for a short time.
                    • erikBE Offline
                      erikB
                      Jim,
                      Sorry to bother you, but is it possible to let you choose if you want to keep the perimeter or let it be randomized (as it was in the first version).
                      As I stated it is a wonderful tool to create water (for instance in swimming pools)but of course, in that case, the perimeter needs to be randomized as well.
                      greetings, erikB
                        Jim
                        Updated with an option to Keep or Randomize the perimeter.
                        See first post: http://forums.sketchucation.com/viewtopic.php?p=10503#p10503
                        • erikBE Offline
                          erikB
                          Thnx Jim. It is a really useful plugin.
                          erikB
                            Panga
                            Thanks Jim for updating the plugin !! 👍 👍
                              AcesHigh
                              [attachment=0:181cgqi8]<!-- ia0 -->0079.png<!-- ia0 -->[/attachment:181cgqi8]
                              interesting, looks kinda like a mixture of DRAPE + STAMP... or a STAMP with variable height?
                                AcesHigh
                                Could this plugin be updated, (or in the case another plugin exists, please point me out)in order for a more smooth randomization to be possible? Right now, the plugin simply changes the vertical distance of every vertex in the TIN by the amount set by the user.
                                However, it creates some artifacts often due to the normals, and even not counting the artifacts, you just can´t get a smooth random terrain, specially if you want bigger random elevation...
                                Only way I found to achieve that was repeat the process inumerous times...
                                Create a TIN with Soap Box and Bubble in a way the squares will be like let's say 2x2 meters. Apply randomize TIN with 0,7 meters of vertical displacement.
                                Notice this is a low resolution terrain... but if you want high displacement with Random TIN, you need a low res terrain, otherwise you might have two points 20cm apart, one of them 1 meter high, and the other -1m!!
                                After randomizing with high displacement a low-res terrain, then you ADD DETAIL... run Randomize TIN again, this time with smaller vertical displacement (say, 0,3 meters), add detail again, run Randomize TIN again this time with 5cm only.
                                  AcesHigh
                                  worth mentioning however that if you create a low resolution TIN and it has a complex shape (like you made it with Soap Skin Bubble, or you have cut it after stamping) you might get some problems. Therefore if the plugin had automatic smoothing either after or before creating it, it would be very good.
                                  Example... only move in the vertical vertexes that are at least 5 vertex from each other (or set a distance in meters instead of number of vertexes) and then the ones in the middle have their height calculate based on average/medians?
