Trying to export a view with curved lines
I'm trying to export a view as an autocad drawing using 2d graphic option, that has curved shapes. but sketchup doesn't export the lines which are curved. I have a bathroom interior in which my fittings are curved.
Exporting as 3d will keep curves/arcs/circles and layers etc but 2d will always reduce stuff to lines only. What's wrong with doing a 3d export ?
3d also increases cad file size isn't it So that's why i need a smart trick to export 2d graphic with all the lines.
BUT since 2d doesn't export what you want then 3d is the only option!
It's easy enough to limit what's actually exported initially under export-dialog>options... and even to erase unwanted geometry in CAD later too... -
Just put profile lines on with a thickness of 1.
Styles/edges
