    [Plugin] CleanUp
    974 Posts 217 Posters 834.3k Views 217 Watching
      OSX Users:
      Download TT_Lib 2.5.5 for a patch that will fix the empty window.
      http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
        Version 3.1.5
        Minor update to fix an internal GC issue.
          small08
          Thank-you TT, for all your hard work.
            driven
            @thomthom said:
            Version 3.1.5
            should this remove the html temp files?
              Ben Ritter
              Thank you!
                putnik
                Thank you Tom!
                http://keshas.info
                  chango70
                  Just great!
                    Clean up of Clean up! 😉
                      @driven said:
                      @thomthom said:
                      Version 3.1.5
                      No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
                      • pep75P Offline
                        pep75
                          mberger
                          Thank you.
                          I have a feature request:
                          Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
                          I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
                          Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
                          • dereiD Offline
                            derei
                            It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
                              What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                              Got sample model? And screenshot of settings?
                              • 3 Offline
                                3rdEye
                                Hmmm, strange....
                                when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                                I use SU 8 Pro, WinXP 32bit,
                                but anyway - thx again for keeping it up!
                                all the best, 3rdEye
                                • dereiD Offline
                                  derei
                                  Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                                    Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                                    • Z Offline
                                      Zacchia
                                      Tomtom
                                      Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                                        @zacchia said:
                                        Tomtom
                                        Can you open the Ruby Console before you try "Clean..." and post back any errors?
                                        • Z Offline
                                          Zacchia
                                          Same thing in office. See screenshot.
                                            My bad. I made a minor change that required an update in TT_Lib2.
                                            Version 3.1.6
                                            Updated TT_Lib requirement to 2.5.5
                                            • 48
                                            • 49
                                            • 3 / 49
