    Material Editor is a nightmare!
    21 Posts 11 Posters 3.9k Views 11 Watching
    • honoluludesktopH
      honoluludesktop
      What would it take to make it work? Organizing materials by group/component? How do other modelers do it?
        samyell77
        On Mac specifically just being able to have the list view of materials would be a massive start! This is possible on PC but not on Mac. I have about one file with multiple reds and I have to hover over each one to find out what it is. Im careful about how I name them so for instance they are called
        Acrylic Red
        Furniture Fabric Red
        Leather Red
        Illuminated Acrylic Red
        But in the browser window they all look the same so I have to hover over each one to find out what it is.
        SU Pro 2016
        Dell Precision M4800
        PC Windows 10
        Intel Core i7-4900MQ @ 2.80ghz
        Nvidia Quadro K2100M
        16gb RAM
        • O
          Openspaces
          Have you tried using the sample paint picker at the top right corner of the material box, that is, on the pc, am not sure where it is on the mac, but am sure it will be there somewhere
          • tpstigersT
            tpstigers
            Frankly, I don't think much of SketchUp's handling of materials on any level. I've gotten to the point where I only use them as 'placemarks', which I replace using another program (in this case, Bryce):
            • Terry
            “I have an existential map; it has 'you are here' written all over it”
              samyell77
              Thanks for your suggestions. The paint picker tool is fine and yes I do already use it but a list would still be far easier. I have a material library that I share with a colleague so when it comes to rendering we both have the same materials regardless which machine we are using. Because of this I load the material library when I open SU and use the materials in it to keep things consistent. The colour picker only works if the material is in the drawing and is no good for picking from a library and even if it was the issue would be the same because on Mac the name of the material is not displayed either in a list to pick from. It also isn't displayed once a material has been selected. So if I have 10 reds I HAVE to hover over each one to see which it is. I just think a list or better still a thumbnail view would be very handy and a lot quicker. The PC version of SU seems to handle this part of materials much better and it easier to use.
              As for putting materials as place markers, I get it and have done it with previous pieces of software but it adds another step into the process and Im just trying to save some time. Our clients are happy to receive SU style visuals for early concepts and it saves having to render and then re-render everything for every tiny change.
              If anyone knows of any plugins or developments on this I'd love to hear them.
              Thanks 👍
              SU Pro 2016
              PC Windows 10
              16gb RAM
                samyell77
                Just got sent this link and thought Id share it cos its certainly going to make my life easier . . . Good work TIG!
                404 Not Found
                (forums.sketchucation.com)
                SU Pro 2016
                PC Windows 10
                16gb RAM
                • Bob JamesB
                  Bob James
                  @thomthom said:
                  I agree - the material browser doesn't scale well. I've wanted a different UI myself. Made a concept graphic once: http://forums.sketchucation.com/viewtopic.php?f=180&t=26149
                  Any chance you're going to get back to this great idea?
                    I hope so, but at the moment Vertex Tools 1.1, Bezier Surface, QuadFace Tools and UV Toolkit is above it on the list. 😕
                    • Bob JamesB
                      Bob James
                      I hope they are in that order!! 🎉
                        jaceguay
                        I´ve found problematic that the material window take the focus from the sketchup main window making any sketchup shortcut not work, it´s really anoying to have to click back at the main window just to make the keyboard shortcuts work again. I really miss the old inteface...
                        My sugestion its to snap the floating window inside the main window when you want. Like the propieties window of Autocad or Layout.
                        • GaieusG
                          In fact, any dialog takes the focus of the main SU window. I also find myself fighting and curing all the time because of this feature. I would also like something (at least a possibility) like in LayOut, to dock these windows.
                            +1 !!!
                            The focus stealing dialogs are a real pain! And the material browser is the worst as it keep expanding.
                              samyell77
                              Thanks TIG for the plugin - its great and Ive been making use of it a lot so far. Im wondering tho if there is any way to view material as a list that are not in open file? I have a material library that Im wrestling (material generally seem to be a proper pain on Mac!!) and what Id like to be able to do is open a file and select material from my material library, not ones that are in the opened document - Im trying to keep materials consistent on files that are worked on by several people (some on Mac and some on PC) so that when we go to render we get the results we are expecting by keeping names consistent.
                              Am I going about this the wrong way? Is there a way to save a template file that has all the materials that I need and so I can view them using TIG's material from list script? Ideally I want to create a material library that I can view, add to and that I and my colleagues can share . . .
                              Is there likely to be any movement by Google on the material palet for mac in future releases? I know colour picker is part of the Mac OS but its so clunky compared to the PC material manager window. Being able to view materials as lists and load / save favourites is an essential feature in my eyes . . . Really really wishing I was on a PC at the moment 😞
                              SU Pro 2016
                              PC Windows 10
                              16gb RAM
                                Make a new Template is a basic thing all users should do.
                                It let's you start a new SKP with a set of premade Unit and similar Model Info settings, Scene-tabs, Styles, Layers etc etc.
                                Of course you could also include a set of commonly used Components and Materials too.
                                Just remember not to Purge the SKP until you are sure you have used all you want.
                                Another way to get a standard 'set' of materials into an existing SKP is to do this...
                                Make a new 'empty' SKP add a rectangle subdivided into say 10x10 squares- this allows 100 new materials. Use the Material Browser and apply your desired materials onto the faces.
                                Now make the faces into a component called say 'StandardMaterials#1' and use 'save_as', putting it into an accessible folder within Components...
                                Now in an existing SKP to get those 100 materials added to the model's materials simply insert an instance of the SKP. The materials will be added to the model's own set. They will then be accessible from the 'model.materials' list...
                                Erasing the instance will not remove the materials, although a full 'purge' would...
                                You can have any number of "standard materials components" that you can load like this.
                                It is not possible to 'import' SKM files from external 'libraries' using the standard Ruby API; however, I have written 'SKMtools', which does allow access to many aspects of SKM files and materials that have hitherto been inaccessible - so it would be relatively easy to use these new methods to load entire folders of SKMs etc into the model and then have them listed...
                                  samyell77
                                  Hey TIG - think I owe you a beer or two! Thanks for you help with this, very much appreciated! Will give this a try and will also have a look at SKMtools too.
                                  Cheers
                                  Sam
                                  SU Pro 2016
                                  PC Windows 10
                                  16gb RAM
