    [Ongoing-Tutorial] How to make a car using SDS/Artisan?
    Scheduled Pinned Locked Moved Organic Modelling
    36 Posts 8 Posters 26.0k Views 8 Watching
    • MarianM Offline
      Marian
      My advice would be now to select the inside wheel wells and group them. That way you'll avoid having odd geometry in that area when smoothing. You can smooth them separately later on.
      Now go ahead and stitch the side of the car. My suggestion here would be to have lines similar like in my model. What I mean is to try to have a balance of how many triangles you use and how you connect the geometry. Don't connect the whole side with only 3 or 4 triangles and don't join other geometry with one big face and not have have other lines, that's likely to happen with the side windows.
      If you followed me so far..Congrats you now have a crap model of a car 😄 And now we can see how our car looks Smoothed for the first time. Still crap but it's smooth crap 😎
      I've also attached the SU model here so you guys can have a look.
      If you look closely at the picture with the smoothed car you can see that at the middle bottom part in the front the geometry is split. That's because there's a corner which is not connected to any other geometry in the component. To correct this kind of behaviour when smoothing geometry you have to use the crease tool. Look at your SDS/Artisan toolbar and find the crease tool. It lets you have vertices and lines which will remain in the same place when smoothing. The crease tool will be an important tool so remember it and use it well.
      At this stage it's the time to make any major modification to the design, when the mesh is relatively simple and you don't have to delete much geometry.
      SDS.skp
      • mitcorbM Offline
        mitcorb
        Hi, Marian:
        It's looking good. Are you keeping progress images as you proceed with the development, or did I miss that?
        Edit: I am thinking you would want to keep skp's of all the steps for future reference and/or publishing?
        • MarianM Offline
          Marian
          Hi,Mitcorb. Yes I post images as I proceed. The car is now in the same state as shown above
          I normally don't keep any files up until I have the car fully stitched.
          After that I save separate files for most versions in both low poly and smoothed. Take a look at some versions of my cars here http://www.deviantart.com/download/150756465/Sunbeam_Evolution_by_Marian87.jpg or the more up to date video http://www.youtube.com/watch?v=gomKM8wGUII and here http://www.deviantart.com/download/152264013/AXA_Evolution_by_Marian87.jpg
          • MarianM Offline
            Marian
            As I said above now is the best time to modify the design, it depends on each of you the direction in which you want to take the design.
            Because editing vertices is especially important for tweaking these kinds of cars I'll go over how you do that with SU in case some of you didn't know it can be done. Use the move tool over vertices until a green dot appears, then click and hold and move it in the direction you want.
            Another important aspect of modelling for SDS is the concept of "doubling" lines to have crisper lines once smoothed. In some cases you'll need to triple the lines to get an acceptably crisp line.
            Select the geometry along the line you wish to double make it into a group, then select only the lines and move them to the side a bit or up or down depending on the mesh. After doing this you can explode the group and start stitching the gap. Now you can see the difference in the smoothed mesh.
              deanlegg
              Here's another try, just need to add windows etc
              sds lambo.skp
                deanlegg
                Windows and ducts in
                Can anyone tell me the little problem on the hood?
                sds lambo.skp
                • MarianM Offline
                  Marian
                  The problem on the hood is related to what I said a few posts up. Look for he NO and YES picture hope that makes it clear. You should connect all lines and not let them connect in the midlle of a face like you have on your hood.
                  • MarianM Offline
                    Marian
                    Today we'll be addressing the issue of how to keep edges square on ducts, inlets, concave openings etc.
                    In the example I used I made opening in the back of the car. The first steps are similar to how we "doubled" the lines. Select/group/move lines/ungroup and stitch. Also remember that if you want crisp edges you'll have to double the outside and inside ones.
                    In some places doubling is not enough to keep the corners crisp, or the shape square. To fix this you have to cut the corners like in my pics below. Imagine that you take a square and cut its corners and make it into a hexagon, that the process here. You'll also have to tweak, fiddle and delete some lines around the corners in order for the shape to smooth correctly. You can control how crisp those corners become after smooth by bringing the lines in the corner close together.
                    That holds true in most all cases of doubling, the closer the lines are the sharper the smoothed outcome.
                    SDS.skp
                      lapx
                      Marian,
                      Thanks for your tutorial! I'm following along. How do you create your double lines? Do you use a front and rear imgage as well?
                      • MarianM Offline
                        Marian
                        • MarianM Offline
                          Marian
                          Sorry I didn't answer this one until now, I was in hurry last time.
                          Simply put, no, I don't use anyother pictures for the front and back. That's because using this method you are not making an accurate representation of an existing car. It is meant to make it easier to start modeling a car, but nobody says you can't do it differently. This is the way it works for me but I encourage you to experiment or use other methods.
                          • MarianM Offline
                            Marian
                            Some more progress. Not much to explain here. I just doubled the lines more so the shapes make more sense.
                            SDS.skp
                            • MarianM Offline
                              Marian
                              I did some more work on this, nothing big, just some tweaks.
                              SDS.skp
                              • MarianM Offline
                                Marian
                                Some more progess.
                                I'm not sure if all of you who watch this thread understand what and how I do stuff, so please ask any questions you may have.
                                SDS.skp
                                • MarianM Offline
                                  Marian
                                  I made some more tweaks and drew in the shapes for the door, hood and trunk lid.
                                  SDS.skp
                                  • MarianM Offline
                                    Marian
                                    Another step forward.
                                    SDS.skp
                                      rappsnitches
                                      how do you make the windows so that they are colored differently??? thanks for this btw its awesome
                                      • MarianM Offline
                                        Marian
                                        You select the paint tool, choose a color and then just clik on the surfaces you want to be colored.
                                          rspierenburg
                                          But make sure you have 'Show Hidden' turned on.
                                            rappsnitches
                                            I don't have the new artisan, i have the old one....do you know how to do it then?
