    [Ongoing-Tutorial] How to make a car using SDS/Artisan?
    Scheduled Pinned Locked Moved Organic Modelling
    36 Posts 8 Posters 26.4k Views 8 Watching
      deanlegg
      Here's another try, just need to add windows etc
      sds lambo.skp
        deanlegg
        Windows and ducts in
        Can anyone tell me the little problem on the hood?
        sds lambo.skp
        • MarianM Offline
          Marian
          The problem on the hood is related to what I said a few posts up. Look for he NO and YES picture hope that makes it clear. You should connect all lines and not let them connect in the midlle of a face like you have on your hood.
          • MarianM Offline
            Marian
            Today we'll be addressing the issue of how to keep edges square on ducts, inlets, concave openings etc.
            In the example I used I made opening in the back of the car. The first steps are similar to how we "doubled" the lines. Select/group/move lines/ungroup and stitch. Also remember that if you want crisp edges you'll have to double the outside and inside ones.
            In some places doubling is not enough to keep the corners crisp, or the shape square. To fix this you have to cut the corners like in my pics below. Imagine that you take a square and cut its corners and make it into a hexagon, that the process here. You'll also have to tweak, fiddle and delete some lines around the corners in order for the shape to smooth correctly. You can control how crisp those corners become after smooth by bringing the lines in the corner close together.
            That holds true in most all cases of doubling, the closer the lines are the sharper the smoothed outcome.
            SDS.skp
              lapx
              Marian,
              Thanks for your tutorial! I'm following along. How do you create your double lines? Do you use a front and rear imgage as well?
              • MarianM Offline
                Marian
                @marian said:
                Select the geometry along the line you wish to double make it into a group, then select only the lines and move them to the side a bit or up or down depending on the mesh. After doing this you can explode the group and start stitching the gap.
                • MarianM Offline
                  Marian
                  Sorry I didn't answer this one until now, I was in hurry last time.
                  Simply put, no, I don't use anyother pictures for the front and back. That's because using this method you are not making an accurate representation of an existing car. It is meant to make it easier to start modeling a car, but nobody says you can't do it differently. This is the way it works for me but I encourage you to experiment or use other methods.
                  • MarianM Offline
                    Marian
                    Some more progress. Not much to explain here. I just doubled the lines more so the shapes make more sense.
                    SDS.skp
                    • MarianM Offline
                      Marian
                      I did some more work on this, nothing big, just some tweaks.
                      SDS.skp
                      • MarianM Offline
                        Marian
                        Some more progess.
                        I'm not sure if all of you who watch this thread understand what and how I do stuff, so please ask any questions you may have.
                        πŸ˜„
                        SDS.skp
                        • MarianM Offline
                          Marian
                          I made some more tweaks and drew in the shapes for the door, hood and trunk lid.
                          SDS.skp
                          • MarianM Offline
                            Marian
                            Another step forward.
                            SDS.skp
                              rappsnitches
                              how do you make the windows so that they are colored differently??? thanks for this btw its awesome
                              • MarianM Offline
                                Marian
                                You select the paint tool, choose a color and then just clik on the surfaces you want to be colored.
                                  rspierenburg
                                  But make sure you have 'Show Hidden' turned on.
                                    rappsnitches
                                    I don't have the new artisan, i have the old one....do you know how to do it then?
                                    • MarianM Offline
                                      Marian
                                      The old one is as good as the new one for this tutorial. The new one has a few more tools but are not used here.
                                        rappsnitches
                                        Where can i find show unhidden?
                                          rspierenburg
                                          Sorry its just called 'Hidden Geometry' in the 'View' Menu. It will show all the hidden lines as dotted and you will be able to select each -piece- of face individually and paint them.
                                          Rob
                                          • MarianM Offline
                                            Marian
                                            A slightly improved version, design wise, by Ely862me.
                                            SDS e.skp
