    Cannot open big file 340Mb
    25 Posts 7 Posters 7.0k Views 7 Watching
      dparadinha
      the link is here:
      http://dl.dropbox.com/u/13163745/neuch_ville_sketchup_Arbre_sans_mobilier_urbain.zip
      i guess the big size is due to excessive use of textures in the model, if there was a way to open partly a file (like in autocad)...
      • soloS Offline
        Hmmm, opened easy enough.
        • TIGT Online
            dparadinha
            humm maybe is this computer after all...
            i'll open on another pc...
            thnk you for helping
            regards
            • brodieB Offline
              brodie
              Maybe give this a shot. Just ran a cleanup script on it real quick and saved it. You're opening in SU 8 right?
              http://dl.dropbox.com/u/384281/neuch_ville_sketchup_Arbre_sans_mobilier_urbain%202.skp
              (it's still uploading so if it doesn't work try again in a bit)
              -Brodie
                dparadinha
                thanks brodie, but when i got home i tried to open it on another (slower) computer and it opened just fine...
                so i made a purge and saved it again, ti work on it next week!
                maybe i'll reinstall sketchup on work, as it didn't open there...
                tnks a lot for everyone who helped,
                regards and nice weekend
                  mac1
                  Solo
                  Are you using 64 bit version of W 7 or 32 and how much RAM. I have XP( 4GB RAM) and of course SU 32 bit and playing with paging file to see If I can sneak buy and open. Have not tried the 3GT option of XP yet.
                  Setting PF at max the commit charge (PF) in task manager hits the 2G limit an throws an error message of cannot open file. The reason for this is the windows memory manager takes the 32 bit addressable space ( 4GB) and allocates 1/2 for processes and the other for the kernel thus the 2GB limit. The W7 64 version ,SU using 32 bits still, allows the use of 4GB of your memmory for processes and the reason you can open.
                  Thanks for any info
                  • soloS Offline
                    I'm running Windows 7 64 bit, on an i7 with 12GB ram.
                      mac1
                      Thanks. If I understand correctly this means SU can address 4Gb ( 2^23) and the memory manager allocates all of this to the SU process where as us poor folks with the 32 bit systen only get 2GB.
                      BTW FYI & what it is worth I get a difference if I drag and drop the file on SU8. Drag it kicks out at a commit charge of 2.14 GB but if I open within SU 8 in drops at 3.14GB
                      Humm>= the 3G tunning allows the process to use an extra 1GB of RAM so it looks like SU 8 operates differently vs how you start the program??
                      Wonder what John B says about that??
                      • TIGT Online
                        Although Sketchup is a 32bit program it can use up to 4Mb of the available RAM on a 64-bit system [version 8 has a large-address-aware option - see here for discussion http://forums.sketchucation.com/viewtopic.php?f=80&t=34299 ].
                        On a 32-bit system the maximum RAM that is ever used is ~3.35Mb even if 4Mb is available.
                        Since the OS itself and other programs that you might have running from startup will use a good chunk of that you're luck if Sketchup has 2Mb available.
                        I opened this mega-SKP o a 32-bit 4Mb RAM PC - it took a while to display and it was as slow as a snail but it opened. Sketchup was using all available RAN ~2Mb [I had closed all non-essential apps beforehand]...
                        So whilst Sketchup is not [yet] a 64-bit program it can use considerably more RAM on a 64-bit system if it's available
                          mac1
                          Agree but for 32 bit system and 4GB ram SU does not get to use all that RAM. The memory manager allocates 1/2 to the process and the other half goes to the kernel. Programs do not get direct access to the RAM but instead virtual memory is used to map into ramSu8 Virtual Memory Map- Open file no model.jpg
                          FYI this is a virtual memory map of my system of Su8 free opened with no model
                          Here is a link you will find interesting http://blogs.technet.com/b/markrussinovich/archive/2008/11/17/3155406.aspx
                            mac1
                            Intel p4 3.2GHZ, Intel PERL 865 Mother board, 4GB RAM, Win XP Pro sp3
                            File opened by by changing the Boot.ini to include the /3GB switch that allows SU 8 to use 3GB RAM vs 2GB as normally or what is called "Large Block Address Aware" WIN XP Pro is an "opt in"to enable and this is not automatic unless you manually make this change. This is not available in the WIN XP OEM version. Max RAM usage peaked at about 2.8GB and of course the orbits etc will be slow. Have not done any work on file size reduction but it appears the background is a large photo texture and if that is deleted file size will reduce drastically. This would allow work on the model without all the slowness and model size??Large File.jpg
                              mac1
                              Texture image question.
                              To reduce file size one would would to attack the large contributors first. This means for the image texture I would like to find the skm files because it will have size noted.
                              I cannot not find the file. Does one have to make a collection first??
                              Stepping texture by texture through the material editor is too time consuming 👊
                                Export the model to collada. Textures will be exported in a separate folder where you can immediately spot the culprit. With Pro, fbx or similar is even better as it will not rename image files.
                                  mac1
                                  Thanks will look at that.
                                  This model is loaded with image texture files as you would guess and some as high as 4000 pix and is modeled on the inside of a sphere. Maybe that is standard but I have not seen that but usually don't do this type. Its size( 350MB) is only about 1/2 or less of the model. It has many " boxes" made but they need texture added.
                                  16 AUG Update
                                  One can make a new collection using the material browser. This then gives a file model material name and size folder so one can find the large contributors. The down side is one cannot print that from windows explorer but must be done from command propt if you want to print more than just file name. bummer 👎
                                  The file size is 160MB but don't know how that correlates to model size contribution??
                                    mac1
                                    @dparadinha said:
                                    Hello!
                                    I have a skp file of 340Mb (version 8), which sketchup cannot open - it says 'failed to open document' everytime...
                                    my system is a quadcore, 4gb ram, >1gb NV GT220 graphic board.
                                    the file displays the site for a competition, and i really need to open it... should i download it again (could be a problem related to the download) or a 340Mb file should be open on a faster/more Ram machine?
                                    regards,
                                    diogo
                                    I have given info herein how to open. The 4Gb RAM is not enough unless you can set your system to the 3GB switch. Even if you open then what?? All operations will be very slow and will be virtually unusable to you. There is a massive use of material files that is a major contributor to your problem like 245 files at 162,608,425 bytes. I would normally try to help reduce file size but this would require major effort and I cannot spend time on now. The only suggestion I have is to split out the three major SK_XX components and see if could help you. You very well may have to address the material issue even with them.
                                    Let me know if you want to try and follow that route and I'll see if I can get them to you??
                                    BTW are you the model creator? The reason I ask is because even though some materials do not show as texture files looking at the details shows them using a jpg as ref and xml to create which should be at most in the 50k range and some are as high as 3MB. Where did they come from??
                                    • V Offline
                                      valerostudio
                                      That's an insane file size. I was working with a 120MB file one time and that was about the max at SU could work with. I can't imagine working with a 300+MB file in SU.
                                        mac1
                                        @dparadinha said:
                                        Hello!
                                        regards,
                                        diogo
                                        Update for you. Have not seen any new post so assume you are no longer interested.
                                        Purged unused materials and model size dropped to 344 MB, mine started at 360;
                                        Edited 18( there are many more to edit) textures reducing pixel resolution from around 2500 to 1024 pixels each. File size down to 314 MB;
                                        Purged unused components and file size dropped to 189 MB( 198,637,699 bytes). However it appears texture lost form a number of "boxes"??
                                          dparadinha
                                          hello to all,
                                          as i had to work on this file, i've openned it on a 64bit pc and 'broke' it in small pieces - then i removed all building materials, join it all again, now its fine.
                                          later when preparing final renders i'll export to collada to reduce texture sizes, but right now i prefer everything in white...
                                          regards,
                                          diogo
