    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • massimoM Offline
      massimo Moderator
      http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html πŸ˜„
      • dereiD Offline
        derei
        Thanks one thousand times! β˜€
        • dereiD Offline
          derei
          There are also two buttons: Assign to Material and Get from Material. They seem to do nothing, but I'm sure that they do. I just don't know how to use them.
          How to apply texture on created faces? That buttons are related to this? Don't tell me that I must apply texture on every shape created 😲
          Thanks.
            boestin
            First of all i would like to say thanks to the person who is responsible for this magnificent peace of art.
            The tool works wonderful, but i'm facing some errors. Hopefully someone will be able to help me out.
            Problem 1:
            The grass or fur is always facing downwards, in other words: upside down. It doesnt matter what i do, its always this way.
            Problem 2:
            Somehow, the color is black and white. I was hoping to see the grass turning green.
            Thanks!!
              Hi Boestin,
              In case 1: is the surface you want to run the plugin on a back face or a front face?
                boestin
                Hello Gaieus,
                Thank you for you reply.
                I dont know how I can check that, I am almost sure that it is the top side because when I draw a rectangle, select it and generate fur on this I am in the Top view camera.
                  When you draw a rectangle on the red/green plane, its back face (blue colour) is showing up by default. Right click and reverse faces to change that and now the front face (white) will show upwards.
                  I am not sure this is the problem but I can imagine.
                    boestin
                    Thanks Gaieus!! That was the problem
                    You made my day!!
                      sectionaa
                      @fletch said:
                      JC,
                      Does THIS help at all?
                      http://twilightrender.com/phpBB3/download/file.php?id=3803
                      Very useful indeed.
                      There must be a variable not shown in settings dialog which controls rotation on a specified axis.
                      (The default effect is visible in the road signs image).
                      It would be a great benefit to have that variable available, and a "jitter" control.
                      But the author has done a fantastic job.
                        sectionaa
                        @gaieus said:
                        Yeah. Though already a minority of the countries, still "the sun never sets over the countries that drive on the left".
                        πŸ˜„
                        And of course the land of the rising sun drives on the left.
                        • brodieB Offline
                          brodie
                          I downloaded the plugin and extracted it to my plugins folder (SU 😎 and now get a runtime error anytime I open SU. Anyone else have this issue or have a solution?
                          -Brodie
                            Taavi K
                            I ran into small problem. What can I do to lose that ... problem?
                              sesil5
                              goodmorning!! i need your help!
                              How can i download this plugin?
                                Hi Sesil,
                                It is posted as an attachment at the bottom of the first post.
                                  sesil5
                                  @gaieus said:
                                  Hi Sesil,
                                  Hi Gaieus, i found the zip file but it doesn't contains any runfile for installation. Sorry for my English,i'm from Greece.
                                  Nevertheless, thank you very much.
                                    SketchUp plugins are 8mostly) simple text files with an rb (for "ruby") extension. All you need to do is to extract all the content and then copy everything into the plugins folder of SketchUp which is by default (on a 32 bit windows) here:
                                    C:\Program Files\Google\Google SketchUp 8\Plugins\
                                    Also, here is a sticky post about the installation of zipped plugins:
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                      sesil5
                                      It's work!!! Thank you very very much. I use some other plugins like omnigrid plugin and it was necessary to make an installation. I think that i'm comfused about the programms and the plugins!!!!
                                        dirtypr
                                        This is great!
                                          brokenstaral
                                          awsome!!
                                          so simple and easy to operate!!
                                          This is by far one of the best and most useful plugins I have ever seen !!!!!
                                          • U Offline
                                            uzairazam
                                            i am unable to create furs....when i click make fur....nothing happens....what is wrong with it plz help?
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 31 / 33
