    [Plugin] Shell
    93 Posts 33 Posters 61.7k Views 34 Watching
      I expect a cookie in 1:1 scale to that photo in my mail
      • EarthMoverE Offline
        EarthMover
        Looks interesting. Thanks Thom! πŸ‘
        Content Creator at Skapeup
        • utilerU Offline
          utiler
          You're da bomb, Thom!!!!
          Have been feeling for your countrymen of late, mate.... πŸ‘
          Just Curious...
            driven
            hi Thomas,
            would it be ok to change the menu name to 'tt_shell' as it needs to be unique to use a mac system shortcut key and Jim's simple shell uses 'shell' in the SU menu already...
            it also turned off all my other toolbars [except 'booleen helper' and SU ones] when I first loaded/ran it.
            never had that happen before...
            I'll do some testing tonight.
              You can edit line 40 to change the menu name.
              There is nothing in the plugin's code that modifies other toolbars. It doesn't even add one itself.
              Did it cause any errors when you loaded the first time?
                driven
                yes,
                it failed on one particular group and generated error messages, so I'd make something less something less complex, but I noticed all my toolbars had gone.
                I turned the same ones back on restarted SU, used tt_shell again and they were fine...
                I get non planar faces errors on things that JPP works on.
                I'll have a proper look later
                  Can you give me a sample model?
                    driven
                    hi thomas,
                    here's something similar that fails tt_skin, but works for JPP.
                    the lavender one is jpp'd.
                    Also, the disappearing toolbars are from TIG's new DAE exporter, which uses
                    Sketchup.send_action('terminate:')
                    which 'disappears' the toolbars and was the last thing that I had used before I installed this.
                    tt_skin_test.skp
                      Cheers for the model!
                      • StinkieS Offline
                        Stinkie
                        OK, I'll ban you later πŸ‘
                        πŸ˜†
                        Thanks, Thomas!
                        • N Offline
                          nomeradona
                          this is the one im waiting for. I requested for this before but many keep on pointing joint push pull. thanks thomas..
                            jorge2011
                            Hi thom, This plugin generates a small error, you can fix that
                            Error: #<ArgumentError: Points are not planar>
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in shell'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in shell'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:321:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in each'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:173:in onReturn'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:420
                            • jeff hammondJ Offline
                              wow 😲
                              i missed this one..
                              gonna test it a little later tonight.
                              thanks thom
                                Ah, yea. There are bugs in this plugin. Hence the Alpha status of the version number. Though I've not had any time to work on it recently.
                                  robert111
                                  mr thomthom
                                  when i make group for this form , i and i use shell plugin , i have this stroange message
                                    That error message is not something I've put into Shell. I have no idea where it's coming from. Exactly what is the steps you do to produce that? (Can you also share the model along with the steps?)
                                      j_forrester
                                      Is it possible to shell but keep the return from the original geometry. I have tried with JPP too but seems to fall down when you try it with and opening with single extruded returns.
                                      Many thanks
                                        The generated geometry is created in a separate group - if that is what you mean..?
                                          robert111
                                          i post my file and vedio for this bug
                                          bug00.rar
                                          shell bug.rar
                                            4.6MB for that.skp 😲
                                            one word:
                                            PURGE πŸ˜„
                                            model info -> statistics -> purge unused.
                                            gets it down to around 150kb
                                            • 5 / 5
