    What's the best way to flatten some geometry lines
    21 Posts 8 Posters 18.5k Views 8 Watching
    • Bob JamesB Offline
      Bob James
      I'd wondered if Vertex tools might have an option. Does anyone know for sure?
      I'll have to take a look at stamp for the plateau, I haven't used it in a long time. -Brodie
      I use Vertex Tools quite often. It can solve your plateau need. You select all of the vertices to be involved in the plateau, then select the "put all vertices onto the same plane". Unfortunately, the resulting plane may not be horizontal. In that case you use the rotate function of VT. (TT said at one time he was thinking of making that a choice automatically).
      Seems like you could also select all of the grass edge vertices, put into the same plane and then move them all down to match the sidewalk. (Which will become easier when TT adds a gizmo πŸ˜† )
      • brodieB Offline
        brodie
        Bob, thanks. Is it possible within VT to select a group of vertices and use the scale tool on them? In effect, scaling them down in the Z axis by .00001?
        -Brodie
        • EarthMoverE Offline
          EarthMover
          You can select each row of edges and use ThomThom's Edge tools to make them colinear on the Z axis. Or using Vertex tools, select the whole mesh and use Make Planar. Or Artisan's Make Planar and choose the XY axis. Also ThomThom's Flatten Script will do it on click as well.
          Select all the verts and using VT to scale them down on the Z will decrease the overall size.
          Content Creator at Skapeup
          • brodieB Offline
            brodie
            ThomThom's flatten script would create extra geometry which isn't what I'm going for (see images above).
            Edge tools seems to make the lines planer but not on a horizontal plane which is quite important. It also only seemed to work on one straight segment at a time (ie. for the image above I had to run the script 4 times, once for each side). I end up with the same problem I had originally.
            From what I can tell Vertex tools works the same way, however maybe it allows me to scale those edge vertices in the Z direction to make them on the same horizontal plane?
            I don't know anything about Artisan's tools. Anyone familiar with it that can confirm that it does what I'm looking for?
            -Brodie
            • brodieB Offline
              brodie
              Just downloaded the Artisan trial. It does indeed do what I was looking for. Vertex Tools might be better though if I could make the points along the edge horizontal along with it's soft selection so there would be a nice easy transition.
              -Brodie
                Seems to me that the Move tool can bring the edges down to the level of the sidewalk and Sandbox tools would handle the plateau.
                You don't even need the Sandbox tools. You could create the plateau with Intersect.
                  I think Brodie's aim is to select the boundary edge and snap them all to another boundary that lies level with Z.
                  I notice that Thomthom's edge tool work to a point. They don't level the straightened edges. But that only leaves a quick rotation on each edge.
                  I'm gonna look at more plugins to see if this is hidden somewhere?
                    You could be right. Still it took little time to just do it and get it over with. πŸ˜‰
                    • brodieB Offline
                      brodie
                      The move tool works but on a large grass area it becomes cumbersome. On my project I had a patch which contained about 60 vertices which needed to be moved. Not insurmountable but certainly a good opportunity for some ruby help.
                      The intersect tool would work except I'm also trying to maintain some good topology as I'm considering running a noise modifier over the object in 3ds max (so the plateau would start flat in SU but end up being slightly wavy after the noise modifier - if the geometry is made of a single large plane rather than a bunch of small quads or triangles then that becomes difficult.
                      -Brodie
                        EarthMover
                        I think I misunderstood what you wanted to do. I thought you just wanted to flatten it out.
                        Are you trying to do something like this?
                        [flash=800,600:1twzfjd5]http://www.youtube.com//v/9J-GMg1t9e0[/flash:1twzfjd5]
                        What would interesting is if someone could write a plugin that would do a "Vert Drop" Essentially letting you drop all verts in a selection to a specified z plane.
                          Bob James
                          Looks like a winner to me: as I understand the need.
                          • TIGT Online
                            Here is my new 'dropverts.rb' http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
                            You can drop the vertices of selected edges to the 'Nearest Object', 'Lowest'[in selection], 'Highest'[in selection] and to 'Z=? [specified in a dialog] πŸ˜„
                            • PixeroP Offline
                              Pixero
                              My jsAlign script can also do this: http://forums.sketchucation.com/viewtopic.php?f=323&t=20080&p=166929
                              • brodieB Offline
                                brodie
                                Inundated with help! That looks to be just the thing. I'll give it a shot on monday. Thanks for the help.
                                -Brodie
