    Geodesic Gear Sphere
    28 Posts 19 Posters 6.3k Views 19 Watching
    • TaffGochT
      TaffGoch
      ย
      I did this to demonstrate that a proper arrangement of gears, in a sphere, could, indeed, rotate.
      There was some conjecture (in another forum) that the counter-rotation of gears would be locked. Truly, if three adjacent gears were meshed together, then the whole system would lock-up. This image settles the argument! "A picture is worth a thousand words."
      Producing the proper association, of a gear and it's neighbors, will ensure that it won't be a locked system.
      ~Taff
      "Information is not knowledge." -- Albert Einstein
        Very nice work.
        • B
          bob-designer
          Very interesting, what else wound I expect from you?
          Can you make it expand and contract, change colors?
          • C
            castromann
            there has to be a lot of thinking behind this one. i saw your geodiscs and models in the warehouse before. where does your addiction to geodiscs come from - seems like your obsessed by these ๐Ÿ˜‰
            • boofredlayB
              boofredlay
              @pixero said:
              Wow. Amazing. It's almost hypnotic. ๐Ÿ˜ฒ
              Indeed. I just sent you the money you demanded as well ๐Ÿ˜ฒ ... can't ... look ... away ... ๐Ÿ˜ฒ
              • TaffGochT
                TaffGoch
                I beg your pardon! - OBSESSED ? ๐Ÿ˜ฎ
                I rather prefer "enamored," if you don't mind.
                ( "Smitten," "enchanted," "infatuated" or "enraptured" will also do )
                ~Taff
                It's been 40+ years of fascination with the geometry & mathematical derivation of the elements of geodesic domes, which used to be closely-guarded proprietary information.
                • TaffGochT
                  TaffGoch
                  @bob-designer said:
                  Very interesting, what else would I expect from you?
                  If you do a quick check of my online history, you'd then know "what," indeed.... ๐Ÿ˜„
                  • TaffGochT
                    TaffGoch
                    I just sent you the money you demanded as well...
                    So, the subliminal programming worked, then. ๐Ÿ˜
                    Mwah-ha-haaaa... ๐Ÿ‘ฟ
                      Slimdog
                      Nicely done. Color me impressed.
                      How do all the axles come together in the middle?
                      Where does the drive motor fit in?
                      So no sketchy physics plugin was used?
                      • mitcorbM
                        mitcorb
                        I salute your legendary talent. ๐Ÿ‘ ๐Ÿ‘ And, congratulations on that solution.
                        • TaffGochT
                          TaffGoch
                          @slimdog said:
                          How do all the axles come together in the middle?"
                          It's a virtual model -- so, no axles. ๐Ÿ˜‰
                          Where does the drive motor fit in?"
                          It's a virtual model -- so, no motor. ๐Ÿ˜„
                          So no sketchy physics plugin was used?"
                          So, no.... ๐Ÿ˜„
                          If I were to physically build this, as a sculpture, I'd use an internal geodesic frame/cage, where I'd mount 92 short axle "spindles," pointing outward, at the geodesic vertices.
                          Only one gear would need to be powered, as all the rest would be "pushed" by that one gear.
                          Mounting an electric motor, hidden inside the cage, would be trivial.
                          How to keep kids from sticking their fingers in the gears - now, THAT would be a problem. (I suppose, the adults, too.)
                          ~Taff
                          • jamalitoJ
                            jamalito
                            it is wasome
                            Albert Einstein:
                            ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                            • K
                              KarinaGM
                              YOU ARE SICK!
                              I'm loving it!!! ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
                              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarรก perdiendo ambas"
                              -Benjamรญn Franklin.**
                              • omiKronO
                                omiKron
                                This engine could spin the Earth forever ! Just.. speechless, awesome work ๐ŸŽ‰
                                • C
                                  castromann
                                  ~Taff
                                  haha! ok i will keep that in mind. whatever your "relationship" with these is - this is simply great and fascinating work
                                  • TaffGochT
                                    TaffGoch
                                    ย
                                    A simplified SketchUp model is available:
                                    Gears Ball- 3D Warehouse
                                    %(#BF0000)[(Clickable image-link, to deviantART๐Ÿ˜ž]
                                    http://fc00.deviantart.net/fs70/f/2011/209/8/9/92_gears___animation_study_by_taffgoch-d41pt63.gif
                                    ~Taff
                                    • N
                                      notareal
                                      Hypnotic! ๐Ÿ˜ฒ
                                      • G
                                        Goonster
                                        This is superb!
                                        I wondered the same thing as slimdog when I saw this though. Where would the gears meet and what could be powering it? ( just a thought)
                                        • daleD
                                          dale
                                          Cool indeed!
                                          Great to see more of your amazing work.
                                          • TaffGochT
                                            TaffGoch
                                            ย
                                            I'm gratified that you folks are liking this.
                                            I've decided to embark upon striving to learn Adobe Flash. As my first production, I converted this particular animated-gif into an animated-flash (adding sound, as "lagniappe.")
                                            (Clickable image)
                                            http://fc06.deviantart.net/fs70/i/2011/218/d/c/92_gears___flash_animation_by_taffgoch-d45huow.gif
                                            I am, right away, impressed with Flash. The SWF-animation has much-higher color resolution (24-bit), yet the jpeg-compression can be adjusted to produce a file no bigger than the animated-GIF. 'Looking forward to learning more about Flash.
                                            -Taff
