Geodesic Gear Sphere
Wow. Amazing. It's almost hypnotic.
that is really cool.
Will that be in stores for Christmas? I want one!
Ooooh!!
That's brilliant.
ย
I did this to demonstrate that a proper arrangement of gears, in a sphere, could, indeed, rotate.There was some conjecture (in another forum) that the counter-rotation of gears would be locked. Truly, if three adjacent gears were meshed together, then the whole system would lock-up. This image settles the argument! "A picture is worth a thousand words."
Producing the proper association, of a gear and it's neighbors, will ensure that it won't be a locked system.
~Taff
Very nice work.
Very interesting, what else wound I expect from you?
Can you make it expand and contract, change colors? -
there has to be a lot of thinking behind this one. i saw your geodiscs and models in the warehouse before. where does your addiction to geodiscs come from - seems like your obsessed by these
Indeed. I just sent you the money you demanded as well
... can't ... look ... away ...
I beg your pardon! - OBSESSED ?
I rather prefer "enamored," if you don't mind.
( "Smitten," "enchanted," "infatuated" or "enraptured" will also do )
~Taff
It's been 40+ years of fascination with the geometry & mathematical derivation of the elements of geodesic domes, which used to be closely-guarded proprietary information.
@bob-designer said:
Very interesting, what else would I expect from you?
If you do a quick check of my online history, you'd then know "what," indeed....
I just sent you the money you demanded as well...
So, the subliminal programming worked, then.
Mwah-ha-haaaa...
Nicely done. Color me impressed.
How do all the axles come together in the middle?
Where does the drive motor fit in?
So no sketchy physics plugin was used?
I salute your legendary talent.
And, congratulations on that solution. -
@slimdog said:
How do all the axles come together in the middle?"
It's a virtual model -- so, no axles.
Where does the drive motor fit in?"
It's a virtual model -- so, no motor.
So no sketchy physics plugin was used?"
So, no....
If I were to physically build this, as a sculpture, I'd use an internal geodesic frame/cage, where I'd mount 92 short axle "spindles," pointing outward, at the geodesic vertices.
Only one gear would need to be powered, as all the rest would be "pushed" by that one gear.
Mounting an electric motor, hidden inside the cage, would be trivial.
How to keep kids from sticking their fingers in the gears - now, THAT would be a problem. (I suppose, the adults, too.)
~Taff
it is wasome
YOU ARE SICK!
I'm loving it!!!
This engine could spin the Earth forever ! Just.. speechless, awesome work
~Taff
haha! ok i will keep that in mind. whatever your "relationship" with these is - this is simply great and fascinating work
ย
A simplified SketchUp model is available:
Gears Ball- 3D Warehouse%(#BF0000)[(Clickable image-link, to deviantART
~Taff
Hypnotic!
With your input, this post could be even better ๐
