    Geodesic Gear Sphere
    28 Posts 19 Posters 5.6k Views 19 Watching
    • TaffGochT Offline
      TaffGoch
      @bob-designer said:
      Very interesting, what else would I expect from you?
      If you do a quick check of my online history, you'd then know "what," indeed.... 😄
      "Information is not knowledge." -- Albert Einstein
      • TaffGochT Offline
        TaffGoch
        I just sent you the money you demanded as well...
        So, the subliminal programming worked, then. 😍
        Mwah-ha-haaaa... 👿
          Slimdog
          Nicely done. Color me impressed.
          How do all the axles come together in the middle?
          Where does the drive motor fit in?
          So no sketchy physics plugin was used?
          • mitcorbM Offline
            mitcorb
            I salute your legendary talent. 👍 👍 And, congratulations on that solution.
            • TaffGochT Offline
              TaffGoch
              @slimdog said:
              How do all the axles come together in the middle?"
              It's a virtual model -- so, no axles. 😉
              Where does the drive motor fit in?"
              It's a virtual model -- so, no motor. 😄
              So no sketchy physics plugin was used?"
              So, no.... 😄
              If I were to physically build this, as a sculpture, I'd use an internal geodesic frame/cage, where I'd mount 92 short axle "spindles," pointing outward, at the geodesic vertices.
              Only one gear would need to be powered, as all the rest would be "pushed" by that one gear.
              Mounting an electric motor, hidden inside the cage, would be trivial.
              How to keep kids from sticking their fingers in the gears - now, THAT would be a problem. (I suppose, the adults, too.)
              ~Taff
              • jamalitoJ Offline
                jamalito
                it is wasome
                Albert Einstein:
                ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                  KarinaGM
                  YOU ARE SICK!
                  I'm loving it!!! 🎉 🎉 🎉
                  **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                  -Benjamín Franklin.**
                  • omiKronO Offline
                    omiKron
                    This engine could spin the Earth forever ! Just.. speechless, awesome work 🎉
                      castromann
                      @taffgoch said:
                      @castromann said:
                      there has to be a lot of thinking behind this one. i saw your geodiscs and models in the warehouse before. where does your addiction to geodiscs come from - seems like your obsessed by these 😉
                      I beg your pardon! - OBSESSED ? 😮
                      I rather prefer "enamored," if you don't mind.
                      ( "Smitten," "enchanted," "infatuated" or "enraptured" will also do )
                      ~Taff
                      It's been 40+ years of fascination with the geometry & mathematical derivation of the elements of geodesic domes, which used to be closely-guarded proprietary information.
                      haha! ok i will keep that in mind. whatever your "relationship" with these is - this is simply great and fascinating work
                      • TaffGochT Offline
                        TaffGoch
                        A simplified SketchUp model is available:
                        Gears Ball- 3D Warehouse
                        %(#BF0000)[(Clickable image-link, to deviantART😞]
                        http://fc00.deviantart.net/fs70/f/2011/209/8/9/92_gears___animation_study_by_taffgoch-d41pt63.gif
                        ~Taff
                        • N Offline
                          notareal
                          Hypnotic! 😲
                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                            Goonster
                            This is superb!
                            I wondered the same thing as slimdog when I saw this though. Where would the gears meet and what could be powering it? ( just a thought)
                            • daleD Offline
                              dale
                              Cool indeed!
                              Great to see more of your amazing work.
                              • TaffGochT Offline
                                TaffGoch
                                I'm gratified that you folks are liking this.
                                I've decided to embark upon striving to learn Adobe Flash. As my first production, I converted this particular animated-gif into an animated-flash (adding sound, as "lagniappe.")
                                (Clickable image)
                                http://fc06.deviantart.net/fs70/i/2011/218/d/c/92_gears___flash_animation_by_taffgoch-d45huow.gif
                                I am, right away, impressed with Flash. The SWF-animation has much-higher color resolution (24-bit), yet the jpeg-compression can be adjusted to produce a file no bigger than the animated-GIF. 'Looking forward to learning more about Flash.
                                -Taff
                                • simon le bonS Offline
                                  simon le bon
                                  Dear Taff,
                                  I have taken these pictures, thinking they where for you: it is "time" with this wonderful geodesic watchmaking to offer them to you. 😄
                                  La Géode, Cité des Sciences, La Villette, Paris.
                                  La Géode: Wikipedia
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/thLaGeode01.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/thLaGeode02.jpg
                                  Cheers, simon.
                                  PS: I love the "doom" sound of your machinery into the flash animation.
                                  • TaffGochT Offline
                                    TaffGoch
                                    Thanks, Simon,
                                    I've long admired La Géode, from photos I've seen online.
                                    It would be great to visit (adding to a long list of other geodesic-architecture landmarks.)
                                    -Taff
                                    • jarynzlesaJ Offline
                                      jarynzlesa
                                      your work is always unbelievable 👍 .
                                      http://www.vizualizaceschodiste.mypage.cz/
                                        d12dozr
                                        I'm blown away, Taff, your work never fails to be inspiring
                                        http://goo.gl/f7ooYh
