    Is there an EXCEL spreadsheet link plugin?
    27 Posts 4 Posters 8.2k Views 4 Watching
    • jgbJ
      jgb
      @tig said:
      NO... I mean manipulate the data exported via the Ruby script πŸ˜’
      Not sure I understand your question. πŸ˜•
      I would not manipulate the data elements with a Ruby script, other than formatting them properly. That tends to create a hard format for output. You could never know what the user might want. i.e. Do not put a units indicator on dimensional data (" for inches) just the raw number. I will know what units my model is in, and if you are consistent with a unit type, or can format the number in the current model units, I can easily work with that, but not with a units mix. Same with attaching the type of component (<instance>) to the name. Make it a separate CSV element, then I do not have to strip stuff from the raw data before I can use it.
      Just export the raw data as a .CSV file. I have more dexterity (for me anyway) in EXCEL to create any format of report with raw relational data.
      If you want, I can dummy up a few EXCEL reports I can use in my boat design and airplane models. That can take a few days though.
      jgb
        I mean customize the Ruby code so what it exports is more like what you want already - rather than try to manipulate the data in Excel after it's been exported...
        • jgbJ
          jgb
          Like I said, there is far more flexibility to manipulate raw CSV data in EXCEL than you would have trying to be generic in RUBY for everyone. And even more-so, easier for you to script a raw data exporter than a formatted series of canned reports.
          πŸ’­ Here's a thought. πŸ’­ Create a fixed format CSV data exporter on 1 or more reports, and I will create a general relational DB from that data that anyone with minimal EXCEL knowledge can use to create their own custom reports.
          I will give you full rights to it and I will also write documentation. The spreadsheet will automatically import the CSV files from a consistent folder you put them into, format the data and setup the relational headers. All the user needs to do is select which data he wants to see in an output report and create any manipulation formulas as needed. In addition, he can add supplementary data to various data sets (ie: density associated with specific materials) to calculate true weight, assuming you provide Solids volume.
          In that way it can be a "live" report that updates every time the data is exported from SU and the EXCEL sheet is recalculated. Basic tasks would be Macro driven, such as importing CSV files, and specific report printing.
          I've done stuff like this before, mind you with LOTUS 123 a long time ago, but EXCEL has more functionality now. Even so, it is not a trivial task and would take a few weeks at least for me to perfect it.
          If you are interested, PM me and then we can communicate more efficiently via e-mail, rather than though SketchUcation.
          jgb
            OK...
            Let's assume we have a way of exporting lots of SKP data to a CSV...
            Can you compile a list of like info you want to then extract from the CSV into another formatted version...
            For example I'd see all of the basic stuff like location, bounds-x/y/z, face-area, instance-volume etc to be in inches and then converted post-export to sqm or whatever...
            The data will also vary by 'type' of object - obviously an edge doesn't have an area or volume...
            The material data for various thing can be used to assign density etc, we can also split material data in RGB/alpha/texture etc - this is basically what an exporter like my OBJ exporter does but that formats the info into an OBJ format not CSV...
            We need an agreed format for the CSV data listing[s] so the columns can be readily accessed in Excel - the first entry of the Row can give us the exported object's type...
            I'll make a list you make yours and we can then discuss it 'off-forum'...
            • jgbJ
              jgb
              Since I do not know what data is readily available in SU for export, you have my preliminary list above.
              Essentially, I would say "everything" but we both know that is not practical, as some stuff is basically useless to create a report on. (ie: which layer is on/off or its colour at time of export)
              How's about you publish a list of everything you can export to a CSV here in this (or perhaps a new) thread, and poll the general unwashed as to relevance and usefulness. Then we can eliminate the unnecessary, and group the list logically.
              Or if you don't want to make an all encompassing list public at this time, we can do it offline first.
              I'm easy either way.
              Also, you might think about publishing a very limited list of data elements that a user can update, such as Layer, Component or group names that can be exported back to SU to update the model. It is easier to make that sort of text edits in EXCEL than in SU, especially if there is a lot of corrections to make. An SU updater would be an add-on update to the spreadsheet after the Reporter is vetted by SU users.
              jgb
                Here's a start... CSVexportProtocols.txtWhat else do you want to extract - most things are accessible somehow...
                • jgbJ
                  jgb
                  Took a very quick look at the file.
                  Obviously there is a lot more data than most users (especially me) would be interested in, and some of only cursory curiosity. Then the hard core users could want and make use of those rarefied bits.
                  We will end up with perhaps 99% of it, but let's start with a subset of the 16 entity types, the one's I think would be of greater interest. Later the other entities can be incorporated by simply expanding on the basic framework of the exporter RB and the reporter spreadsheet, as requested by users.
                  If you can give me a list of the data elements available for each of the following 8 entities, even if of dubious use (for now) then I can mockup a spreadsheet with a relevant selection of those elements.
                  Model
                  Face
                  Group
                  Definition
                  Instance
                  Material
                  Layer
                  Text
                  The real key here is some unique common identifier so a relational DB can work.
                  I am going to assume the "REF" is that identifier. So if say, component ZZZ says its "parent" is XXX, then the REF of XXX should be the data element, not the name. The name is useful as well, but not necessary. The RDB function will replace the parent as XXX not its REF. Again, I'm assuming that ZZZ is nested within XXX.
                  Also, any NUL data in an element field must contain a value of some kind, zero or "-" to avoid misplaced columns which will royally screw things up.
                  Replacing embedded "," with ";" is not a problem for me. However you can also substitute one common alternative extended ASCii code (128-254) for any embedded "," (ASCii 44) that I can search and replace with a "," in the RDB. It should be innocuous to an EXCEL CSV import.
                  After I see the list of data elements and understand what each really represents (with your tutelage), then we can see where some can be eliminated, or others combined.
                  At that point you can produce a raw data CSV exporter while I mockup the Spreadsheet.
                  We will also need 1 or more varied geometric SKP's to test with.
                  Once we are in sync, I can start defining the detailed spreadsheet functionality.
                  Then it can be expanded in stages to meet any demand.
                  jgb
                  • jgbJ
                    jgb
                    I've started a mockup to test some concepts for the reporter. πŸ˜„
                    I just ran into a very frustrating limitation in EXCEL that LOTUS123 had no problem with. I've queried some expert XL'rs but no reply yet. The available help does not address this at all.
                    When XL imports a CSV file it opens a new window, rather than import into the open sheet at the time. That file import also puts me into the new window, where I then have to macro copy the CSV data over into the spreadsheet where I want it. Then go back to the CSV file window and close it, which will return me back to the spreadsheet.
                    I need to define the sheets by name (in a cell reference) to the Macro. There is a "range("name")" function that I use for selecting the files to import, BUT the window switching macro command "Windows("windowname").activate" will not accept it. It wants a hardcoded window name in the syntax, and that would blow me out of the water to give the reporter the flexibility to work with any SU model.
                    There is another way to do this using a CSV dataset in a TXT file. While that would put the data exactly where I want it, the user has to put up with a data formatting dialog for every CSV file. That is a non-starter.
                    πŸ‘Š πŸ‘Š πŸ‘Š
                    jgb
                      You insert the CSV just the once as a 'linked object' so the XLS updates when the CSV changes... but the XLS formats and uses the CSV data as it wishes...
                      I think you can have the entire CSV load into an unused worksheet and extract data from that into other worksheets in the same XLS as desired...
                      I haven't had a chance to think any more about this but I will get back to you...
                      • jgbJ
                        jgb
                        Had not thought about linking. Never tried it, but tomorrow I will bone up on it.
                        The auto-update is intriguing. πŸŽ‰
                        thanks.
                        jgb
                          I have done this before with a CSV linked into a XLS.
                          The SKP exporter keeps the CSV up to date and the XLS displays the latest CSV data on opening or can be updated when open [like an Xref].
                          Because you can't format a CSV you do all of your formating in the host XLS and manipulate cells etc as needed.
                          As I said you need at east two worksheets in the XLS.
                          One sheet containing the CSV 'insert' link and the other sheet reading data from it with formatting, formulas etc as needed. Obviously you could have several worksheets presenting different aspects of the CSV's data if desired...
                          • jgbJ
                            jgb
                            My concept is a workbook with several sheets, maybe 20+ with all 16 entities reported.
                            Several CSV data sheets each containing the raw CSV data and a slightly massaged version of that data used for the database. I am leaning towards 1 sheet per entity type, but will combine a few where practical.
                            A main cover sheet for user controls and macro cell references, plus user guide.
                            Several canned reports, 1 per sheet. So far, 5 reports.
                            and as many added user defined reports as wanted, 1 per sheet.
                            The report sheets are divided in 2, the far right side is for the raw data extract from the CSV data sheets, specific to the report in sorted order.
                            The left side is for the formatted output report.
                            In addition, my concept would open a new CSV import window, from which I transfer the data over to the CSV data sheets, then close that window. I have not yet considered the linking aspect you mentioned yesterday, so this may change.
                            I was going to make the sheet flexible enough to handle multiple models, 1 at a time, but this am I realized this won't be practical.
                            So there will be a master template, from which is spawned a copy for each SU model the user wants. The template would be user unalterable, but the copies will just protect critical parts of the sheet. I will publish the model sheet passwords for those who wish to be daring, but not the master template password. Only you and I will know that.
                            Until I get a solution to the windows switch macro, I am defining several other macro models to do specific housekeeping tasks.
                            jgb
                            • jgbJ
                              jgb
                              Hey Tig; still with me on this ❓ ❓ ❓ ❓
                              I have figured a very simple workaround to the window name/address problem. 😍
                              So immediately, EXCEL throws another curve at me. 🀒
                              When I attempt to close the CSV input window, either with or without data in it, EXCEL sometimes asks if I want to save the sheet before closing. But the MACRO will not record my "NO" (dammit) entry. Not only that, it is not consistent in asking. I started searching any EXCEL help files, but gave up mid week and took a mental health day(s) off.
                              If this were still LOTUS 123, the data load macro would be long done and working right.
                              jgb
                                I've been a bit preoccupied but I am still here πŸ˜‰
                                Rule 1: you should never edit the CSV file.
                                Rather you must insert the virgin CSV file as a linked file into a separate XLS file.
                                Now you can FORMAT the data in the XLS as desired and save the XLS - but never EDIT the data from the CSV directly as this is your the link back into the SKP [eventually!].
                                Now if you edit the CSV file directly [I know I said NOT to, but here we will 'simulate' the SKP changing the CSV fro now!!!].
                                Now the XLS will change to suit the CSV changes...
                                If you want to be able to change the CSV file it's OK BUT only if yu them 'import' it back into the SKP!
                                It'll be destroyed next time the SKP exports the data to the CSV anyway πŸ˜’
                                • jgbJ
                                  jgb
                                  I had no intention of editing the CSV file, only import, copy over and close the import file, unchanged.
                                  I need them pristine in case the files needed to be imported again. If any were edited then I would have to run the SU Extract script every time, and that may not be advisable in some circumstances, especially if the SU model is undergoing changes, but the user wants to develop reports using an older version of the model.
                                  Any editing was done on the copy in the XL CSV data area, after the import CSV was closed.
                                  Should we (I hope) be able to export to SU a changed CSV file, then I will deal with that later, probably by bringing it in again, make the edits and exporting the changed CSV to SU.
                                  I am not yet sold on a linked CSV file. I have no experience with that, but It may not be a good idea to auto update the XL reporter, unless there is some user control. Like I said, I need to experiment with it, but I have that stupid "save file - Yes/No" dialog to contend with.
                                  In Lotus 123 EVERY keystroke/mouse click could be recorded or simply coded for. In XL, most of the time you end up needing some extra code around simple stuff, like dialog box entries, or range name inclusion, and yet, some keystrokes, mouse clicks can't be coded around. Also, the documentation for XL Macros and VBA suck bigtime.
                                  jgb
                                    samyell77
                                    Im interested in this thread but sadly Im no script writer. I don't want to distract from what you are looking to achieve in this thread but it is related to something Im trying to achieve so have started a separate thread and wonder if you wouldn't mind taking a quick look to see if you have any suggestions . . .
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=39840
                                    SU Pro 2016
                                    Dell Precision M4800
                                    PC Windows 10
                                    Intel Core i7-4900MQ @ 2.80ghz
                                    Nvidia Quadro K2100M
                                    16gb RAM
                                    • Jean LemireJ
                                      Jean Lemire
                                      Hi Jgb, hi folks.
                                      If you have SU pro, you may try File menu --> Generate report.
                                      Just ideas.
